Time for configuring node increases after deleting from mesh network
Hi guys,
I have the same issue as coca1989 had 2 years ago. Did anybody found a solution?
I am using health model and simple message model. Client and Provisioner are running on one device (demoboard). I can provision and configure upto 5 server nodes (dongles). I get health events from each connected server (all 10 seconds) and I can send and receive small messages on all server nodes.
Now, I would like to remove nodes from the mesh network and reconnect them (reprovisioning and reconfiguration). This are the steps that I am doing:
  1. config_client_server_bind() and config_client_server_set() to the server node I would like to remove from network
  2. config_client_node_reset()
  3. the server gets the node reset event (CONFIG_SERVER_EVT_NODE_RESET) from client and performs node_reset() with:  mesh_stack_config_clear() and mesh_stack_device_reset()
  4. the server responds to the client with CONFIG_CLIENT_EVENT_TYPE_CANCELLED and I do dsm_devkey_delete()
After removing the server node, I can reprovision and reconfigure the node successfully (getting health events and send/receive messages). But the configuration takes longer then the first time. Repeating this process (removing node and reconnecting) increases the configuration time each time.
Here is a time table:
First configuration: 2-3 seconds
Second configuration (after removing node from mesh): 10-11 seconds
Third configuration (after removing node from mesh):20-30 seconds
Fourth configuration (after removing node from mesh): 45 -50 seconds
Fifth configuration (after removing node from mesh): >80 seconds
This is reproduceable. Rebooting the client/provisioner device after removing a server node reduces the configuration time back to 2-3 seconds, but I do not get health events and no messages.
During reconfiguration (after removing the server from network) I am getting SAR mesh events on the server node. At the first configuration (fresh device) I dont have this SAR events.
I guess I have to delete more on client side? Maybe the simple message or health is still active on the last address handles?
