Hallo,
how can I flash the software on the PowerProfile PCA63511?
Thank you in advance
Werner Loser
Hallo,
Werner Loser
No picture in particular, but it is described in the DK user guide how to prepare the DK for current measurement and restore normal kit function to it afterwards.
Simon
Sorry, I had read that - but it does not work properly. I must reflash the PPK at every startup.
The Power Profiler app will check the firmware on the PPK (or connected nRF chip), and prompt you to flash the Power Profiler firmware onto the PPK if the correct firmware is not present. If you get this prompt every time, that points to you flashing the PPK with some other firmware inbetween uses. You need to dismount the PPK before trying to flash the DK with any other application firmware.
Simon
