I'm trying to mimic a fully functional zigbee color light bulb using the nRF52840 dongle.
Starting with the NRF5 Zigbee example light_bulb (examples/zigbee/light_control/), I began familiarizing with the code using EmStudio as recommended.
After flashing the build HEX (nRF connect -> Programmer) to the nRF52840 dongle, I was able to control the nRF52840 dongle using a 3rd party zigbee controller: great!
The next step would be to add the different missing parameters, starting with hue parameter, to make the light_bulb a color_light_bulb. This is where I am reaching out for support.
The closest example code I found to use as a starting point is the ble_zigbee_dynamic_color_light_bulb_thingy (examples/multiprotocol/experiemental/).
I tried to salvage some of its code back into the light_bulb ones, including the "zb_ha_dimmable_color_light.h" and "zigbee_color_light.h" and adapting on the go without success.
Unfortunately, the gap from light_bulb to ble_zigbee_dynamic_color_light_bulb_thingy is too complicated for my current skill level.
I am adding the code below, where I am at now.
Am I going in the right direction? Any tips?
Thanks!
* Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup zigbee_examples_light_bulb main.c
* @ingroup zigbee_examples
* @brief Dimmable light sample (HA profile)
#include "sdk_config.h"
#include "zboss_api.h"
#include "zboss_api_addons.h"
#include "zb_mem_config_med.h"
#include "zb_ha_dimmable_color_light.h"
#include "zb_error_handler.h"
#include "zb_nrf52_internal.h"
#include "zigbee_helpers.h"
#include "zigbee_color_light.h"
#include "bsp.h"
#include "boards.h"
#include "app_pwm.h"
#include "app_timer.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define MAX_CHILDREN 10 /**< The maximum amount of connected devices. Setting this value to 0 disables association to this device. */
#define IEEE_CHANNEL_MASK 0x07fff800U /**< Scan only one, predefined channel to find the coordinator.(1l << ZIGBEE_CHANNEL) */
#define HA_COLOR_LIGHT_ENDPOINT 10 /**< Device endpoint, used to receive light controlling commands. */
#define ERASE_PERSISTENT_CONFIG ZB_FALSE /**< Do not erase NVRAM to save the network parameters after device reboot or power-off. */
#define BULB_PWM_NAME PWM1 /**< PWM instance used to drive dimmable light bulb. */
#define BULB_PWM_TIMER 2 /**< Timer number used by PWM. */
/* Basic cluster attributes initial values. */
#define BULB_INIT_BASIC_APP_VERSION 01 /**< Version of the application software (1 byte). */
#define BULB_INIT_BASIC_STACK_VERSION 10 /**< Version of the implementation of the Zigbee stack (1 byte). */
#define BULB_INIT_BASIC_HW_VERSION 11 /**< Version of the hardware of the device (1 byte). */
#define BULB_INIT_BASIC_MANUF_NAME "Nordic" /**< Manufacturer name (32 bytes). */
#define BULB_INIT_BASIC_MODEL_ID "Dimable_Light_v0.1" /**< Model number assigned by manufacturer (32-bytes long string). */
#define BULB_INIT_BASIC_DATE_CODE "20180416" /**< First 8 bytes specify the date of manufacturer of the device in ISO 8601 format (YYYYMMDD). The rest (8 bytes) are manufacturer specific. */
#define BULB_INIT_BASIC_POWER_SOURCE ZB_ZCL_BASIC_POWER_SOURCE_DC_SOURCE /**< Type of power sources available for the device. For possible values see section 3.2.2.2.8 of ZCL specification. */
#define BULB_INIT_BASIC_LOCATION_DESC "Office desk" /**< Describes the physical location of the device (16 bytes). May be modified during commisioning process. */
#define BULB_INIT_BASIC_PH_ENV ZB_ZCL_BASIC_ENV_UNSPECIFIED /**< Describes the type of physical environment. For possible values see section 3.2.2.2.10 of ZCL specification. */
#ifdef BOARD_PCA10059 /**< If it is Dongle */
#define IDENTIFY_MODE_BSP_EVT BSP_EVENT_KEY_0 /**< Button event used to enter the Bulb into the Identify mode. */
#define ZIGBEE_NETWORK_STATE_LED BSP_BOARD_LED_0 /**< LED indicating that light switch successfully joind Zigbee network. */
#else
#define IDENTIFY_MODE_BSP_EVT BSP_EVENT_KEY_3 /**< Button event used to enter the Bulb into the Identify mode. */
#define ZIGBEE_NETWORK_STATE_LED BSP_BOARD_LED_2 /**< LED indicating that light switch successfully joind Zigbee network. */
#define BULB_LED BSP_BOARD_LED_3 /**< LED immitaing dimmable light bulb. */
#if !defined ZB_ROUTER_ROLE
#error Define ZB_ROUTER_ROLE to compile light bulb (Router) source code.
