BLE mesh and FOTA upgrade
I am working with nRF Connect SDK using an nRF52840 DK. And I want to realise both BLE mesh and FOTA upgrade. FOTA upgrade example SMP Server Sample works properly for Bluetooth Low Energy (without any mesh). And now I want to integrate this FOTA upgrade into BLE mesh application. Please, tell me, how can I do it in the best way?
I had some attempts to realise it, however I faced some difficulties. I don't know how to stop mesh advertisement, which started by bt_mesh_prov_enable, and run ordinary BLE advertising by bt_le_adv_start. bt_le_adv_stop and bt_mesh_prov_disable didn't stop mesh advertisement, since calling bt_le_adv_start function after them returned EALREADY error code. As I think, I could merely set a flag to upgrade (after pressing a button or some command) and reboot microcontroller, and depending on this flag run the FOTA upgrade sample. But I think that there's a more straightforward way to realise this functionality. Can you explain to me how to merge BLE mesh example and FOTA upgrade properly?
  • I tried the proposed solutions. But unfortunately, they also don't work and it outputs the same errors and even some others.
    I wrote a simplified example, which switches between BLE mesh and usual BLE, to demonstrate my problem. I built it both with nRF Connect SDK v1.3.0 and master branch. The example is consisted of BLE mesh network, running initially, and pressing a button 1 on an nRF52840 DK you can stop BLE mesh and start usual BLE and vice versa.
    #include <zephyr.h>
    #include <device.h>
    #include <drivers/gpio.h>
    #include <sys/__assert.h>
    #include <string.h>
    #include <bluetooth/bluetooth.h>
    #include <bluetooth/conn.h>
    #include <bluetooth/gatt.h>
    #include <bluetooth/mesh/models.h>
    #include <bluetooth/mesh/dk_prov.h>
    #include <dk_buttons_and_leds.h>
    #include "model_handler.h"
    #define LOG_LEVEL LOG_LEVEL_DBG
    #include <logging/log.h>
    LOG_MODULE_REGISTER(my_ble_sample);
    #define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
    static const struct bt_data ad[] = {
        BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
        BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    typedef enum
        MODE_BLE_MESH     = 0x00,
        MODE_NOT_BLE_MESH = 0x01,
        NUMBER_OF_BLE_MODES
    } ble_mode_t;
    static struct k_delayed_work change_ble_mode_work;
    static void button_pressed(uint32_t button_state, uint32_t has_changed);
    static void change_ble_mode(struct k_work *work);
    static void connected(struct bt_conn *conn, uint8_t err);
    static void disconnected(struct bt_conn *conn, uint8_t reason);
    static void start_ble(void);
    static void stop_ble(void);
    static void start_ble_mesh(void);
    static void stop_ble_mesh();
    static void bt_ready(int err);
        if (has_changed & DK_BTN1_MSK) {  /* Check a particular button whether its state has changed */
            if ((button_state & DK_BTN1_MSK) != 0) {  /* The button is pressed */
                k_delayed_work_submit(&change_ble_mode_work, K_NO_WAIT);
                return;
        static ble_mode_t current_ble_mode = MODE_BLE_MESH;
        switch(current_ble_mode) {
            case MODE_BLE_MESH:
                LOG_DBG("Change mode from MODE_BLE_MESH to MODE_NOT_BLE_MESH.");
                stop_ble_mesh();
                start_ble();
            case MODE_NOT_BLE_MESH:
                LOG_DBG("Change mode from MODE_NOT_BLE_MESH to MODE_BLE_MESH.");
                stop_ble();
                start_ble_mesh();
        current_ble_mode = (current_ble_mode + 1) % NUMBER_OF_BLE_MODES;
        if (err) {
            LOG_ERR("Connection failed (err 0x%02x)", err);
        } else {
            LOG_INF("Connected");
        LOG_INF("Disconnected (reason 0x%02x)", reason);
        start_ble();
    static struct bt_conn_cb conn_callbacks = {
        .connected = connected,
        .disconnected = disconnected,
        int err;
        err = bt_le_adv_stop();
        if (err) {
            LOG_ERR("Failed to stop advertising (err %d)", err);
        } else {
            LOG_INF("Stop advertising");
        err = bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), NULL, 0);
        if (err) {
            LOG_ERR("Failed to start advertising (err %d)", err);
            return;
