Implementing 64-bit Epoch Time Using Timer
I have an application that requires that timestamps be 64-bit epoch to the millisecond.  I'm currently using a Timer peripheral to track 1ms and increment a 64-bit counter.  I was concerned reading the value in an atomic way so I am currently disabling all interrupts when a read is performed but this seems to be pretty heavy handed.
I saw this post https://devzone.nordicsemi.com/f/nordic-q-a/27597/extending-rtc-beyond-24-bits and it seem likes it's better just to disable the timer interrupt.
I noticed the driver API also clears the current timer value when the interrupts are enabled.  Is there a reason for this?
Is there are better way to achieve the atomic read than my current implementation?
  • I have some followup questions regarding the suggested implementation.  You sequence mentions disabling the timer interrupt and then enabling the timer interrupt once I have gotten the number of milliseconds using the capture.
    I took this to mean disabling the CC[0] interrupt and then enable the CC[0] interrupt. The nrfx_timer.c implementation
    nrfx_timer_compare_int_enable
     calls
    nrf_timer_event_clear
     which clears the timer counter which will cause time to be lost every time the epoch is read, no?
    Should I just call
    nrf_timer_int_enable
     directly instead?
  • Hi Darren
    Yes, you shouldn't have to disable the compare event itself, just temporarily disable the interrupt.
    nrf_timer_int_disable/enable should work fine, or you could disable the timer interrupt globally.
    Best regards
    Torbjørn
