I am working on nRF52840.
I want to add Device Information Service in ble_app_template. (as shown in the attached image its from another device)
How can I add?
Kindly suggest.
Thanks!
How can I add?
Kindly suggest.
Thanks!
When an error is generated, I recommend looking into the documentation for the functions API Reference, to see why the error was generated.
For example, in your case this error is caught in line 670, so you have to delve into where it came from.
In this case, the NRF_ERROR_DATA_SIZE is returned by ble_advdata_encode, an exempt from its API Reference reads:
| NRF_ERROR_DATA_SIZE | If the operation failed because not all the requested data could fit into the provided buffer or some encoded AD structure is too long and its length cannot be encoded with one octet. |
So, it seems you are trying to fit to much encoded data into a too small buffer.
Karl
So how can I fix it?
That depends, what / how much are you trying to put in your advertisements?
Could you share your code, so that I may see what you are sending to your ble_advertising_init function, and how you are initializing your advertising data?
I do not recommend just sharing screenshots of your code, it drastically reduces readability.
Please use the "Insert -> Code" option when sharing code on the forum.
Karl
Hi Karl Ylvisaker
I have attached the main.c, ble_cus.h, ble_cus.h and sdk_config.h. (Code+Files)
Do you require more? (Means complete project)
Main.c
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_template_main main.c
* @ingroup ble_sdk_app_template
* @brief Template project main file.
* This file contains a template for creating a new application. It has the code necessary to wakeup
* from button, advertise, get a connection restart advertising on disconnect and if no new
* connection created go back to system-off mode.
* It can easily be used as a starting point for creating a new application, the comments identified
* with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include <ble_dis.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "C:\Nordic\SDK\nRF5SDK17009d13099\nRF5_SDK_17.0.0_9d13099\examples\ble_peripheral\custom_ble_service_example\pca10056\s140\ses\ble_cus.h"
#define DEVICE_NAME "Nordic_Template" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
BLE_CUS_DEF(m_cus);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
* BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
{CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN }, /**< Universally unique service identifiers. */
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
// Create timers.
/* YOUR_JOB: Create any timers to be used by the application.
Below is an example of how to create a timer.
For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
one.
ret_code_t err_code;
err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
APP_ERROR_CHECK(err_code); */
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
/* YOUR_JOB: Use an appearance value matching the application's use case.
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
* YOUR_JOB implement a service handler function depending on the event the service you are using can generate
* @details This function will be called for all YY Service events which are passed to
* the application.
* @param[in] p_yy_service YY Service structure.
* @param[in] p_evt Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t * p_yy_service,
ble_yy_service_evt_t * p_evt)
switch (p_evt->evt_type)
case BLE_YY_NAME_EVT_WRITE:
APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
// No implementation needed.
/* YOUR_JOB: Add code to initialize the services used by the application.*/
ble_cus_init_t cus_init;
ble_dis_init_t dis_init;
// Initialize CUS Service init structure to zero.
memset(&cus_init, 0, sizeof(cus_init));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
err_code = ble_cus_init(&m_cus, &cus_init);
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
dis_init.dis_char_rd_sec = SEC_OPEN;
err_code = ble_dis_init(&dis_init);
ble_xxs_init_t xxs_init;
ble_yys_init_t yys_init;
// Initialize XXX Service.
memset(&xxs_init, 0, sizeof(xxs_init));
xxs_init.evt_handler = NULL;
xxs_init.is_xxx_notify_supported = true;
xxs_init.ble_xx_initial_value.level = 100;
err_code = ble_bas_init(&m_xxs, &xxs_init);
// Initialize YYY Service.
memset(&yys_init, 0, sizeof(yys_init));
yys_init.evt_handler = on_yys_evt;
yys_init.ble_yy_initial_value.counter = 0;
err_code = ble_yy_service_init(&yys_init, &yy_init);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void application_timers_start(void)
/* YOUR_JOB: Start your timers. below is an example of how to start a timer.
err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
// APP_ERROR_CHECK(err_code);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @param[in] event Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Template example started.");
application_timers_start();
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
/** @file
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "ble.h"
#include "fds.h"
BLE_CUS_DEF(m_cus);
// Create timers.
one.
* the application.
sleep_mode_enter();
} break;
switch (event)
sleep_mode_enter();
nrf_pwr_mgmt_run();
delete_bonds();
bool erase_bonds;
// Initialize.
log_init();
timers_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
// Enter main loop.
for (;;)
/* This code belongs in ble_cus.c*/
#include "sdk_common.h"
#include "ble_cus.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
/**@brief Function for initializing the Custom Service.
* @param[out] p_cus Custom Service structure. This structure will have to be supplied by
* the application. It will be initialized by this function, and will later
* be used to identify this particular service instance.
* @param[in] p_cus_init Information needed to initialize the service.
* @return NRF_SUCCESS on successful initialization of service, otherwise an error code.
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context);
if (p_cus == NULL || p_cus_init == NULL)
return NRF_ERROR_NULL;
uint32_t err_code;
ble_uuid_t ble_uuid;
// Initialize service structure
p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
// Add Custom Service UUID
ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid.type = p_cus->uuid_type;
ble_uuid.uuid = CUSTOM_SERVICE_UUID;
// Add the Custom Service
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
if (err_code != NRF_SUCCESS)
return err_code;
// Add Custom Value characteristic
return custom_value_char_add(p_cus, p_cus_init);
/**@brief Function for adding the Custom Value characteristic.
* @param[in] p_cus Custom Service structure.
* @return NRF_SUCCESS on success, otherwise an error code.
uint32_t err_code;
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_gatts_attr_md_t attr_md;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write = 1;
char_md.char_props.notify = 0;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = NULL;
char_md.p_sccd_md = NULL;
memset(&attr_md, 0, sizeof(attr_md));
attr_md.read_perm = p_cus_init->custom_value_char_attr_md.read_perm;
attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
/* This code belongs in custom_value_char_add() in ble_cus.c*/
ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint8_t);
err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
&attr_char_value,
&p_cus->custom_value_handles);
return err_code;
return NRF_SUCCESS;
/**@brief Function for handling the Connect event.
* @param[in] p_ble_evt Event received from the BLE stack.
void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
/**@brief Function for handling the Disconnect event.
void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
UNUSED_PARAMETER(p_ble_evt);
/**@brief Function for handling the Write event.
void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
// Check if the handle passed with the event matches the Custom Value Characteristic handle.
if (p_evt_write->handle == p_cus->custom_value_handles.value_handle)
NRF_LOG_INFO("Data Write");
nrf_gpio_pin_toggle(LED_4);
ble_cus_t * p_cus = (ble_cus_t *) p_context;
if (p_cus == NULL || p_ble_evt == NULL)
return;
on_connect(p_cus, p_ble_evt);
on_disconnect(p_cus, p_ble_evt);
case BLE_GATTS_EVT_WRITE:
on_write(p_cus, p_ble_evt);
Hi Karl Ylvisaker,
Here is the complete project.
Kindly check.
Thanks!
Project
