I connected MCUBoot and FOTA to my project. I checked that the download is working, but not stable. I saw in the documentation that you can enable the continuation of the firmware download after restarting the device.
I set the parameters:
CONFIG_SETTINGS=y CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS=y CONFIG_SETTINGS_RUNTIME=y CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
Initialized the file system to the internal flash memory:
FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(cstorage);
static struct fs_mount_t lfs_storage_mnt = {
.type = FS_LITTLEFS,
.fs_data = &cstorage,
.storage_dev = (void *)FLASH_AREA_ID(storage),
.mnt_point = "/settings",
err = fs_mount(&lfs_storage_mnt);
if (err != 0)
LOG_ERR("mounting littlefs error: [%d]\n", err);
However, the download continuation system does not work.
I started to study the source code of the program, I found that the settings of the loaded firmware are written correctly and read also correctly.
However, the function that loads them makes them empty (file dfu_target_mcuboot.c):
* @brief Function used by settings_load() to restore the flash_img variable.
* See the Zephyr documentation of the settings subsystem for more
* information.
static int settings_set(const char *key, size_t len_rd,
settings_read_cb read_cb, void *cb_arg)
if (!strcmp(key, FILE_FLASH_IMG)) {
size_t bytes_written = flash_img_bytes_written(&flash_img);
ssize_t len = read_cb(cb_arg, &bytes_written,
sizeof(bytes_written));
if (len != sizeof(bytes_written)) {
LOG_ERR("Can't read flash_img from storage");
return len;
return 0;
It turns out that the program loaded the bytes_written parameter correctly, but does not use it anywhere and just exits this function, and the firmware download starts from byte 0
Am I misunderstanding something or is it a library bug?
regards
