SAADC scan + burst?
On SDK16.0.0 + Mesh SDK 4.1.0
I know that oversampling when using the SADDC in scan mode on multiple channels does not work because the buffer gets all out of order.
But I believe burst mode can be used in scan mode where it samples the channel multiple times as fast as possible, averages it, and then puts the result in the buffer in the right order. Burst mode uses the oversample setting for setting how many readings to average. Is this all correct?
Does this work in SDK16.0.0 by simply setting nrf_drv_saadc_config_t .oversample value and nrf_saadc_channel_config_t .burst value? I did this and everything seems to be working, but I don't know if it's actually doing it. I initially tried to use nrf_saadc_burst_set(channel, NRF_SAADC_BURST_ENABLED) to enable burst for each channel, but that did not work and the readings were all wrong.
Or do some modifications need to be made like in this thread? https://devzone.nordicsemi.com/f/nordic-q-a/26659/saacd-scan-oversample/
Thanks.
