After nrf52382 is written into the firmware program, the test runs OK. After it is placed for a period of time, it is checked again. It is found that it is not running. Use the JLINK tool jflash to read the data. Why is this
Yes, there's no reaction at all. I can't connect
It was encountered on the customized board; it took a long time to place, and there was no power when it was found out; the code modification was relatively large, and 0.1% of the boards had this problem, with more than 20 boards.
Sounds like it could be a board-issue then. If the chip does not get power, it will not do anything useful.
Did you manage to recover the failing boards? If so, how did you do that?
Have you examined the failing boards closely, to make sure there is no shorts, etc.?
Find the board, re brush the program, run well
