SAADC callback never called with Softdevice
Hello, I'm having trouble to understand why the saadc buffer is not being filled.
I had already tested this functionality without the softdevice, and everything worked fine but now, with the softdevice,
I found that the "saadc_callback" function is not called at any time.
I tried to follow some clues after reading several posts here on the blog on this subject, but they did not lead me to a solution.
Tested items:
Modify saadc to continuous mode.
Modify the saadc interrupt priority.
The timer for the PPI ist the TIMER1
Thanks
  • I can not see that you are calling nrf_drv_ppi_channel_enable
    anywhere. Could you confirm for me that this is in fact done?
    I do that in the main function.
    I think I found a solution, I changed the SAADC priority to APP_IRQ_PRIORITY_THREAD in their initialization but I don't know if it's the best (if it will cause problems in the future with the messages sent by ble)
        saadc_config.resolution= NRF_SAADC_RESOLUTION_12BIT;
        saadc_config.oversample= NRF_SAADC_OVERSAMPLE_16X;
        saadc_config.interrupt_priority= APP_IRQ_PRIORITY_THREAD;
        //saadc init
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    Thank you for confirming this.
    I would not think that APP_IRQ_PRIORITY would cause the behavior you describe - SAADC initializing but buffer not getting filled, since you are using PPI.
    What is your SAMPLES_IN_BUFFER set to?
    No, you can rest assured that this will not cause any problems with the BLE communication. The SoftDevice takes priority over any application-layer task.
    Karl
  • SAMPLES_IN_BUFFER
    #define SAMPLES_IN_BUFFER         128
    When I activate the BLE_NUS Log in debug mode, it shows the following message:
    <info> app: Connected to device with Nordic UART Service.
    <debug> nrf_ble_gq: Processing the request queue...
  • Thank you for the update.
    I do not immediately see how changing the priority to APP_IRQ_PRIORITY_THREAD could resolve the issue you described, but I am happy that you have found a solution to your issue.
    Please do not hesitate to open a new ticket if you should encounter any issues or questions in the future!
    Karl
  • The problem was the allocation of the PPI channels, to solve it I just modified the PPI channels that I used in another part of the program (I had configured the same channel PPI twice for different applications and with this, only the last configuration was valid)
