NRF52832 SDK 17 NUS LESC problem
Hi.
NRF52832 is used as central for connecting with phones as peripheral.
NUS service is used. Lesc is used too.
SDK 17
SoftDevice S132 V7.0.1
I have sometimes crash of application.
I suppose it is crash of softdevice.
there aren't any logs in that time.
Application is just restarting in random times (every 1 - 15 minutes).
Breakpoint on NVIC_SystemReset() doesn't catches too.
Size of stack was increased. So i think perhaps sd has crashed in that time.
How can i find cause of that?
Thanks for any suggestions.
Another strange thing is that after resetting chip in this cases
resolving of private resolved address doesn't work (im_address_resolve).
(it is usually actual for one phone from two. phone1 is connecting successfully, another phone has not resolved address.)
  • My advice to you is to try to debug the application.
    Ok. I see.
    It is solved. I wrote above. External reset signal on the reset pin was the cause.
    Disconnections on old phone is another problem.
    Do you see any disconnect reason on the nRF?
    app: BLE_GAP_EVT_DISCONNECTED: 1 , reason=0x13
    And the next question:
    Could you advice a variant of self testing for factory testing.
    I mean testing RF part, accuracy of quartz. Perhaps do you have application note for that?
     I am no HW expert. I suggest you create a new ticket for this. That way, you don't have to listen to me trying to explain something to you that a colleague told me, which I don't understand myself.
    Does that mean that the disconnect issue still remains? If so, we are back to the disconnect reason 13. I just checked, and actually, if you disconnect from the nRF yourself, you will receive a disconnect reason 0x16 (BLE_HCI_LOCAL_HOST_TERMINATED_CONNECTION), and not 0x13 (BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION).
    So if you see disconnected reason 0x13 on the nRF, it means that the phone decided to disconnect. Perhaps you can try to connect to it with nRF Connect for Android/iOS, and see if it disconnects, and if so, what the reason (should be printed in the log in nRF Connect for iOS/android).
    BR,
    Edvin
  • hi
    ok
    0x13  is used in app code too.
    The issue can be closed now.
    we'll try to debug phone application later.
