Trying to build pc-ble-driver for a nRF52840 dongle project
I'm trying to build the pc-ble-driver (https://github.com/NordicSemiconductor/pc-ble-driver) to be able to use the nRF52840 as a receiver for a thermometer.  See https://devzone.nordicsemi.com/f/nordic-q-a/65516/using-nrf52840-dongle-as-receiver-client-for-onset-thermometer for details.
I have followed the instructions I think, but got an error at building the pc-ble-driver:  See output below.  I was on step 2 of the section "Compiling pc-ble-driver from source". To handle the part about "CMake Select the Visual Studio compiler to use according to this article: Build C/C++ code on the command line" I opened a Developer Command Prompt for VS2019 which was one of the suggestions.  I am on a Windows 10 machine running Visual Studio 2019.
Can somebody tell me what I'm doing wrong?
Andrew
Console Output
C:\Nordic\pc-ble-driver>cd build
C:\Nordic\pc-ble-driver\build>cmake -G Ninja ..
-- NRF_BLE_DRIVER_VERSION not specified, setting it to 0.0.0
-- Architecture not set, using native 64-bit toolchain.
CMake Error at test/CMakeLists.txt:11 (find_package):
Could not find a package configuration file provided by "spdlog" with any
of the following names:
spdlogConfig.cmake
spdlog-config.cmake
Add the installation prefix of "spdlog" to CMAKE_PREFIX_PATH or set
"spdlog_DIR" to a directory containing one of the above files. If "spdlog"
provides a separate development package or SDK, be sure it has been
installed.
See also "C:/Nordic/pc-ble-driver/build/CMakeFiles/CMakeOutput.log".
See also "C:/Nordic/pc-ble-driver/build/CMakeFiles/CMakeError.log".
  • I get the same output as Andrew from running....
    ">cmake -G Ninja .."
    and
    "vcpkg install asio catch2 spdlog"
    What's different from Installing dependencies on Windows, is that I had to download vcpkg to a different directory, otherwise the following would occur from running boostrap in C:\Windows\System32\vcpkg>
    C:\Windows\System32\vcpkg>.\bootstrap-vcpkg.bat
    Building vcpkg.exe ...
    MSBUILD : error MSB1009: Project file does not exist.
    Switch: C:\Windows\System32\vcpkg\toolsrc\dirs.proj
    C:\Windows\System32\vcpkg\scripts\bootstrap.ps1 : Building vcpkg.exe failed. Please ensure you have installed Visual
    Studio with the Desktop C++ workload and the Windows SDK for Desktop C++.
    At line:1 char:4
    + & {& 'C:\Windows\System32\vcpkg\scripts\bootstrap.ps1' }
    + CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,bootstrap.ps1
    Next step.. Then add the vcpkg location to the PATH and VCPKG_ROOT environment variable.
    And from there I added C:\Users\michael.larson\vcpkg to the user environment variable Path (NOT system variable!).  These are the only things that are different in my setup. Otherwise, again the output for
    and
    are the same as Andre.. Any help would be appreciated!!