/* Declare context variable and cluster attribute list for first endpoint */
zb_color_light_ctx_t m_color_light_ctx_1;
ZB_DECLARE_COLOR_CONTROL_CLUSTER_ATTR_LIST(m_color_light_ctx_1,
m_color_light_clusters_1);
/* Declare two endpoints for color controllable and dimmable light bulbs */
ZB_ZCL_DECLARE_COLOR_DIMMABLE_LIGHT_EP(m_color_light_ep_1,
HA_COLOR_LIGHT_ENDPOINT,
/* Declare context for endpoints */
ZBOSS_DECLARE_DEVICE_CTX_1_EP(m_color_light_ctx,
m_color_light_ep_1);
APP_PWM_INSTANCE(BULB_PWM_NAME, BULB_PWM_TIMER);
//static bulb_device_ctx_t m_dev_ctx;
/**@brief Function for initializing the application timer.
static void timer_init(void)
uint32_t error_code = app_timer_init();
APP_ERROR_CHECK(error_code);
static void log_init(void)
/**@brief Sets brightness of on-board LED
* @param[in] brightness_level Brightness level, allowed values 0 ... 255, 0 - turn off, 255 - full brightness
static void light_bulb_onboard_set_brightness(zb_uint8_t brightness_level)
app_pwm_duty_t app_pwm_duty;
/* Scale level value: APP_PWM uses 0-100 scale, but Zigbee level control cluster uses values from 0 up to 255. */
app_pwm_duty = (brightness_level * 100U) / 255U;
/* Set the duty cycle - keep trying until PWM is ready. */
while (app_pwm_channel_duty_set(&BULB_PWM_NAME, 0, app_pwm_duty) == NRF_ERROR_BUSY)
/**@brief Sets brightness of bulb luminous executive element
static void light_bulb_set_brightness(zb_uint8_t brightness_level)
light_bulb_onboard_set_brightness(brightness_level);
/**@brief Function for setting the light bulb brightness.
* @param[in] new_level Light bulb brightness value.
static void level_control_set_value(zb_uint16_t new_level)
NRF_LOG_INFO("Set level value: %i", new_level);
ZB_ZCL_SET_ATTRIBUTE(HA_COLOR_LIGHT_ENDPOINT,
ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL,
ZB_ZCL_CLUSTER_SERVER_ROLE,
ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID,
(zb_uint8_t *)&new_level,
ZB_FALSE);
/* According to the table 7.3 of Home Automation Profile Specification v 1.2 rev 29, chapter 7.1.3. */
if (new_level == 0)
zb_uint8_t value = ZB_FALSE;
ZB_ZCL_CLUSTER_ID_ON_OFF,
ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID,
&value,
ZB_FALSE);
zb_uint8_t value = ZB_TRUE;
&value,
ZB_FALSE);
light_bulb_set_brightness(new_level);
/**@brief Function for setting the light bulb color.
* @param[in] new_level Light bulb color hue value.
static void color_control_set_value(zb_uint16_t new_level)
NRF_LOG_INFO("Set color hue value: %i", new_level);
ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_HUE_ID,
ZB_FALSE);
if (new_level == 0)
&value,
ZB_FALSE);
&value,
ZB_FALSE);
//light_bulb_set_brightness(new_level); //need to call func to change LED
/**@brief Function for turning ON/OFF the light bulb.
