Increase current consumption with app_button
Hi All,
I am using SDK17 for my application currently. To sense ping change I am using app_button function as below. Normally my port pin remains high and current consumption of board is 6 uA with no advertisement. But when my port pin goes low, current increase to 15 uA. This behavior was not in SDK15.3. Current was normal in SDK15.3 in high or low pin cases. Can anybody help here?
void buttons_init(void)
static app_button_cfg_t buttons[] =
{DOOR1_SWITCH, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_NOPULL,button_event_handler},
app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]), BUTTON_DETECTION_DELAY);
Bipin Patel
    I have assigned the ticket to me as Stian is currently out of the office.
    karanbakshi said:
    Should we consider this as a bug as in many application GPIO normally remain low and on some events it become high. so what should we do in this cases with SDK17 app_button library?
     The button library is mainly designed with push buttons in mind. And the changes in SDK 17 were made to reduce the chance of missed events when having multiple buttons triggered around the same time.
    karanbakshi said:
    Is it fine if I use app_button library of SDK15.3 into SDK17 based application? Is any chance of issue in any way in future?
     It shouldn't be any problem to use the old library with SDK 17.
    Vidar
  • Hi Vidar.
    Thanks for comment.
    In my application, I have nearly 3 GPIO sensing which remains push low normally. As you said,  there is a improvement in SDK17 for multiple buttons triggered around the same time so what library should I use? SDK17 or SDK15.3 based? If I will use SDK17 based library then my board current will increase and if I use SDK15.3 then may I face issue in multiple button triggering?
    Bipin Patel
  • Hi Bipin,
    I think the risk of losing events is very low even if you use the old library from SDK 15.3.0, but I would of course recommend you do stress testing to confirm this. The GPIOTE driver in SDK 17 should also be more robust as it makes use of the GPIO LATCH registers.
    Vidar
  • Ok Thanks Vidar.
    Then I will go with SDK15.3 based library as of now to save power of board as normally my GPIO remains low.
    Bipin Patel
