Connect one pheripheral to two central
Hi
how to  connect  one peripheral to two central and after connection established sent the data to both central?
I am using nrf52, soft device 132 .
i am able to make connection and send data from one peripheral to one central using ble_app_uart(peripheral),ble_app_uart_c(central ) code.
  • In multi peripheral example there is no implementation for sending data from peripheral to central but in ble_app_uart there is direct function for sending data..
    I am able to make connection between one peripheral and two central using ble_app_uart code(peripheral) by making below changes in code .
    ble_app_uart(main.c) - :
    static void on_connected(const ble_gap_evt_t * const p_gap_evt)
        ret_code_t  err_code;
        uint32_t    periph_link_cnt = ble_conn_state_peripheral_conn_count(); // Number of peripheral links.
        NRF_LOG_INFO("Connection with link 0x%x established.", p_gap_evt->conn_handle);
        // Assign connection handle to available instance of QWR module.
        for (uint32_t i = 0; i < NRF_SDH_BLE_PERIPHERAL_LINK_COUNT; i++)
            //if (m_qwrs[i].conn_handle == BLE_CONN_HANDLE_INVALID)
               // err_code = nrf_ble_qwr_conn_handle_assign(&m_qwrs[i], p_gap_evt->conn_handle);
     bsp_board_led_on(CONNECTED_LED);
       if (periph_link_cnt == NRF_SDH_BLE_PERIPHERAL_LINK_COUNT)
           bsp_board_led_off(ADVERTISING_LED);
            // Continue advertising. More connections can be established because the maximum link count has not been reached.
            advertising_start();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                   on_connected(&p_ble_evt->evt.gap_evt);
                //NRF_LOG_INFO("Connected");
                //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                //APP_ERROR_CHECK(err_code);
                //m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
                //err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle);
                //break;
    Can you please suggest is this right way or not?After making connection i am not able sent data between peripheral to central .How to sent data?
  • Q.What i am trying to implement?
    A. i am making a ble remote(peripheral) and there is two device (central).I want, when i press button on peripheral(remote) then it should reflect on both central(camera device/speaker device like volume up/down and many more) as per requirement.
    I'm not sure what the issue is. This is exactly what is done in the example I linked in my previous comment. Please try the example.
    regards
    Jared
