PA + LNA with BLE and Zigbee at the same time
We have been working with a coordinator and a router device based on nRF52840 with nRF5_SDK_for_Thread_and_Zigbee_v4.0.0_dc7186b
Both devices are Zigbee 3.0 and implement Install Codes.
On the Coordinator we have Zigbee and BLE turned on at the same time on a Fanstel BT840X with integrated PA/LNA
We tried several things:
1.When running this code, BLE seems to work but Zigbee does not seem to send Link Status messages among others
ret_code_t pa_lna_init(uint32_t gpio_pa_pin, uint32_t gpio_lna_pin)
    ble_opt_t opt;
    uint32_t gpiote_ch = NULL;
    ret_code_t err_code;
    nrf_gpio_cfg_output(APP_CPS_PIN);
    nrf_gpio_cfg_output(APP_CHL_PIN);
    nrf_gpio_pin_set(APP_CHL_PIN);
    nrf_gpio_pin_clear(APP_CPS_PIN); //enable
    //nrf_gpio_pin_set(APP_CPS_PIN); //bypass
    nrf_gpio_cfg_output(APP_PA_PIN);
    nrf_gpio_pin_clear(APP_PA_PIN); //
    nrf_gpio_cfg_output(APP_LNA_PIN);
    nrf_gpio_pin_clear(APP_LNA_PIN); //
    memset(&opt, 0, sizeof(ble_opt_t));
    if (!nrf_drv_gpiote_is_init())
      if(err_code != NRF_ERROR_INVALID_STATE)
    if(err_code != NRF_ERROR_MODULE_ALREADY_INITIALIZED)
    nrf_ppi_channel_t ppi_set_ch;
    nrf_ppi_channel_t ppi_clr_ch;
    err_code = nrf_drv_ppi_channel_alloc(&ppi_set_ch);
    err_code = nrf_drv_ppi_channel_alloc(&ppi_clr_ch);
    nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    if((gpio_pa_pin == NULL) && (gpio_lna_pin == NULL))
        err_code = NRF_ERROR_INVALID_PARAM;
    if(gpio_pa_pin != NULL)
        if(gpiote_ch == NULL)
            // nrf_drv_gpiote_out_uninit(gpio_pa_pin);
            err_code = nrf_drv_gpiote_out_init(gpio_pa_pin, &config);
            gpiote_ch = nrf_drv_gpiote_out_task_addr_get(gpio_pa_pin);
        // PA config
        opt.common_opt.pa_lna.pa_cfg.active_high = 1;   // Set the pin to be active high
        opt.common_opt.pa_lna.pa_cfg.enable      = 1;   // Enable toggling
        opt.common_opt.pa_lna.pa_cfg.gpio_pin    = gpio_pa_pin; // The GPIO pin to toggle tx
    if(gpio_lna_pin != NULL)
            // nrf_drv_gpiote_out_uninit(gpio_lna_pin);
            err_code = nrf_drv_gpiote_out_init(gpio_lna_pin, &config);
            gpiote_ch = nrf_drv_gpiote_out_task_addr_get(gpio_lna_pin);
        // LNA config
        opt.common_opt.pa_lna.lna_cfg.active_high  = 1; // Set the pin to be active high
        opt.common_opt.pa_lna.lna_cfg.enable       = 1; // Enable toggling
        opt.common_opt.pa_lna.lna_cfg.gpio_pin     = gpio_lna_pin;  // The GPIO pin to toggle rx
    // Common PA/LNA config
    opt.common_opt.pa_lna.gpiote_ch_id  = (gpiote_ch - NRF_GPIOTE_BASE) >> 2;   // GPIOTE channel used for radio pin toggling
    opt.common_opt.pa_lna.ppi_ch_id_clr = ppi_clr_ch;   // PPI channel used for radio pin clearing
    opt.common_opt.pa_lna.ppi_ch_id_set = ppi_set_ch;   // PPI channel used for radio pin setting
    err_code = sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt);
    // APP_ERROR_CHECK(err_code);
    return err_code;
2. When setting at sdk_config.h FEM_CONTROL_DEFAULT_ENABLE to 1 (and other FEM_CONTROL_DEFAULT_XXX for pins), BLE stops working...
So, we would like to know which is the right approach to get Zigbee and BLE working at the same time with PA/LNA
Santiago
  • I see. Just to try to pinpoint where the issue, so I know who to reach out to.
    Can you please test to not use any of the pins P0.05 - P0.10, just to ensure that you don't have any conflicts with the pins that are used by the UART by default (5-8), and not the NFC pins (9-10).
    Have you tried to analyze the FEM pins that you have connected to the front end module? Is there any data on the lines? If so, are these signals from the Zigbee or BLE? (try to disable one to check the other).
    BR,
    Edvin
  • Hi Edvin,
    Pins P0.05 to P0.010 are unused.
    We are currently setting
    FEM_CONTROL_DEFAULT_ENABLE 1
    FEM_CONTROL_DEFAULT_PA_PIN 17
    FEM_CONTROL_DEFAULT_LNA_PIN 19
    FEM_CONTROL_DEFAULT_PDN_PIN 11
    FEM_CONTROL_DEFAULT_MODE_PIN 8
    FEM_CONTROL_DEFAULT_ANTSEL_PIN 13
    FEM_CONTROL_DEFAULT_CSN_PIN 6
    PDN and ANTSEL pins are hardwired so we configured them to unused pins just in case.
    BLE does not seem to work with this configuration
    (signal detected by LightBlue is less than -90dB quite close to the hub)
    Thanks for your support
  • I am not sure I understand what you are doing in your first snippet, where you claim that only BLE is working.
    From your first reply to my questions, you say that BLE is not working either when you enable FEM. You maintain a connection in nRF Toolbox. Is the device advertising (BLE) at all? Or is the radio dead silent? Because if so, it would mean that there is either a HW or a software problem, but not necessarily related to the Zigbee stack at all.
  • Hi Edvin,
    BLE works properly with option 1 (calling function pa_lna_init). But in this case Zigbee does not work
    BLE stops working when using option 2 (setting FEM_CONTROL_XXX from sdk_config.h)
  • I think that pa_lna_init() and FEM_CONTROL_XXX have to be configured too at the same time to get BLE and Zigbee working, right?
    If so, I think that the problem is that in our case Zigbee does not seem to be managing the Frontend properly with the Fanstel Module BT840X.
    Is there any extra setting to use FEM_CONTROL_XXX with Zigbee and SoftDevice while running within a SoftDevice timeslot?
    Regards
