My Setup details:
nRF9160 DK Board: 0.8.3
nRF Connect SDK tag: 1.3.0
OS: Windows 10 Pro
LTE Network: NB-IoT
Modem Firmware: mfw_nrf9160_1.2.0
Cloud Platform: AWS IoT Core
CONFIG_AWS_IOT_MQTT_PAYLOAD_BUFFER_LEN: 5120
Use case:
As part of device provisioning process we need to receive a MQTT message from AWS which contains certificate details, this message can't be split as we don't have control over it. Size of such messages are around 3KB.
Issue:
Whenever the incoming PUBLISH message size from AWS is more than 2048 bytes, MQTT connection is dropped. After some debugging the function "mqtt_read_and_parse_fixed_header" in MQTT library (mqtt_rx.c source code) returns -ENOTCONN.
In the release notes of modem firmware, a limitation is mentioned about TLS feature: "2kB secure socket buffer size."
However after experimenting with incoming message sizes I noticed publish messages up to 2235 bytes are received successfully. Few bytes over it and the connection drops. In general with TCP protocol large packets can be received with small buffers with appropriate MTU/Window size. Is this issue linked to the above TLS limitation or something else?
Reproducing the issue is simple, use any cloud example to connect to AWS over TLS, subscribe to any topic and from AWS send 2KB+ sized messages.
Ravikiran