        } else {
            LOG_INF("Start advertising");
        bt_conn_cb_register(&conn_callbacks);
        int err;
        bt_conn_cb_register(NULL);
        if (err) {
        } else {
        int err;
        if (bt_mesh_is_provisioned()) {
            err = bt_mesh_resume();
            if (err) {
                LOG_ERR("Failed to resume BLE mesh (err %d)", err);
            } else {
                LOG_INF("Resume BLE mesh");
        } else {
            err = bt_mesh_prov_enable(BT_MESH_PROV_ADV | BT_MESH_PROV_GATT);
            if (err) {
                LOG_ERR("Failed to enable BLE mesh provisioning (err %d)", err);
            } else {
                LOG_INF("Enable BLE mesh provisioning");
        int err;
            err = bt_mesh_suspend();
            if (err) {
                LOG_ERR("Failed to suspend BLE mesh (err %d)", err);
            } else {
                LOG_INF("Suspend BLE mesh");
        } else {
            err = bt_mesh_prov_disable(BT_MESH_PROV_ADV | BT_MESH_PROV_GATT);
            if (err) {
                LOG_ERR("Failed to disable BLE mesh provisioning (err %d)", err);
            } else {
                LOG_INF("Disable BLE mesh provisioning");
        if (err) {
            LOG_ERR("Bluetooth init failed (err %d).", err);
            return;
        } else {
            LOG_INF("Bluetooth initialized.");
        err = bt_mesh_init(bt_mesh_dk_prov_init(), model_handler_init());
        if (err) {
            LOG_ERR("Initializing mesh failed (err %d)\n", err);
            return;
        } else {
            LOG_INF("Initialize BLE mesh");
        if (IS_ENABLED(CONFIG_SETTINGS)) {
            settings_load();
        /* This will be a no-op if settings_load() loaded provisioning info */
        if (err) {
        } else {
        k_delayed_work_init(&change_ble_mode_work, change_ble_mode);
    void main(void)
        int err;
        err = dk_leds_init();
        if (err) {
            LOG_ERR("LEDs init error %d", err);
            return;
        err = dk_buttons_init(button_pressed);
        if (err) {
            LOG_ERR("Buttons init error %d", err);
            return;
        err = bt_enable(bt_ready);
        if (err) {
            return;
    /** Configuration server definition */
    static struct bt_mesh_cfg_srv cfg_srv = {
        .relay = IS_ENABLED(CONFIG_BT_MESH_RELAY),
        .beacon = BT_MESH_BEACON_ENABLED,
        .frnd = IS_ENABLED(CONFIG_BT_MESH_FRIEND),
        .gatt_proxy = IS_ENABLED(CONFIG_BT_MESH_GATT_PROXY),
        .default_ttl = 7,
        /* 3 transmissions with 20ms interval */
        .net_transmit = BT_MESH_TRANSMIT(2, 20),
        .relay_retransmit = BT_MESH_TRANSMIT(2, 20),
    /* Set up a repeating delayed work to blink the DK's LEDs when attention is
     * requested.
    static struct k_delayed_work attention_blink_work;
    static void attention_blink(struct k_work *work)
        static int idx;
        const uint8_t pattern[] = {
            BIT(0) | BIT(1),
            BIT(1) | BIT(2),
            BIT(2) | BIT(3),
            BIT(3) | BIT(0),
        dk_set_leds(pattern[idx++ % ARRAY_SIZE(pattern)]);
        k_delayed_work_submit(&attention_blink_work, K_MSEC(30));
    static void attention_on(struct bt_mesh_model *mod)
        k_delayed_work_submit(&attention_blink_work, K_NO_WAIT);
    static void attention_off(struct bt_mesh_model *mod)
        k_delayed_work_cancel(&attention_blink_work);
        dk_set_leds(DK_NO_LEDS_MSK);
    static const struct bt_mesh_health_srv_cb health_srv_cb = {
        .attn_on = attention_on,
        .attn_off = attention_off,
    static struct bt_mesh_health_srv health_srv = {
        .cb = &health_srv_cb,
    BT_MESH_HEALTH_PUB_DEFINE(health_pub, 0);
    static struct bt_mesh_elem elements[] = {
        BT_MESH_ELEM(1,
            BT_MESH_MODEL_LIST(BT_MESH_MODEL_CFG_SRV(&cfg_srv),
                               BT_MESH_MODEL_HEALTH_SRV(&health_srv, &health_pub)),
            BT_MESH_MODEL_NONE),
    static const struct bt_mesh_comp comp = {
        .cid = CONFIG_BT_COMPANY_ID,
        .elem = elements,
        .elem_count = ARRAY_SIZE(elements),
    const struct bt_mesh_comp *model_handler_init(void)
        k_delayed_work_init(&attention_blink_work, attention_blink);
        return &comp;
    And you can find the whole project here:
    example.zip
    Run the nRF52840 DK.