* @param[in] on Boolean light bulb state.
static void on_off_set_value(zb_bool_t on)
NRF_LOG_INFO("Set ON/OFF value: %i", on);
(zb_uint8_t *)&on,
ZB_FALSE);
if (on)
level_control_set_value(m_color_light_ctx_1.level_control_attr.current_level);
light_bulb_set_brightness(0U);
/**@brief Callback for button events.
* @param[in] evt Incoming event from the BSP subsystem.
static void buttons_handler(bsp_event_t evt)
zb_ret_t zb_err_code;
switch(evt)
case IDENTIFY_MODE_BSP_EVT:
/* Check if endpoint is in identifying mode, if not put desired endpoint in identifying mode. */
if (m_color_light_ctx_1.identify_attr.identify_time == ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE)
NRF_LOG_INFO("Bulb put in identifying mode");
zb_err_code = zb_bdb_finding_binding_target(HA_COLOR_LIGHT_ENDPOINT);
ZB_ERROR_CHECK(zb_err_code);
NRF_LOG_INFO("Cancel F&B target procedure");
zb_bdb_finding_binding_target_cancel();
NRF_LOG_INFO("Unhandled BSP Event received: %d", evt);
/**@brief Function for initializing LEDs and a single PWM channel.
static void leds_buttons_init(void)
ret_code_t err_code;
app_pwm_config_t pwm_cfg = APP_PWM_DEFAULT_CONFIG_1CH(5000L, bsp_board_led_idx_to_pin(BULB_LED));
/* Initialize all LEDs and buttons. */
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, buttons_handler);
/* By default the bsp_init attaches BSP_KEY_EVENTS_{0-4} to the PUSH events of the corresponding buttons. */
/* Initialize PWM running on timer 1 in order to control dimmable light bulb. */
err_code = app_pwm_init(&BULB_PWM_NAME, &pwm_cfg, NULL);
app_pwm_enable(&BULB_PWM_NAME);
while (app_pwm_channel_duty_set(&BULB_PWM_NAME, 0, 99) == NRF_ERROR_BUSY)
/**@brief Function for initializing all clusters attributes.
static void bulb_clusters_attr_init(void)
/* Basic cluster attributes data */
m_color_light_ctx_1.basic_attr.zcl_version = ZB_ZCL_VERSION;
m_color_light_ctx_1.basic_attr.app_version = BULB_INIT_BASIC_APP_VERSION;
m_color_light_ctx_1.basic_attr.stack_version = BULB_INIT_BASIC_STACK_VERSION;
m_color_light_ctx_1.basic_attr.hw_version = BULB_INIT_BASIC_HW_VERSION;
/* Use ZB_ZCL_SET_STRING_VAL to set strings, because the first byte should
* contain string length without trailing zero.
* For example "test" string wil be encoded as:
* [(0x4), 't', 'e', 's', 't']
ZB_ZCL_SET_STRING_VAL(m_color_light_ctx_1.basic_attr.mf_name,
BULB_INIT_BASIC_MANUF_NAME,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MANUF_NAME));
ZB_ZCL_SET_STRING_VAL(m_color_light_ctx_1.basic_attr.model_id,
BULB_INIT_BASIC_MODEL_ID,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MODEL_ID));
ZB_ZCL_SET_STRING_VAL(m_color_light_ctx_1.basic_attr.date_code,
BULB_INIT_BASIC_DATE_CODE,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_DATE_CODE));
m_color_light_ctx_1.basic_attr.power_source = BULB_INIT_BASIC_POWER_SOURCE;
ZB_ZCL_SET_STRING_VAL(m_color_light_ctx_1.basic_attr.location_id,
BULB_INIT_BASIC_LOCATION_DESC,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_LOCATION_DESC));
m_color_light_ctx_1.basic_attr.ph_env = BULB_INIT_BASIC_PH_ENV;
/* Identify cluster attributes data */
m_color_light_ctx_1.identify_attr.identify_time = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
/* On/Off cluster attributes data */
m_color_light_ctx_1.on_off_attr.on_off = (zb_bool_t)ZB_ZCL_ON_OFF_IS_ON;
m_color_light_ctx_1.level_control_attr.current_level = ZB_ZCL_LEVEL_CONTROL_LEVEL_MAX_VALUE;
m_color_light_ctx_1.level_control_attr.remaining_time = ZB_ZCL_LEVEL_CONTROL_REMAINING_TIME_DEFAULT_VALUE;
(zb_uint8_t *)&m_color_light_ctx_1.on_off_attr.on_off,
ZB_FALSE);
(zb_uint8_t *)&m_color_light_ctx_1.level_control_attr.current_level,
ZB_FALSE);
/**@brief Function which tries to sleep down the MCU
* Function which sleeps the MCU on the non-sleepy End Devices to optimize the power saving.
