Incorrect sample order in high frequency ADC sampling + BLE transfer
Hello Guys,
I am running an application which is sampling 3 ADC channels at 50 MHz. I am using sample buffers of size 150 and PPI to generate a sample event every 20 microseconds. At lower sampler rates, the data position in the buffers is consistent. But as I go below a sample period of 100 microseconds, the buffer order is corrupted.
This seems to be a very common and important issue but there is really no clear cut instructions on how to fix the issue.
I have tried the tips provided here, but none of them seem to work.
        ret_code_t err_code;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        /* Get average battery value */
        uint16_t bat_total = 0;
        /* Create Bucket from ADC Data */
        sample_bucket_t* pbucket = malloc(sizeof(sample_bucket_t));
        if(pbucket == NULL) return;
        for(uint16_t i=0; i<SAMPLE_BUCKET_SIZE; i++){
          int16_t mic_val = p_event->data.done.p_buffer[i*3];
          int16_t acc_val = p_event->data.done.p_buffer[i*3+1];
          bat_total += p_event->data.done.p_buffer[i*3+2];
printf("%d\n", mic_val);
          pbucket->samples[i].data[0] = (uint8_t)(mic_val);
          pbucket->samples[i].data[1] = (uint8_t)((mic_val >> 8) & 0x0F) | ( (uint8_t)(acc_val) << 4 );
          pbucket->samples[i].data[2] = (uint8_t)(acc_val >> 4);
        battery_val = bat_total / SAMPLE_BUCKET_SIZE;
        /* Run Sampling FSM */
        switch(device_status.sampling_state){
          case SAMPLE_NONE:
            free(pbucket);
          case SAMPLE_POLLING:
            ring_buffer_add(buckets_before, pbucket);   /* Add bucket to buckets before buffer */
            /* Check if accel threshold is exceeded */
            uint16_t accel_val = bucket_acc_average(pbucket);
            //printf("%d\n", accel_val);
            if(accel_val > fusion_config.shot_detection_acc_threshold){
              //LOGI("Accelerometer threshold exceeded");
              device_status.sampling_state = SAMPLE_ACCEL_THRESHOLD;
              device_status.sampling_status.acc_exceed_time = global_ticks;
          case SAMPLE_ACCEL_THRESHOLD:
            /* Continue adding buckets to before_buffer even after accel threshold
              has been exceeded. */
            /* Check if threshold has been exceeded */;
            uint16_t audio_val = bucket_mic_average(pbucket);
            if(audio_val > fusion_config.shot_detection_aud_threshold){
              //LOGI("Shot Detected !");
              device_status.sampling_state = SAMPLE_SHOT_DETECTED;
            /* Check if time has been elapsed */
            else if(TIME_ELAPSED(device_status.sampling_status.acc_exceed_time, AUDIO_WAIT_TIMEOUT)){
              //LOGI("Audio Signal not detected ");
              device_status.sampling_state = SAMPLE_POLLING;
          case SAMPLE_SHOT_DETECTED:
            /* Add buckets to buckets_after ring buffer */
            //printf("%d\n", buckets_after->size);
            if(buckets_after->size < buckets_after->capacity){
              ring_buffer_add(buckets_after, pbucket);
            /* When bucket is full, create shot_data_t */
            else{
              free(pbucket);  /* free bucket or add to ring buffer */
              uint8_t shot_id = get_shot_count();
              //device_status.sampling_state = SAMPLE_SHOT_COOL_DOWN;
              //break;
              /* Create ble packets from bucket data */
              /* Iterate through all buckets in buckets before */
              while(buckets_before->size){
                sample_bucket_t* bucket = front(buckets_before);
                ble_packet_t* ble_packet = malloc(sizeof(ble_packet_t));
                //if(ble_packet == NULL) continue;
                ble_packet->buf[0] = shot_id;
                memcpy(ble_packet->buf+2,  &bucket->samples, 150);
                ble_packet->packet_length = 152;
                ble_add_to_queue(LOW_PRIORITY_PACKET, ble_packet);
                dequeue(buckets_before);
                free(bucket);
              /* Iterate through buckets_after */
              while(buckets_after->size){
                sample_bucket_t* bucket = front(buckets_after);
