SES CMAKE ERROR
I have installed the latest SDK 1.3.0 using the Toolchain Manager.
I would now like to open nRF Connect SDK Projekt and get the follwoing error:
I have added the CXX environment variable, but it did not help Disappointed
  • Hi Didrik,
    I have changed the LWM2M_PEER_PORT to 5683 and now I can connect to Roberts server. Thank you for your help!
  • Hi Didrik,
    after some weeks of work with our own hardware radio connectivity issues, I am now back working on the software. We have bad LTE-M1 reception conditions here and are not able to connect to the network with our custom board. The hardware reasons are pretty clear and it work when we drive to another location.
    In order to design and test the remaining software I am using Segger Embedded Studio from the latest SDK 1.4.0.
    The problem is I can start the application and singlestep through part of our own code, when the LTE network connection process starts SES however crashes and will not reply to anything. I have to restart the computer to get it working again. I normally use Crossworks from Rowley which seems to be the origin of SES, but have never ever experienced so many problems and crashses as with SES. I have even turned of the VPN since I have problems with the SDK due to that before but it did not help.
    I dont know if this should be a new thread?
    Best regards
    Dirk
  • Hi, that sounds like a strange problem.
    But yes, I think it is best to create a new ticket for it.
