How to copy the light_switch demos external to SDK?
I am having difficulty copying the light_switch client and server demos outside of the SDK, what is the general procedure? I have manually deleted and re-inserted the files and cleaned up some of the project definition paths but this is not working, I have spent a lot of effort doing this and have not been successful.
We are using 'nrf5_SDK_for_Mesh_v4.2.0 ' for the 'nRF52832' on the 'light_switch\client' & 'light_switch\server' demos, are these demos possible to duplicate outside of the SDK?
    I'm a little bit confused by your two latest replies. Were you able to solve the issue? Or are you still having problems?
     I was never able to get this to work, I have put a lot of effort into this without success exercising and exploring all of the referenced suggestions.
    I think this comes to porting the CMakeLists.txt; how do you port a project externally from the SDK? I am available for whatever questions or help may be needed, let us know when you can! :)
    How did you change the pathing? I assume you are using Segger Embedded Studio?
    After opening your project in SES, go to the left panel -> Right-Click on your project and click "Options..." -> In the upper-left dropdown, choose "Common" -> Under "Code", click "Preprocessor" -> User Include Directories. Here you need to change everything so the pathing is pointing to your SDKs.
  • Yes, I had tried manually updating the preprocessor includes as you reference, this didn't work
    ... I got it! I followed the following procedure -
    1. Copy my "/nRF5_SDK_16.0.0" to "/nRF5_SDK_16.0.0_98a08e2"
    2. Make SDK_ROOT navigate there now
        SDK_LOC:    C:\Sw\Nordic\SDK\nRF5_SDK_16.0.0
        SDK_ROOT:  C:\Sw\Nordic\SDK\A\B\C\D
    3. Manually copy all source files listed into project
    4. Update include directories
        Code->Preproc->User Include Dirs manual listing (cut and paste a WHOLE bunch!)
    What... on review this comes from not porting CMakeLists.txt, is this correct? What is the general procedure then to reproduce this copy-paste & use for your demo applications? This was surprising, I did not expect this to take so long!
    Let me know when available, looking forward to closing this one for use later
    Sorry for the late reply.
    To make this quicker, you can open your project file(.emProject file) in a text editor. Then use "find and replace"(ctrl + h) to replace the same text strings to the correct pathing.
    What do you mean by "cut and paste a whole bunch"? You only need to change the includes for the Mesh SDK. The pathing to your normal SDK should been fixed by the SDK_ROOT macro.
