SPIM3 reads fail when SoftDevice enabled
I am developing a product that uses an external flash chip and we are using SPIM3 at 32 MHz. In addition we have been attempting to utilize the SoftDevice in order to offer some BLE functionality. But after enabling the SoftDevice (nrf_sdh_enable_request) the communication to the flash chip fails. The most basic example is trying to read the manufacturer id. To do this there is a transfer of 1 command byte(0x9F) and 3 dummy bytes in which the ID is received (0xEF4018). There is no problem reading the flash with the SPIM at full speed normally but when I change the #defines to include the SoftDevice code and re-compile and run the project the read comes back with all zeroes. All the nrf function calls during setup and read return normal error codes (NRF_SUCCESS) it is only the received data that is missing.
We successfully use SPIM1 for other SPI operations for other peripherals, for instance we have an IO expander connected to SPIM1 and as far as I can tell that is not affected.
I am honestly stumped as to what the SD enable has to do with the SPIM transfer. Any help is appreciated.
Some of the relevant code follows, please let me know if I should provide any additional snippets.
static const nrfx_spim_t fastspim = NRFX_SPIM_INSTANCE(FASTSPIM_INSTANCE);
uint32_t
initFastSPIM(void* p_context)
// Init the 32 MHz Fast SPI Master. The SPIM port structure might not be initialized yet.
// Returns an NRF error code, good is NRF_SUCCESS.
nrfx_spim_config_t spim_config = NRFX_SPIM_DEFAULT_CONFIG;
spim_config.mosi_pin = 17;
spim_config.miso_pin = 19;
spim_config.sck_pin = 15;
spim_config.ss_pin = NRFX_SPIM_PIN_NOT_USED;
spim_config.frequency = NRF_SPIM_FREQ_32M;
ret_code_t err_code = nrfx_spim_init(&fastspim, &spim_config, spim_event_handler, p_context);
return err_code;
void
queryFlashID(uint8_t* rx)
// Read 3 ID bytes from the flash into rx
// For W25Q128FV, expected result is EF 40 18
uint8_t tx[4];
memset(tx, 0, sizeof(tx));
tx[0] = W25_JEDEC_ID; // request manufacturing id
nrf_gpio_pin_set(PINNUM_nCSF0); // ensure Flash 0 is not selected
nrf_gpio_pin_set(PINNUM_nCSF1); // ensure Flash 1 is not selected
nrf_gpio_pin_clear(PINNUM_nCSF0); // select Flash 0
nrfx_spim_xfer_desc_t desc = {
.p_tx_buffer = tx,
.tx_length = 4,
.p_rx_buffer = rx,
.rx_length = 4
uint32_t ret;
spim_done = false;
ret = nrfx_spim_xfer(&fastspim, &desc, 0);
APP_ERROR_CHECK(ret);
 while (!spim_done) {
__WFE();
//rx buffer is then read and compared against expected
The MOSI/MISO/SCLK pins are configured like so:
nrf_gpio_cfg_output(17);
nrf_gpio_cfg_input (19, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_output(15);
