Multichannel use of ADC in NRF51822
I want to measure voltages at all 8 channels but when I am enabling all channels its sending the values once only and after that its not sending anything, my requirement is i don't want to use any handler,i am using polling method simultaneously to sample ADC,please suggest if any code available or any support message for the same.
  • I have BLE 400 Waveshare board i am connecting to AN0 pin and AN1 pin and giving 3.3v on that and also for checking connecting it to ground using 10 bit ADC which can give o/p as 2^10 i.e. upto 1024 certainly with or without i/p its giving same value, there is no formula i am using right now i just want some o/p but its giving the o/p as mentioned above queries.
  • Please verify that you are using the correct pins on the Waveshare board. Could you share with me the pinout of the waveshare board you are using, and how you are testing it?
    I assume you then have changed the code I provided earlier, to reflect this?
    Please share with me the code you are currently running.
    I do not know what you mean by "o/p", but I agree that reading values in the 500 range using the 10-bit ADC configuration sounds strange.
    Karl
  • Output (O/p) is nothing but value i am getting after reading ADC, I just want ADC to give me some values according to my input to AN0 or AN1 pin still i am not getting any values.Please suggest me if any other ways if available to read multichannel ADC values or tell me if it is hardware restriction
    You are not giving me a lot to work with here, since you are not answering my questions.
    Please, take a look at what I asked about in my previous reply, and answer the questions I wrote you.
    I require more information in order to help you resolve this issue.
    I assure you there are no hardware restrictions on reading multiple channels of the ADC. Do not worry, the issue here is not hardware restrictions.
    Karl
  • static nrf_drv_adc_channel_t m_channel_config_0 = NRF_DRV_ADC_DEFAULT_CHANNEL(NRF_ADC_CONFIG_INPUT_0);
    static nrf_drv_adc_channel_t m_channel_config_1 = NRF_DRV_ADC_DEFAULT_CHANNEL(NRF_ADC_CONFIG_INPUT_1);
    static  nrf_adc_value_t sample_channel_0 = 0;
    static  nrf_adc_value_t sample_channel_1 = 0;
    static void adc_init(void)
        ret_code_t err_code;
        nrf_drv_adc_config_t config = NRF_DRV_ADC_DEFAULT_CONFIG;
        err_code = nrf_drv_adc_init(&config, NULL);
    //Error Code:H1600
    void user_adc_init0(){
             nrf_drv_adc_sample_convert(&m_channel_config_0, &sample_channel_0);
             nrf_delay_ms(1000);
             printf("\r\n  0 :%d\r\n",sample_channel_0);
    //Error Code:H1700
    void user_adc_init1(){
          nrf_drv_adc_sample_convert(&m_channel_config_1, &sample_channel_1);
            printf("\r\n  1 : %d\r\n",sample_channel_1);
    adc_init();
    for (;;)
          printf("\r\n for Start!\r\n");
          user_adc_init0();
          nrf_delay_ms(100);
          user_adc_init1();
          nrf_delay_ms(100);
          nrf_delay_ms(2000);
          printf("\r\nADC fin!\r\n");