                dequeue(buckets_after);
                /* Add bucket to buckets before buffer so that next shot can use it */
                ring_buffer_add(buckets_before, bucket);
              /* Go To Cool Down Phase */
              //LOGD("SHOT_DETECTED -> SHOT_COOL_DOWN");
          case SAMPLE_SHOT_COOL_DOWN:
            free(pbucket);
            free(pbucket);
 * Initialize ADC (saadc)
 * Params:
 *  bool bat_only: Flag to determine if only Battery ADC should be enabled
 * Ret: None
static void init_adc(bool bat_only){
  nrf_saadc_channel_config_t channel_config_mic =
      NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(MIC_ADC);
  channel_config_mic.acq_time = NRF_SAADC_ACQTIME_3US;
  nrf_saadc_channel_config_t channel_config_acc =
      NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(ACC_ADC);
  channel_config_acc.acq_time = NRF_SAADC_ACQTIME_3US;
  nrf_saadc_channel_config_t channel_config_bat =
      NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BAT_ADC);
  channel_config_bat.acq_time = NRF_SAADC_ACQTIME_3US;
  nrf_drv_saadc_config_t saadc_config = {
    .resolution = NRF_SAADC_RESOLUTION_12BIT,
    .oversample = NRF_SAADC_OVERSAMPLE_DISABLED,
    .interrupt_priority = 2,
    .low_power_mode = false
  err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
  /* Initialize channels */
  err_code = nrf_drv_saadc_channel_init(0, &channel_config_mic);
  err_code = nrf_drv_saadc_channel_init(1, &channel_config_acc);
  err_code = nrf_drv_saadc_channel_init(BAT_CHANNEL, &channel_config_bat);
  /* Set buffers */
  err_code = nrf_drv_saadc_buffer_convert(buffer_pool[0], SAMPLES_IN_BUFFER);
  /* Initialize all buffers only when accel and microphone are being sampled */
  err_code = nrf_drv_saadc_buffer_convert(buffer_pool[1], SAMPLES_IN_BUFFER);
  APP_ERROR_CHECK(nrf_drv_ppi_init());
  err_code = nrf_drv_timer_init(&adc_timer, &timer_cfg, timer_handler);
  /* If only battery sampling is needed, use a lower sampling rate
   * All channels will be sampled on every iteration.
  uint32_t ticks;
  if(bat_only){
    ticks = nrf_drv_timer_ms_to_ticks(&adc_timer, ADC_BATT_SAMPLE_INTERVAL);
  else{
    ticks = nrf_drv_timer_us_to_ticks(&adc_timer, ADC_FULL_SAMPLE_INTERVAL);
  nrf_drv_timer_extended_compare(&adc_timer,
                                 NRF_TIMER_CC_CHANNEL0,
                                 ticks,
                                 NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                 false);
  uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&adc_timer,
        NRF_TIMER_CC_CHANNEL0);
  err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
  err_code = nrf_drv_ppi_channel_alloc(&ppi_channel2);
  err_code = nrf_drv_ppi_channel_assign(ppi_channel,
                                        timer_compare_event_addr,
                                        saadc_sample_task_addr);
  err_code = nrf_drv_ppi_channel_assign(ppi_channel2,
    nrf_saadc_event_address_get(NRF_SAADC_EVENT_END),
    nrf_saadc_task_address_get(NRF_SAADC_TASK_START)
  nrf_drv_timer_enable(&adc_timer);
  periph_status.adc_status = (bat_only) ? ADC_BATTERY_ONLY : ADC_FULL ;
 * Start ADC Sampling
 * Params: None
 * Ret: None
static void start_adc_sampling(void){
  APP_ERROR_CHECK(nrf_drv_ppi_channel_enable(ppi_channel));
  APP_ERROR_CHECK(nrf_drv_ppi_channel_enable(ppi_channel2));
The SAADC runs with priority level = 2, and there is not much else that interrupts it other than the softdevice. In the near future I will incoorporate a feature to send a BLE packet every 10 ms.
Please can you shed more light on how the solution 1 (Use PPI to trigger START task on an END event. This will avoid the delayed triggering og the START task due to a queued interrupt generated by the END event,) from the link above should be implemented. I have tried the implied implementation but this doesnt solve this problem.
I am using the latest nRF17.0.0 SDK so I am suprised this issue still persists after soo many years.
Please what is the best workaround for this?
Is a sample rate of 50 kHz achievable using CPU interrupts?
  • David said:
    The ADC never seems to start in a specific order. the buffer arrangement is different every time the program starts.
