How to prevent Radio test from stopping with cli disconnected?
Hi Devzone:
We put the radio test project on our custom battery powered board and encountered a problem.
When we disconnect the usb cable, the tone emitted by radio test project disappeared.
We want to disconnect the cable as the cable could act as an antenna.
Why the radio test needs usb cable connected to keep running? Where can I modify the code so that disconnecting cable would not stop the test?
Thanks.
  • Hi Jared:
    I added this code to cli usb example project, the added lines are in the main() function.
  • My last point was referring to your previous question about where the USBD driver might be turning off the clock. We've seen earlier that a call to request the hfclk clock with the nrf_drv_clock driver will effectively turn off the clock if the clock was already running and was initially turned on by writing directly to the register. I was therefore curious if you during the initialization process was requesting the hfclk clock for example in usbd_init()
    regards
    Jared
  • Hi Jared:
    In the main(), usbd_init() is indeed called, but that function is the original code in the cli example project written by Nordic. I did not modify it. Can you tell if it's turning off the HFCLK? Below is the code:
    static void usbd_init(void)
    #if CLI_OVER_USB_CDC_ACM
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_handler = app_usbd_event_execute,
            .ev_state_proc = usbd_user_ev_handler
        ret = app_usbd_init(&usbd_config);
        APP_ERROR_CHECK(ret);
        app_usbd_class_inst_t const * class_cdc_acm =
                app_usbd_cdc_acm_class_inst_get(&nrf_cli_cdc_acm);
        ret = app_usbd_class_append(class_cdc_acm);
        if (USBD_POWER_DETECTION)
            ret = app_usbd_power_events_enable();
            NRF_LOG_INFO("No USB power detection enabled\nStarting USB now");
            app_usbd_enable();
            app_usbd_start();
        /* Give some time for the host to enumerate and connect to the USB CDC port */
        nrf_delay_ms(1000);
    With a rough scan I didn't find any "nrf_drv_clock " related code in here that could cause HFCLK be turned off.
    The HF clock is requested in the app_usbd.c driver more specifically in sustate_set(). Either way I guess the original issue is solved?
    regards
    Jared
  • I know this thread is a bit old, but I was encountering the same issue and thought it might be helpful for others.
    It looks like when USB is disconnected and app_usbd_stop() is called, if you go down the rabbit hole, you'll end up in app_usbd.c and in the APP_USBD_EVT_STOP_REQ event, the code will try to release the hfclk in line 1106 of SDK 17.0.2. Hopefully this is helpful for others in the future.