    Let's consider the first case when BLE mesh node is not provisioned.
    *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
    [00:00:00.003,143] <inf> mcuboot: Starting bootloader
    [00:00:00.009,552] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.019,805] <inf> mcuboot: Boot source: none
    [00:00:00.025,421] <inf> mcuboot: Swap type: none
    [00:00:00.378,479] <inf> mcuboot: Bootloader chainload address offset: 0xc000
    [00:00:00.386,291] <inf> mcuboot: Jumping to the first image slot
    [00:00:00.002,899] <inf> fs_nvs: 2 Sectors of 4096 bytes
    [00:00:00.002,899] <inf> fs_nvs: alloc wra: 0, ff0
    [00:00:00.002,929] <inf> fs_nvs: data wra: 0, 0
    [00:00:00.005,706] <inf> bt_hci_core: No ID address. App must call settings_load()
    [00:00:00.005,706] <inf> my_ble_sample: Bluetooth initialized.
    [00:00:00.005,767] <inf> my_ble_sample: Initialize BLE mesh
    [00:00:00.021,392] <inf> my_ble_sample: Enable BLE mesh provisioning
    Initially, everything seems fine, BLE mesh started. You can provision the node using the nRF Mesh mobile app. And you can connect and disconnect.
    [00:01:03.898,437] <inf> bt_mesh_main: Primary Element: 0x0002
    [00:01:11.455,322] <wrn> bt_mesh_transport: No matching TX context for ack
    Okay, the next step is that you disconnect from the node and press a button 1 to change a BLE mode. You can see that node is suspended, but advertising hasn't started.
    [00:01:31.023,345] <dbg> my_ble_sample.change_ble_mode: Change mode from MODE_BLE_MESH to MODE_NOT_BLE_MESH.
    [00:01:31.023,620] <inf> my_ble_sample: Suspend BLE mesh
    [00:01:31.023,834] <inf> my_ble_sample: Stop advertising
    [00:01:31.023,986] <err> my_ble_sample: Failed to start advertising (err -22)
    You press the button 1 again to get it back to BLE mesh mode.
    [00:03:02.516,021] <dbg> my_ble_sample.change_ble_mode: Change mode from MODE_NOT_BLE_MESH to MODE_BLE_MESH.
    [00:03:02.516,021] <inf> my_ble_sample: Stop advertising
    [00:03:02.517,089] <inf> my_ble_sample: Resume BLE mesh
    Everything has worked without any errors. So, now you try to connect to this BLE mesh node from the nRF Mesh mobile app (Android).
    In the case of a master branch, I have such assertion and fatal error:
    ASSERTION FAIL [client] @ WEST_TOPDIR/zephyr/subsys/bluetooth/mesh/proxy.c:750
            No client for connection
    [00:00:54.936,340] <err> os: r0/a1:  0x00000004  r1/a2:  0x000002ee  r2/a3:  0x200012d0
    [00:00:54.936,370] <err> os: r3/a4:  0x00000002 r12/ip:  0x6f697463 r14/lr:  0x000286d1
    [00:00:54.936,370] <err> os:  xpsr:  0x41000000
    [00:00:54.936,370] <err> os: Faulting instruction address (r15/pc): 0x0003d368
    [00:00:54.936,370] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    [00:00:54.936,401] <err> os: Current thread: 0x20001b58 (unknown)
    [00:00:55.052,429] <err> fatal_error: Resetting system
    In the case of v1.3.0, I just can't connect to the node. It tried to connect the first time, but without any result and after it the node is not scannable from the app.
    But if try to connect to the node from the nRF Connect for Mobile (Android), then it connects fine without fatal error and rebooting. But it generates another error permanently:
    [00:00:30.454,193] <wrn> bt_mesh_proxy: Failed to advertise using Network ID (err -12)
    Another way, start from the beginning. You don't provision the node at all and it's unprovisioned. And after flashing and running the node, you merely press the button 1 to switch to normal BLE.
    Initial output is the same:
    [00:00:00.019,836] <inf> mcuboot: Boot source: none
    [00:00:00.025,451] <inf> mcuboot: Swap type: none
    [00:00:00.378,936] <inf> mcuboot: Bootloader chainload address offset: 0xc000
    [00:00:00.386,779] <inf> mcuboot: Jumping to the first image slot
    [00:00:00.002,899] <inf> fs_nvs: data wra: 0, 0
    [00:00:00.005,676] <inf> bt_hci_core: No ID address. App must call settings_load()
    [00:00:00.005,676] <inf> my_ble_sample: Bluetooth initialized.