    What do you mean?
    The samples should always be in the format specified in EasyDMA. If they are not, and you're not using calibration, then there is a mismatch between when the START task is triggered and when the SAMPLE tasks are triggered.
    Can you share more of your code, at least what pertains to the SAADC operation?
  • #define SAMPLES_IN_BUFFER   3 * 50
            int16_t mic_val = p_event->data.done.p_buffer[1*3];
            int16_t acc_val = p_event->data.done.p_buffer[1*3+1];
            int16_t b_val = p_event->data.done.p_buffer[1*3+2];
            printf("%d %d %d\n", mic_val, acc_val, b_val);
     * Callback for Timer
     * Params: Timer Event type
     * Ret: None
    void timer_handler(nrf_timer_event_t event_type, void * p_context){
     * Params:
     * Ret: None
    static void init_adc(void){
      nrf_saadc_channel_config_t channel_config_mic = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(MIC_ADC);
      nrf_saadc_channel_config_t channel_config_acc = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(ACC_ADC);
      nrf_saadc_channel_config_t channel_config_bat = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BAT_ADC);
        .interrupt_priority = 5,
      APP_ERROR_CHECK(nrf_drv_saadc_init(&saadc_config, saadc_callback));
      APP_ERROR_CHECK(nrf_drv_saadc_channel_init(1, &channel_config_mic));
      APP_ERROR_CHECK(nrf_drv_saadc_channel_init(2, &channel_config_acc));
      APP_ERROR_CHECK(nrf_drv_saadc_channel_init(BAT_CHANNEL, &channel_config_bat));
      /* Set buffers */
      APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(buffer_pool[0], SAMPLES_IN_BUFFER));
      APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(buffer_pool[1], SAMPLES_IN_BUFFER));
      nrf_drv_timer_config_t timer_cfg  = NRF_DRV_TIMER_DEFAULT_CONFIG;
      timer_cfg.bit_width               = NRF_TIMER_BIT_WIDTH_32;
      APP_ERROR_CHECK(nrf_drv_timer_init(&adc_timer, &timer_cfg, timer_handler));
      uint32_t ticks = nrf_drv_timer_us_to_ticks(&adc_timer, ADC_FULL_SAMPLE_INTERVAL);
      nrf_drv_timer_extended_compare(&adc_timer, NRF_TIMER_CC_CHANNEL0, ticks,
          NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
      uint32_t timer_cmp_evt_addr   = nrf_drv_timer_compare_event_address_get(&adc_timer,
      uint32_t adc_sample_task_addr = nrf_drv_saadc_sample_task_get();
      // setup ppi channel so that timer compare event is triggering sample task in SAADC
      APP_ERROR_CHECK(nrf_drv_ppi_channel_alloc(&ppi_channel));
      APP_ERROR_CHECK(nrf_drv_ppi_channel_alloc(&ppi_channel2));
      APP_ERROR_CHECK(nrf_drv_ppi_channel_assign(ppi_channel, timer_cmp_evt_addr, adc_sample_task_addr));
      //nrf_saadc_task_trigger(NRF_SAADC_TASK_SAMPLE);
      nrf_drv_timer_clear(&adc_timer);
    I this is what my adc setup looks like. I call the init function once to startup the ADC.
    The END event is used to trigger the next start like we discussed above.
  • That looks alright, but how do you set the buffers following the STARTED event?
    Also, I suggest that you increase the buffer size significantly, as it will greatly reduce the number of interrupts that you need to service.
  • I assumed the nrf_saadc handles the setting of the buffer inside the driver. But it seems this is wrong. I guess I have to make changes to the saadc driver.  How should the buffer be set?
    Also my application needs to see the sampled data really often. What buffer size do you think will be sufficient?
  • I'm looking at the new SAADC driver v2 in sdk17 and it has this already implemented, including triggering the START task following an END event.
    See modules\nrfx\drivers\include\nrfx_saadc_v2.h and modules\nrfx\drivers\src\nrfx_saadc.c.
    nrfx_saadc_init
    nrfx_saadc_channels_config
    nrfx_saadc_advanced_mode_set, set start_on_end to 'true' in nrfx_saadc_adv_config_t, and supply an event handler to enable non-blocking operation.
    nrfx_saadc_mode_trigger
    nrfx_saadc_buffer_set(buffer1)
    nrfx_saadc_buffer_set(buffer2)