* The weak definition inside the OSIF layer provides some minimal working template
zb_void_t zb_osif_go_idle(zb_void_t)
//TODO: implement your own logic if needed
zb_osif_wait_for_event();
/**@brief Callback function for handling ZCL commands.
* @param[in] bufid Reference to Zigbee stack buffer used to pass received data.
static zb_void_t zcl_device_cb(zb_bufid_t bufid)
zb_uint8_t cluster_id;
zb_uint8_t attr_id;
zb_zcl_device_callback_param_t * p_device_cb_param = ZB_BUF_GET_PARAM(bufid, zb_zcl_device_callback_param_t);
NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
/* Set default response value. */
p_device_cb_param->status = RET_OK;
switch (p_device_cb_param->device_cb_id)
case ZB_ZCL_LEVEL_CONTROL_SET_VALUE_CB_ID:
NRF_LOG_INFO("Level control setting to %d", p_device_cb_param->cb_param.level_control_set_value_param.new_value);
level_control_set_value(p_device_cb_param->cb_param.level_control_set_value_param.new_value);
case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
attr_id = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
if (cluster_id == ZB_ZCL_CLUSTER_ID_ON_OFF)
uint8_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data8;
NRF_LOG_INFO("on/off attribute setting to %hd", value);
if (attr_id == ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID)
on_off_set_value((zb_bool_t) value);
else if (cluster_id == ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL)
uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
NRF_LOG_INFO("level control attribute setting to %hd", value);
if (attr_id == ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID)
level_control_set_value(value);
else if (cluster_id == ZB_ZCL_CLUSTER_ID_COLOR_CONTROL)
NRF_LOG_INFO("color control attribute setting to %hd", value);
if (attr_id == ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_HUE_ID)
color_control_set_value(value);
/* Other clusters can be processed here */
NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
p_device_cb_param->status = RET_ERROR;
NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
/**@brief Zigbee stack event handler.
* @param[in] bufid Reference to the Zigbee stack buffer used to pass signal.
void zboss_signal_handler(zb_bufid_t bufid)
/* Update network status LED */
zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
/* No application-specific behavior is required. Call default signal handler. */
ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
if (bufid)
zb_buf_free(bufid);
/**@brief Function for application main entry.
zb_ieee_addr_t ieee_addr;
/* Initialize timer, logging system and GPIOs. */
timer_init();
log_init();
leds_buttons_init();
/* Set Zigbee stack logging level and traffic dump subsystem. */
ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
ZB_SET_TRAF_DUMP_OFF();
/* Initialize Zigbee stack. */
ZB_INIT("led_bulb");
/* Set device address to the value read from FICR registers. */
zb_osif_get_ieee_eui64(ieee_addr);
zb_set_long_address(ieee_addr);
/* Set static long IEEE address. */
zb_set_network_router_role(IEEE_CHANNEL_MASK);
zb_set_max_children(MAX_CHILDREN);
zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
/* Initialize application context structure. */
UNUSED_RETURN_VALUE(ZB_MEMSET(&m_color_light_ctx_1, 0, sizeof(m_color_light_ctx_1)));
/* Register callback for handling ZCL commands. */
ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
/* Register dimmer switch device context (endpoints). */
ZB_AF_REGISTER_DEVICE_CTX(&m_color_light_ctx_1); //warning here during build
bulb_clusters_attr_init();
/** Start Zigbee Stack. */
zb_err_code = zboss_start_no_autostart();
while(1)
zboss_main_loop_iteration();
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