    [00:00:00.005,737] <inf> my_ble_sample: Initialize BLE mesh
    [00:00:00.021,331] <inf> my_ble_sample: Enable BLE mesh provisioning
    You press the button 1:
    [00:01:41.167,907] <dbg> my_ble_sample.change_ble_mode: Change mode from MODE_BLE_MESH to MODE_NOT_BLE_MESH.
    [00:01:41.168,212] <inf> my_ble_sample: Disable BLE mesh provisioning
    [00:01:41.168,548] <wrn> bt_hci_core: opcode 0x200a status 0x0c
    [00:01:41.168,579] <err> bt_mesh_proxy: Failed to stop advertising (err -5)
    [00:01:41.168,609] <inf> my_ble_sample: Stop advertising
    [00:01:41.168,792] <err> my_ble_sample: Failed to start advertising (err -22)
    You can see errors, which I mentioned in my previous messages. And BLE advertisement doesn't work.
    After it you press the button 1 again to get it back to BLE mesh mode:
    [00:03:02.380,554] <dbg> my_ble_sample.change_ble_mode: Change mode from MODE_NOT_BLE_MESH to MODE_BLE_MESH.
    [00:03:02.380,554] <inf> my_ble_sample: Stop advertising
    [00:03:02.381,256] <inf> my_ble_sample: Enable BLE mesh provisioning
    And you try to add the node in the nRF Mesh mobile app (Android).
    In the case of the master branch, I have such assertion and fatal error:
    ASSERTION FAIL [client] @ WEST_TOPDIR/zephyr/subsys/bluetooth/mesh/proxy.c:631
    [00:00:47.184,997] <err> os: r0/a1:  0x00000004  r1/a2:  0x00000277  r2/a3:  0x200012d0
    [00:00:47.184,997] <err> os: r3/a4:  0x00000002 r12/ip:  0x6f697463 r14/lr:  0x00028671
    [00:00:47.185,028] <err> os:  xpsr:  0x41000000
    [00:00:47.185,028] <err> os: Faulting instruction address (r15/pc): 0x0003d368
    [00:00:47.185,028] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    [00:00:47.185,058] <err> os: Current thread: 0x20001b58 (unknown)
    [00:00:47.321,014] <err> fatal_error: Resetting system
    And in the case of v1.3.0, the nRF Mesh mobile app is trying to "connect" to the node for a while and stops without any result. And the node becomes not scannable from the app also.
    I sincerely ask you to provide at least a small workable example of switching between BLE mesh and usual BLE. As you can see from my logs, switching between BLE mesh and usual BLE produces various errors. Maybe you know how to overcome them.
    And please, give a bit more detailed answer to allow me to reproduce your idea. I am so eagerly awaiting to realise my BLE mesh and OTA DFU.
  • Hi Mttrinh!
    Do you have any suggestions on how to cope with described problems? I need to turn BLE mesh off and initiate FOTA over Bluetooth Low Energy. And I need to have an ability to switch back to BLE mesh in the case of absence of any upgrade. I thought that it's a routine task, which has to be already implemented. However, there're so many troubles. Can you specify the root of errors, which I listed earlier to you?
    Sorry for the late response.
    I have forwarded this to our team to have a look at. I will update you when I get a response from the team.
  • Response from the team:
    Looks like his crash comes from this call in ble_stop(): bt_conn_cb_register(NULL);
    NULL is not a valid parameter for this function. As far as I know, you can't unregister the conn_cb, and you definitely shouldn't register the same handler multiple times.
    Instead, he should register the handler in bt_ready().
    Other than this, what he's doing looks correct. We will try test this internally.
  • Thank you for your response!
    I don't know why I decided to put NULL as an argument, it seems that I did it reading about bt_conn_auth_cb_register() function. Many thanks for these notes. I fixed everything.
    Also, I've found another error. I called this function bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), NULL, 0);  which included BT_LE_ADV_OPT_USE_NAME in advertising parameters, whereas "ad" argument also contained device name. So I had to choose between using a setting device name explicitly in "ad" structure and calling bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), NULL, 0); and calling bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), NULL, 0); where "ad" structure doesn't contain the device name.
    It seems that now I have the only error, which I described before also. bt_le_adv_stop() returns success, but at the same time there're errors in logs:
    [00:00:35.429,229] <wrn> bt_hci_core: opcode 0x200a status 0x0c
    [00:00:35.429,260] <err> bt_mesh_proxy: Failed to stop advertising (err -5)
