Can't change ERASEPROTECT.DISABLE value
If I write a value to ERASEPROTECT.DISABLE -- which itself works, as I'm fully able to perform the mass erase by writing the same value using the debugger -- I can't seem to write a new value to the register during the same boot. It presumably isn't flash-based, since it needs to be written each boot. Is this specifically being prevented by the core? Is there a way to "reset" the value and write a new one, assuming ERASEPROTECT.LOCK hasn't been set?
