ERROR_INVALID_DATA (135) during 'Configuring and performing DFU over Mesh' v4.2.0
I've been trying to transfer a DFU update via serial, and I have gotten error 135 each time.
A colleague of mine got it working this january, with v3.1.0. Now, the same scripts don't work on my machine, with my nrfutil Installation. I am using the current commit of the mesh_dfu branch of the nrfutil tool.
This is my console output:
C:\_SVN\01_FuMu_SOM_TestPCB\BLE Mesh DFU Update 4.2>nrfutil --verbose dfu serial -pkg blinky_update.zip -p COM11 -b 115200 -fc --mesh
Upgrading target on COM11 with DFU package C:\_SVN\01_FuMu_SOM_TestPCB\BLE Mesh DFU Update 4.2\blinky_update.zip. Flow control is enabled.
Flushing com-port...
Opened com-port
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 2180
Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
1: PC -> target: 0502aabbccdd
target -> PC: 0582aabbccdd
Got echo response
Sending DFU init packet
Sending ready packet
1: PC -> target: 1378fdff040f4da6184559000000010002000000
target -> PC: 03847800
Sending start packet
1: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
target -> PC: 03847887
2: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
3: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
4: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
5: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
6: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
7: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
8: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
9: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
10: PC -> target: 1478fcff00004da61845ffffffff2102000000000c
Failed to upgrade target. Error is: Device returned status code ERROR_INVALID_DATA (135) on a DFU data packet.
Possible causes:
- bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
- baud rate or flow control is not the same as in the target bootloader.
- target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
- if the error is ERROR_BUSY at the beginning of the DFU process,increase the value of PAGE_ERASE_TIME_MAX by few milliseconds.
Closing serial port...
After flashing the DFU example, this is the output on the RTT Viewer, the nothing is output while trying to send the update:
00> <t:          2>, main.c,  222, ----- Bluetooth Mesh DFU Example -----
00> <t:      12732>, ble_softdevice_support.c,  171, sd_ble_enable: app_ram_base should be adjusted to 0x200018F8
00> <t:      13257>, serial_handler_prov.c,  267, Generating encryption keypair...
00> <t:      18033>, main.c,  228, Initialization complete!
00> <t:      22743>, main.c,  249, Enabling serial interface...
00> <t:      22746>, mesh_app_utils.c,   66, Device UUID (raw): B792232387B44786B0B95873ECE2BB8A
00> <t:      22750>, mesh_app_utils.c,   67, Device UUID : B7922323-87B4-4786-B0B9-5873ECE2BB8A
00> <t:      22759>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE
00> <t:      22763>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65534)
00> <t:      22771>, main.c,  257, DFU example started!
00> <t:      23920>, nrf_mesh_dfu.c,  418,   New firmware!
00> <t:      23923>, main.c,  119, Requesting DFU transfer with bank at 0x00047000
00> <t:      23926>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD
00> <t:      23930>, nrf_mesh_dfu.c,  565, Killing a TX slot prematurely (repeats done: 1).
00> <t:      23934>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65533)
Seems fishy to me, that it immediately seems to receive packets, even though I havent started the update yet?
  • Hi Hung Bui,
    it worked! Thank you. However, to gain some deeper understanding to help me in the future, I would be thankful for some additional insight:
    I was able to narrow down the cause of the problem, because I noticed that you included dfu_nrf52832_xxAA_s132_7.0.1.hex
    which worked, but confused me a bit, so I tried it with
    dfu_nrf52833_xxAA_s113_7.0.1.hex
    which produced the same error 135 again.
    How is this possible?
    • I am using the nrf52833 chip, but the DFU version for the nrf52832 chip works
    • I am using the S113 softdevice, but the DFU version using the S132 softdevice works
    I also noticed that you sent me a different bootloader:
    • Before: mesh_bootloader_serial_gccarmemb_nrf52833_xxAA.hex
    • Now: mesh_bootloader_serial_armcc_nrf52833_xxAA.hex
    Both work. What is the difference?
  • Hi Benedev,
    It's my mistake I supposed to send you the dfu_nrf52833_xxAA_s113_7.0.1.hex.
    Could you please try again with the file I attached here:
    If this works for you, then there must be something wrong in the project/SDK you have. I would suggest to try to build using a fresh SDK copy.
    The difference between mesh_bootloader_serial_gccarmemb_nrf52833_xxAA and mesh_bootloader_serial_armcc_nrf52833_xxAA is the different compiler gcc vs armcc (Keil). They should both work the same.
  • Hi Hung Bui,
    thank you, it worked your file, and it also worked after I redownloaded the SDK and rebuilt the DFU example. Very weird, I didn't knowingly change anything. Anyway, I now have a working DFU Mesh example and I can start including it in my project, thank you very much!
