Using: Windows 10, nRF Connect v3.5.0, nrf v1.3.0, zephyr v2.3.0
I have a board based on the Thingy91 and the Asset Tracker application. I verified serial console output and that my LEDs work.
1. In the asset tracker folder, there is prj.conf and prj_thingy91_nrf9160ns.conf. Does SES read and parse both of these? If so, how does it know to load the second one? Or does it automatically pull in all .conf files in the project folder? Or are you supposed to overwrite prj.conf with it?
2. How do I disable the light sensor and environmental sensors? If I grep for CONFIG_LIGHT_SENSOR in the asset tracker folder, I see conditionals for it, but not the actual define anywhere:
CMakeLists.txt:43:add_subdirectory_ifdef(CONFIG_LIGHT_SENSOR src/light_sensor)
src/cloud_codec/cloud_codec.c:415:#if CONFIG_LIGHT_SENSOR
src/cloud_codec/cloud_codec.c:461:#endif /* CONFIG_LIGHT_SENSOR */
src/cloud_codec/cloud_codec.h:276:#if CONFIG_LIGHT_SENSOR
src/cloud_codec/cloud_codec.h:279:#endif /* CONFIG_LIGHT_SENSOR */
src/light_sensor/light_sensor.c:37:static char *ls_dev_name = CONFIG_LIGHT_SENSOR_DEV_NAME;
src/light_sensor/light_sensor.c:47:static u32_t data_send_interval_s = CONFIG_LIGHT_SENSOR_DATA_SEND_INTERVAL;
src/light_sensor/light_sensor.c:61: if (!IS_ENABLED(CONFIG_LIGHT_SENSOR)) {
src/main.c:188:#if CONFIG_LIGHT_SENSOR
src/main.c:190:#endif /* CONFIG_LIGHT_SENSOR */
src/main.c:898:#if defined(CONFIG_LIGHT_SENSOR)
src/main.c:1007:#if IS_ENABLED(CONFIG_LIGHT_SENSOR)
src/main.c:1161:#if defined(CONFIG_LIGHT_SENSOR)
src/main.c:1203:#endif /* CONFIG_LIGHT_SENSOR */
src/main.c:1638:#if CONFIG_LIGHT_SENSOR
src/main.c:1644:#endif /* CONFIG_LIGHT_SENSOR */
It doesn't show up in the boards/arm/thingy91_nrf9160/ folder either. What am I missing?
3. I also need to swap out the ADXL362 and ADXL372 for an LIS2DW12. I see that zephyr drivers exist for it, which is great, but is there a guide on how to add it and which parameters need to be listed in thingy91_nrf9160_common.dts (or elsewhere)?
