Projects for Writing into Flash Memory does not work on nRF52840 dongle
I am using nRF52840 dongle and nRF SDK version nRF5_SDK_17.0.0_9d13099.
When I am trying to debug the application it gives an error.
using your example project on nRF52840 dongle
nRF5_SDK_17.0.0_9d13099\examples\peripheral\flash_fds\pca10056\s140\ses\flash_fds_s140_pca10056.emProject
main.c
Line 352 rc = fds_record_update(&desc, &m_dummy_record);
after that it goes to
app_error_weak.c file , Line no. 100
nRF5_SDK_17.0.0_9d13099\examples\peripheral\flash_fstorage\pca10056\s140\ses\flash_fstorage_s140_pca10056.emProject
main.c
line no. 284 rc = nrf_fstorage_write(&fstorage, 0x3e100, &m_data, sizeof(m_data), NULL);
nRF5_SDK_17.0.0_9d13099\examples\peripheral\flashwrite\pca10056\blank\ses\flashwrite_pca10056.emProject
When trying to write hex file into the dongle, it does not allow to add softdevice hex file, stating that the hex file is overlapping.
if I try to write hex file flashwrite_pca10056.hex, it gives an error, log of the programmer is   2020-08-11T07_59_13.264Z-log.txt
do let me know, what I am missing.
  • Hi Amanda ,
    I had modified main.c file of ble_app_blinky_pca10059_s140.emProject located at
    nRF5_SDK_17.0.0_9d13099\examples\ble_peripheral\ble_app_blinky\pca10059\s140\ses.
    Added code from nRF5_SDK_17.0.0_9d13099\examples\peripheral\flashwrite\main.c
    I am able to write data into flash memory successfully when i executes write command after calling
    flash_page_init() function, but it fails if i execute write function after advertising_start() function.
    following error occurs
    id = NRF_FAULT_ID_APP_MEMACC
    pc = 0x0002ef0e
    info = 0x40000000
     * Copyright (c) 2015 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_clock.h"
    #include "nrf_nvmc.h"
    #define FLASHWRITE_EXAMPLE_MAX_STRING_LEN       (62u)
    #define FLASHWRITE_EXAMPLE_BLOCK_VALID          (0xA55A5AA5)
    #define FLASHWRITE_EXAMPLE_BLOCK_INVALID        (0xA55A0000)
    #define FLASHWRITE_EXAMPLE_BLOCK_NOT_INIT       (0xFFFFFFFF)
    //static char data[] = "AABBCCDD";
    typedef struct
       uint32_t magic_number;
       uint32_t buffer[FLASHWRITE_EXAMPLE_MAX_STRING_LEN + 1]; // + 1 for end of string
    } flashwrite_example_flash_data_t;
    typedef struct
        uint32_t addr;
        uint32_t pg_size;
        uint32_t pg_num;
        flashwrite_example_flash_data_t * m_p_flash_data;
    } flashwrite_example_data_t;
    static flashwrite_example_data_t m_data;
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        ret_code_t              err_code;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        ble_lbs_init_t     init     = {0};
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    static ret_code_t clock_config(void)
        err_code = nrf_drv_clock_init();
        if (err_code != NRF_SUCCESS && err_code != NRF_ERROR_MODULE_ALREADY_INITIALIZED)
            return err_code;
        return NRF_SUCCESS;
    static void flash_page_init(void)
        m_data.pg_num = NRF_FICR->CODESIZE - 1;
        m_data.pg_size = NRF_FICR->CODEPAGESIZE;
        m_data.addr = (m_data.pg_num * m_data.pg_size);
        m_data.m_p_flash_data = (flashwrite_example_flash_data_t *)m_data.addr;
        while (1)
            if (m_data.m_p_flash_data->magic_number == FLASHWRITE_EXAMPLE_BLOCK_VALID)
                return;
            if (m_data.m_p_flash_data->magic_number == FLASHWRITE_EXAMPLE_BLOCK_INVALID)
                ++m_data.m_p_flash_data;
                continue;
            nrf_nvmc_page_erase(m_data.addr);
            return;
    static void flash_string_write(uint32_t address, const char * src, uint32_t num_words)
        uint32_t i;
        // Enable write.
        NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
        while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
        for (i = 0; i < num_words; i++)
            /* Only full 32-bit words can be written to Flash. */
            ((uint32_t*)address)[i] = 0x000000FFUL & (uint32_t)((uint8_t)src[i]);
        NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
    static void flashwrite_erase_cmd()
    static void flashwrite_read_cmd()
        flashwrite_example_flash_data_t * p_data = (flashwrite_example_flash_data_t *)m_data.addr;
        char string_buff[FLASHWRITE_EXAMPLE_MAX_STRING_LEN + 1]; // + 1 for end of string
        if ((p_data == m_data.m_p_flash_data) &&
            (p_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_VALID))
    //        nrf_cli_fprintf(p_cli, NRF_CLI_WARNING, "Please write something first.\r\n");
            return;
        while (p_data <= m_data.m_p_flash_data)
            if ((p_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_VALID) &&
                (p_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_INVALID))
    //            nrf_cli_fprintf(p_cli, NRF_CLI_WARNING, "Corrupted data found.\r\n");
                return;
            uint8_t i;
            for (i = 0 ; i <= FLASHWRITE_EXAMPLE_MAX_STRING_LEN; i++)
                string_buff[i] = (char)p_data->buffer[i];
    //        nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%s\r\n", string_buff);
            ++p_data;
    static void flashwrite_write_cmd(size_t argc, char **argv)
        static uint16_t const page_size = 4096;
        if (argc < 2)
    //        nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "%s:%s", argv[0], " bad parameter count\r\n");
            return;
        if (argc > 2)
    //                        NRF_CLI_WARNING,
    //                        "%s:%s",
    //                        argv[0],
    //                        " bad parameter count - please use quotes\r\n");
            return;
        uint32_t len = strlen(argv[1]);
        if (len > FLASHWRITE_EXAMPLE_MAX_STRING_LEN)
    //                        NRF_CLI_ERROR,
    //                        "Too long string. Please limit entered string to %d chars.\r\n",
    //                        FLASHWRITE_EXAMPLE_MAX_STRING_LEN);
            return;
        if ((m_data.m_p_flash_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_NOT_INIT) &&
            (m_data.m_p_flash_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_VALID))
    //        nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Flash corrupted, please errase it first.");
            return;
            uint32_t new_end_addr = (uint32_t)(m_data.m_p_flash_data + 2);
            uint32_t diff = new_end_addr - m_data.addr;
            if (diff > page_size)
    //                            NRF_CLI_WARNING,
    //                            "Not enough space - please erase flash first.\r\n");
                return;
            nrf_nvmc_write_word((uint32_t)&m_data.m_p_flash_data->magic_number,
                                FLASHWRITE_EXAMPLE_BLOCK_INVALID);
        //++len -> store also end of string '\0'
        flash_string_write((uint32_t)m_data.m_p_flash_data->buffer, argv[1], ++len);
                            FLASHWRITE_EXAMPLE_BLOCK_VALID);
    uint8_t d[] = {'A', 'B', 'C', 'D', 'E', 'F'};
    uint8_t d1[] = {'0', '1', '2', '3', '4', '5'};
    /**@brief Function for application main entry.
        uint32_t err_code;
        // Initialize.
        log_init();
        err_code = app_timer_init();
        err_code = clock_config();
        flash_page_init();
        nrf_nvmc_write_bytes(m_data.addr, d, sizeof(d));
        leds_init();
    //    timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("Blinky example started.");
    //    nrf_nvmc_write_bytes(m_data.addr, d, sizeof(d));
        // Enter main loop.
        for (;;)
            idle_state_handle();
    I am using nrf52840 dongle.
    regards
    shailesh
  • Hi Shailesh,
    According to this softdevice specification, peripheral Id 30-> NVMC is a restricted peripheral when the softdevice is enabled. That means that it is not allowed to access NVMC registers directly from the application as those registered are inside access protected areas. And you can see in the implementation of nrf_nvmc_write_bytes that it is accessing NVMC registers directly, hence the memory fault. This post might help.
    -Amanda H.
  • Hi Amanda,
    In that case, it should also raise memory fault when I am running nrf_nvmc_write_bytes function, just after flash_page_init(), but it didn't raise any fault.
    Fault is raised only, when i call nrf_nvmc_write_bytes function, after advertising_start() function in the example.
    regards
    Shailesh
  • Hi Shailesh,
    According to this softdevice specification, peripheral Id 30-> NVMC is a restricted peripheral when the softdevice is enabled. Therefore, it only happened to the nrf_nvmc_write_bytes function which is after your ble_stack_init().
    -Amanda H.
  • Hi Amanda,
    My main purpose is solved in writing data into Flash memory and sending it as advertising data.
    Yesterday I come to know that the error which I was getting while debugging is due to the time taken to check the variable value and not related to coding.
    It depends where I had added a breakpoint and how much time it takes to check and resume the execution of code.
    if I take more time, then the error NRF_FAULT_ID_SD_ASSERT is raised.
    You may close this ticket.
    regards
    Shailesh
