nRF52833 development
Hello all,
I am working on low power sensor development with nRF52833 as target. I have some questions but I'm not sure it this was addressed in some other posts.
1. I don't have nRF52833 DK but instead I use nRF52840DK for development under SES environment. What in particular should I be aware of when generating target code for nRF52833?
2. I wan't to place sensor in sleep state for longer period of time. From product spec I understand that I should use wake on RTC and no RAM retention for lowest possible power. Because of no RAM retention, I need CPU to restart after timeout, not to go to application timer timeout handler but to top of main. How can I set this up?
Thanks
  • I am sorry for bothering you, but I think there is still a problem with sleep-wakeup sequence:
    1. When sleep timer is created, pointer to sleep timer callback routine is stored in RAM (by calling app_timer_create)
    2. RAM retention is turned OFF and device sleep timer starts counting. (by calling app_timer_start)
    3. If there is no active task (for example advertising), device will go to low power mode. All RAM content will be lost
    4. When sleep timer expires, CPU will have to fetch pointer to sleep timer callback routine (created in step 1.)
    But at step 4 all RAM data is lost, including pointer to sleep timer callback routine. How can program execution go to sleep timer callback routine if pointer to it is destroyed
    Best regards
  • Hi
    No problem at all, we're here to help you get a better understanding of nRF development. I should have been clearer in my explanation.
    The RTC peripheral is its own independent peripheral and is not dependent on the app_timer in order to trigger a wake-up, as long as the peripheral is powered you won't be dependent on what the RAM is doing. You can take a look at the RTC peripheral example to see how you can use RTC without the app_timer.
    Keep in mind that, depending on your application, you might not see a better average current consumption if you have to reinitialize a bunch of peripherals whenever your device wakes up due to the RAM not being retained, so it might be just as energy-efficient to have RAM retention if you save a lot of power on the wake-up process that way.
    Simon
  • Hi Simon,
    My application is such that sensor sleeps for 8 hours, wakes up, performs soft reset, then starts advertising for few minutes, then goes back to 8 hour sleep. It stays in this loop forever. As you can see, battery life greatly depends on power during sleep. I hope to achieve 1.5uA sleep current as specified in product spec (wake on RTC event and no RAM retention)
    ION_RAMOFF_RTC
    System ON, no RAM retention, wake on RTC (running from LFRC clock)
    1.50
    µA
    Actually, RAM retention is term applicable only for System OFF state (above table entry may be misleading because wake on RTC event assumes system is ON). I think the table entry should say "System ON, all RAM powered off, wake on RTC".
    I have modified RTC example as below. After RTC timer is initialised, all of the RAM is powered off. When RTC interrupts, soft reset is called.
    This is exactly what I want to do in my application. Result is that my nRF52840 DK bricks itself (I need to recover it by (nrfjprog --recover --family NRF52)
    I actually expected this will happen because turning ALL of the RAM off is like "cutting the branch you sit on" Slight smile
    Can you illustrate example which results in 1.5uA current during timeout and wake on RTC?
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup rtc_example_main main.c
     * @ingroup rtc_example
     * @brief Real Time Counter Example Application main file.
     * This file contains the source code for a sample application using the Real Time Counter (RTC).
    #include "nrf.h"
    #include "nrf_gpio.h"
    #include "nrf_drv_rtc.h"
    #include "nrf_drv_clock.h"
    #include "boards.h"
    #include "app_error.h"
    #include
    #include
    #define COMPARE_COUNTERTIME  (3UL)                                        /**< Get Compare event COMPARE_TIME seconds after the counter starts from 0. */
    #ifdef BSP_LED_0
        #define TICK_EVENT_OUTPUT     BSP_LED_0                                 /**< Pin number for indicating tick event. */
    #ifndef TICK_EVENT_OUTPUT
        #error "Please indicate output pin"
    #ifdef BSP_LED_1
        #define COMPARE_EVENT_OUTPUT   BSP_LED_1                                /**< Pin number for indicating compare event. */
    #ifndef COMPARE_EVENT_OUTPUT
    const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
    /** @brief: Function for handling the RTC0 interrupts.
     * Triggered on TICK and COMPARE0 match.
    static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
        NVIC_SystemReset();
    /** @brief Function configuring gpio for pin toggling.
    static void leds_config(void)
    /** @brief Function starting the internal LFCLK XTAL oscillator.
    static void lfclk_config(void)
        ret_code_t err_code = nrf_drv_clock_init();
    /** @brief Function initialization and configuration of RTC driver instance.
    static void rtc_config(void)
        uint32_t err_code;
    //Initialize RTC instance nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG; config.prescaler = 4095; err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler); APP_ERROR_CHECK(err_code); //Enable tick event & interrupt nrf_drv_rtc_tick_enable(&rtc,true); //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true); APP_ERROR_CHECK(err_code); //Power on RTC instance nrf_drv_rtc_enable(&rtc); } /** * @brief Function for application main entry. */ int main(void) { leds_config(); lfclk_config(); rtc_config(); NRF_POWER->RAM[0].POWERCLR = 0x3; NRF_POWER->RAM[1].POWERCLR = 0x3; NRF_POWER->RAM[2].POWERCLR = 0x3; NRF_POWER->RAM[3].POWERCLR = 0x3; NRF_POWER->RAM[4].POWERCLR = 0x3; NRF_POWER->RAM[5].POWERCLR = 0x3; NRF_POWER->RAM[6].POWERCLR = 0x3; NRF_POWER->RAM[7].POWERCLR = 0x3; NRF_POWER->RAM[8].POWERCLR = 0x3F; while (true) { __SEV(); __WFE(); __WFE(); } } /** @} */
    But if I only power OFF RAM 8, like this
    Then it doesn't brick itself.
    What I meant is that some RAM must stay powered on during sleep.
    Regards
    Kerim
  • Hi again,
    I figured out that if I change this line
    to this:
    err_code = nrf_drv_rtc_init(&rtc, &config, 0);
    then it seems to work fine, no bricking when all RAM power is off. Presumably replacing RTC callback routine by system reset vector. I guess 0 is system reset vector, is it?
    Regards
  • Hi
    I'm sorry, but setting the rtc_handler to 0 in the nrf_drv_rtc_init() bricks the device on my end. Have you made any other changes to your application to allow for this setting to 0? What current consumption is the best you're able to achieve? I've tested myself on an nRF52832 DK (the only DK I had at hand this morning, which according to the spec. should draw ~1.9µA in this mode) and got it down to ~2.3µA with very small adjustments to the RTC handler.
    As for the 1.5µA that is stated in the spec. this is the absolute lowest possible current consumption you can achieve with the RTC running. This is a combination that's not really usable in and of itself as you will always need to have some RAM enabled if you'd want to execute interrupts, etc. The SDK examples are made to be generic and suit most use cases, and are likely in need of modifications in order to suit specific use cases. With the RTC module in the SDK with a usable application wrapped around it, getting the current consumption down to ~2.0µA should be feasible during sleep mode, depending on the application of course.
    My apologies for any confusion and misunderstandings throughout this thread.
    Simon
