nRF52840 BLE advertising issue
   We are developing the BLE product based based on the nrf52840 Chipset and we are facing below problem while testing in the field.
    During our development we have come across the scenario where the BLE chip suddenly stop advertising after Some days for testing.
    This doesn’t happen every time but randomly it stops working and there is no way to discover the device. The only solution to make it to advertise its name is to program it again.
    Your timely support is appreciated to resolve the issue, or let us know if similar issue is faced by anyone in the forum.
Ram
  • Hi Jarad,
     We are using the nRF52840 chip for application where it transfer the configuration data on the Mesh network to the other nodes.
    We are able to configure the device as proxy node and transfer the information between the nodes when configured as both server and client model.
    But the problem is the reliability of data reception is not consistent.  ex if we try to transfer the data from node 1 around 10 times the  node 2 will receive the data only 8 times and another 2 times data will be missed out.
    Please let me know if you need any more information.
    Ram
    How does your mesh network look like? Is it many hops in the network between node 1 and node 2? Could you elaborate a bit more on your app, is it from a SDK example? What data do you send and which model are you using?
    regards
    Jared
  • Hi Jarad,
      We have developed our own BLE application which interacts with the PIC micro-controller through UART Port. The  micro-controller collect the data and send to the BLE chip which transmits it on the mesh so that the other similar device receive that data fro processing.
    We are using Generic On OFF Client and Generic On OFF server model for transferring the data.
    In Our mesh network we have multiple node say around 5 which is in star topology.
    Ram
    Have you checked that the data has actually been collected by the nRF through UART? Could you try to increase number of re-transmits, and consider using reliable transfer so lost packets will be resent.
    regards
    Jared
