compiler warning: pointer from integer without a cast
Would appreciate some understanding of a compiler warning. Developing for nRF52832 using SDK 15.3.0 plus S112.
This code compiles without warning:
ret_code_t err_code;
err_code = nrfx_ppi_channel_assign(chan_0, nrfx_gpiote_in_event_addr_get(COMPARATOR_PIN),nrfx_timer_task_address_get(&m_timer1,NRF_TIMER_TASK_START));
Then I switch from nrfx to sd calls:
err_code = sd_ppi_channel_assign(chan_0, nrfx_gpiote_in_event_addr_get(COMPARATOR_PIN),nrfx_timer_task_address_get(&m_timer1,NRF_TIMER_TASK_START));
and the following warnings:
passing argument 2 of 'sd_ppi_channel_assign' makes pointer from integer without a cast [-Wint-conversion]
passing argument 3 of 'sd_ppi_channel_assign' makes pointer from integer without a cast [-Wint-conversion]
All seems to work, but would appreciate understanding the warnings.
Many thanks,
Tim
