SPI Master initialization with BLE
I've been trying to implement a SPI master module in the example ble_app_hrs_c_s120 on the nRF51 DK with nRF51422 (I copied the code of the example of spi_master in the BLE example).
It compiles without error nor warnings but doesn't work. After debugging, I found out that it's the configuration of the SPIM that causes a HardFault at the exact line :
// Configure SPI master.
spi_master_config_t spi_config = SPI_MASTER_INIT_DEFAULT;
The symbol is defined as :
#define SPI_MASTER_INIT_DEFAULT                                             \
    SPI_FREQUENCY_FREQUENCY_M1, /**< Serial clock frequency 1 Mbps. */      \
    SPI_PIN_DISCONNECTED,       /**< SCK pin DISCONNECTED. */               \
    SPI_PIN_DISCONNECTED,       /**< MISO pin DISCONNECTED. */              \
    SPI_PIN_DISCONNECTED,       /**< MOSI pin DISCONNECTED. */              \
    SPI_PIN_DISCONNECTED,       /**< Slave select pin DISCONNECTED. */      \
    APP_IRQ_PRIORITY_LOW,       /**< Interrupt priority LOW. */             \
    SPI_CONFIG_ORDER_LsbFirst,  /**< Bits order LSB. */                     \
    SPI_CONFIG_CPOL_ActiveHigh, /**< Serial clock polarity ACTIVEHIGH. */   \
    SPI_CONFIG_CPHA_Leading,    /**< Serial clock phase LEADING. */         \
    0                           /**< Don't disable all IRQs. */             \
I really can't figure out why it doesn't find the symbol. It's defined in spi_master.h that I included in the main.
The SD S120 is downloaded on the board and I use uvision 5.14 with the SDK 8.0.
Do you have any idea?
Thank you so much for your help, I'm stuck.
Yann
  • Okay, I changed for SPI1 instead of SP0 and it's working (?!) until the line :
    APP_ERROR_CHECK(sd_nvic_ClearPendingIRQ(p_spi_instance->irq_type));
    which now causes the hard fault...
    Thank you for your help.
  • Check if you have not set the interrupt priority for the SPI to be too high, it cannot be higher priority than NRF_APP_PRIORITY_HIGH If it is possible to attach your file, then probably I take a look into it.
  • main.c
    The SPI interrupt priority is set to low (same as the UART perif.).
    Here is the function (located in spi_master.c) that causes the hardfault, exactly at the line
    	 APP_ERROR_CHECK(sd_nvic_EnableIRQ(p_spi_instance->irq_type));
    at the end of the function. Apparently it's when the softdevice is called to enable the SPI IRQ.
    uint32_t spi_master_send_recv(const spi_master_hw_instance_t spi_master_hw_instance,
                                  uint8_t * const p_tx_buf, const uint16_t tx_buf_len,
                                  uint8_t * const p_rx_buf, const uint16_t rx_buf_len)
        #if defined(SPI_MASTER_0_ENABLE) || defined(SPI_MASTER_1_ENABLE)
        volatile spi_master_instance_t * p_spi_instance = spi_master_get_instance(
            spi_master_hw_instance);
        APP_ERROR_CHECK_BOOL(p_spi_instance != NULL);
        uint32_t err_code   = NRF_SUCCESS;
        uint16_t max_length = 0;
        uint8_t nested_critical_region = 0;
        //Check if disable all IRQs flag is set
        if (p_spi_instance->disable_all_irq)
            //Disable interrupts.
            APP_ERROR_CHECK(sd_nvic_critical_region_enter(&nested_critical_region));
            //Disable interrupt SPI.
            APP_ERROR_CHECK(sd_nvic_DisableIRQ(p_spi_instance->irq_type));
        //Initialize and perform data transfer
        if (p_spi_instance->state == SPI_MASTER_STATE_IDLE)
            max_length = (rx_buf_len > tx_buf_len) ? rx_buf_len : tx_buf_len;
            if (max_length > 0)
                p_spi_instance->state        = SPI_MASTER_STATE_BUSY;
                p_spi_instance->bytes_count  = 0;
                p_spi_instance->started_flag = false;
                p_spi_instance->max_length   = max_length;
                /* Initialize buffers */
                spi_master_buffer_init(p_tx_buf,
                                       tx_buf_len,
                                       &(p_spi_instance->p_tx_buffer),
                                       &(p_spi_instance->tx_length),
                                       &(p_spi_instance->tx_index));
                spi_master_buffer_init(p_rx_buf,
                                       rx_buf_len,
                                       &(p_spi_instance->p_rx_buffer),
                                       &(p_spi_instance->rx_length),
                                       &(p_spi_instance->rx_index));
                nrf_gpio_pin_clear(p_spi_instance->pin_slave_select);
                spi_master_send_initial_bytes(p_spi_instance);
                err_code = NRF_ERROR_INVALID_PARAM;
            err_code = NRF_ERROR_BUSY;
        //Check if disable all IRQs flag is set.
            //Enable interrupts.
            APP_ERROR_CHECK(sd_nvic_critical_region_exit(nested_critical_region));
            //Enable SPI interrupt.
        return err_code;
        #else
        return NRF_ERROR_NOT_SUPPORTED;
  • Seems strange, however I cannot know the reason for the hardfault unless I will be able to reproduce it myself and I do not have working setup to test this yet. I will try to reproduce this on monday.
  • Thank you so much !
    I may have complicated the thing. The main goal is just to have a working SPI master peripheral with a BLE collector...
    Anyway thank you and have a nice weekend.
