Up to and including `v10.4.0`, `nrfjprog` correctly implements support for runtime `LD_LIBRARY_PATH`:
~/test$ # unpack directories ~/test$ tar -xf nRFCommandLineTools1040Linuxamd64tar.gz ~/test$ tar -xf nRF-Command-Line-Tools_10_4_0_Linux-amd64.tar.gz ~/test$ tar -xf JLink_Linux_V650b_x86_64.tgz ~/test$ mv nrfjprog nrfjprog_10_4_0 ~/test$ # expected failure: no way to locate JLink libraries ~/test$ nrfjprog_10_4_0/nrfjprog --version ERROR: JLinkARM DLL not found. Please reinstall latest JLinkARM. ~/test$ # expected success: library path provided explicitly ~/test$ LD_LIBRARY_PATH=$(realpath ./JLink_Linux_V650b_x86_64) nrfjprog_10_4_0/nrfjprog --version nrfjprog version: 10.4.0 JLinkARM.dll version: 6.50b
Starting with `v10.5.0` this is broken, and `nrfjprog` expects JLink libraries to be only at `/opt/SEGGER/JLink`:
~/test$ # unpack directories ~/test$ tar -xf nRFCommandLineTools1050Linuxamd64tar.gz ~/test$ tar -xf nRF-Command-Line-Tools_10_5_0_Linux-amd64.tar.gz ~/test$ tar -xf JLink_Linux_V654c_x86_64.tgz ~/test$ mv nrfjprog nrfjprog_10_5_0 ~/test$ # expected failure: no path JLink library ~/test$ nrfjprog_10_5_0/nrfjprog --version ERROR: JLinkARM DLL not found. Please reinstall latest JLinkARM. ~/test$ # BUG: executable IGNORES provided LD_LIBRARY_PATH ~/test$ LD_LIBRARY_PATH=$(realpath JLink_Linux_V654c_x86_64) nrfjprog_10_5_0/nrfjprog --version ERROR: JLinkARM DLL not found. Please reinstall latest JLinkARM. ~/test$ # BUG: it is UNACCEPTABLE to assume/force a fixed filesystem path ~/test$ sudo mkdir -p /opt/SEGGER ~/test$ sudo ln -s $(realpath JLink_Linux_V654c_x86_64) /opt/SEGGER/JLink ~/test$ nrfjprog_10_5_0/nrfjprog --version nrfjprog version: 10.5.0 JLinkARM.dll version: 6.50b
It is unacceptable to hardcode `/opt/SEGGER/JLink`.
Please revert to the behavior of `v10.4.0` (and previous) and correctly use the system linker RPATH resolution, which respects `LD_LIBRARY_PATH`.
