connect to the nRF52840-DK with the STM32F103 development board
Hi, recently I want to establish a connection between two development boards (STM32F103 + nRF52840-DK), that the STM32f103 board can create the data and send it to the nRF52840-DK, the openwsn has been ported to the nRF52840-DK. I want to combine development boards and Component wireless sensor networks. But I find that the nRF52840-DK has only one usart port pin(reference datasheet), If there has the other UARTport I don't find, please correct me. So I want to use other communication protocols (like I2C and SPI, etc). But I am not familiar with 52840 programming, I hope I can provide some help.
  • kyh-ly said:
    I want to know how to specify the specific configuration of the UART1.
    Depending on what you would like to configure, it is either done in sdk_config or during the initialization.
    kyh-ly said:
    I always configure the UART0 and the UART1 doesn't work.Which files should I modify.
    The UART instance is configured in your sdk_config file, and the global instance should be initialized at the beginning of your main file.
    What is your UART configurations in sdk_config?
    Karl
  • Same as sdk_config.h provided in the UART example.
    //UARTE configure
    #ifndef NRFX_UARTE_ENABLED
    #define NRFX_UARTE_ENABLED 1
    // <o> NRFX_UARTE0_ENABLED - Enable UARTE0 instance
    #ifndef NRFX_UARTE0_ENABLED
    #define NRFX_UARTE0_ENABLED 0
    // <o> NRFX_UARTE1_ENABLED - Enable UARTE1 instance
    #ifndef NRFX_UARTE1_ENABLED
    #define NRFX_UARTE1_ENABLED 0
    //NRFX_UART_ENABLED - nrfx_uart - UART peripheral driver
    #ifndef NRFX_UART_ENABLED
    #define NRFX_UART_ENABLED 1
    // <o> NRFX_UART0_ENABLED - Enable UART0 instance
    #ifndef NRFX_UART0_ENABLED
    #define NRFX_UART0_ENABLED 0
    // <e> UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver - legacy layer
    #ifndef UART_ENABLED
    #define UART_ENABLED 1
    // <e> UART0_ENABLED - Enable UART0 instance
    #ifndef UART0_ENABLED
    #define UART0_ENABLED 1
    // <q> UART0_CONFIG_USE_EASY_DMA - Default setting for using EasyDMA
    #ifndef UART0_CONFIG_USE_EASY_DMA
    #define UART0_CONFIG_USE_EASY_DMA 1
    // </e>
    // <e> UART1_ENABLED - Enable UART1 instance
    #ifndef UART1_ENABLED
    #define UART1_ENABLED 0
  • Can there have a complete using uart0 and uart1 transmission example? It's difficult for me to work for it. And I also find I can not use two UARTs(UART1 and UART0) at the same time.By configurating APP_UART_DRIVER_INSTANCE 0/1, I can use UART0/UART1 respectively.
    From the sdk_config you shared - which is the same as the UART example's - it is apparent that you are only enabling UART0, and not UART1.
    This is the reason why you are not able to use UART1.
    Please define UART1_ENABLED to 1, and see if you then are able to create a UART1 instance in your application.
    Please be advised that when you are using the legacy UART ( instead of nrfx_uarte ) the CPU will need to be involved in each transfer. Instead, I recommend that you use the nrfx_uarte driver, which uses the easyDMA feature.
    Which SDK version are you working with?
    Karl
