How to create a Makefile based project?
I am new to creating project from scratch.
I want to use nRF51802 module. From few support tickets i have come to know that  SDK version 12.3 and SoftDevice S130 version 2.0.x  are the compatible versions for nRF51802 module. Are these the latest combination for nRF51802? What should i use?
And i want to create a project which is IDE independent project, a Makefile project.
Can anyone please guide me how to create a makefile project for nRF51802 module?
Swetha.
  • Ok. Do you see any logs? Does it say anything? Try to define DEBUG in your preprocessor definitions, and put a breakpoint in the error handler. To make sure that you set the breakpoint the correct place, try adding APP_ERROR_CHECK(1); before advertising_start();
  • Edvan,
    I dont see any logs.. Since i am running the code in debug mode.
    I did what u said earlier... it came to app_error_handler() with error code as 1.
  • What was the line_num and file_name? Hover over the file name to see the path to the file. If you don't see it, then use:
    "nrfjprog --memrd 0x<filename memory address> --n 256". What does it say?
    And when you figure out what it says, check where this points to in your application, and what function that returned that value (err_code).
    BR,
    Edvin
  • Edvan,
    I think i'm not clear with my question.. Leave the earlier discussion.
    Currently i have kept my device in advertising mode and enabled tx rx characteristics on nus service.
    And established ble connection with nrf connect android application.
    Now when i try to send data from nrf connect application, i should get the data in nus_data_handler. But i am not getting in that handler. I kept a break point in that handler but it never comes there. But it comes to a switch case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST in on_ble_evt(). I hope you understood my question. Please see the code and help me where i'm doing wrong. I need to get data in nus_data_handler().
    I am sharing code of my main.c file and ble_nus.c file
     * Copyright (c) 2012 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(BLE_NUS)
    #include "ble_nus.h"
    #include "ble_srv_common.h"
    #define BLE_UUID_NUS_TX_CHARACTERISTIC 0x0002                      /**< The UUID of the TX Characteristic. */
    #define BLE_UUID_NUS_RX_CHARACTERISTIC 0x0003                      /**< The UUID of the RX Characteristic. */
    #define BLE_NUS_MAX_RX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN        /**< Maximum length of the RX Characteristic (in bytes). */
    #define BLE_NUS_MAX_TX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN        /**< Maximum length of the TX Characteristic (in bytes). */
    #define NUS_BASE_UUID                  {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}} /**< Used vendor specific UUID. */
    /**@brief Function for handling the @ref BLE_GAP_EVT_CONNECTED event from the S110 SoftDevice.
     * @param[in] p_nus     Nordic UART Service structure.
     * @param[in] p_ble_evt Pointer to the event received from BLE stack.
    static void on_connect(ble_nus_t * p_nus, ble_evt_t * p_ble_evt)
        p_nus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    /**@brief Function for handling the @ref BLE_GAP_EVT_DISCONNECTED event from the S110 SoftDevice.
    static void on_disconnect(ble_nus_t * p_nus, ble_evt_t * p_ble_evt)
        UNUSED_PARAMETER(p_ble_evt);
        p_nus->conn_handle = BLE_CONN_HANDLE_INVALID;
    /**@brief Function for handling the @ref BLE_GATTS_EVT_WRITE event from the S110 SoftDevice.
    static void on_write(ble_nus_t * p_nus, ble_evt_t * p_ble_evt)
        ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
        if (
            (p_evt_write->handle == p_nus->rx_handles.cccd_handle)
            (p_evt_write->len == 2)
            if (ble_srv_is_notification_enabled(p_evt_write->data))
                p_nus->is_notification_enabled = true;
                p_nus->is_notification_enabled = false;
        else if (
                 (p_evt_write->handle == p_nus->tx_handles.value_handle)
                 (p_nus->data_handler != NULL)
            p_nus->data_handler(p_nus, p_evt_write->data, p_evt_write->len);
            // Do Nothing. This event is not relevant for this service.
    /**@brief Function for adding RX characteristic.
     * @param[in] p_nus_init  Information needed to initialize the service.
     * @return NRF_SUCCESS on success, otherwise an error code.
    static uint32_t rx_char_add(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
        /**@snippet [Adding proprietary characteristic to S110 SoftDevice] */
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        memset(&cccd_md, 0, sizeof(cccd_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
        cccd_md.vloc = BLE_GATTS_VLOC_STACK;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.notify = 1;
    //    char_md.char_props.write  = 1;
    //    char_md.char_props.read  = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        ble_uuid.type = p_nus->uuid_type;
        ble_uuid.uuid = BLE_UUID_NUS_RX_CHARACTERISTIC;
        memset(&attr_md, 0, sizeof(attr_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
        attr_md.vloc    = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth = 1;
        attr_md.wr_auth = 1;
        attr_md.vlen    = 1;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = sizeof(uint8_t);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = BLE_NUS_MAX_RX_CHAR_LEN;
        return sd_ble_gatts_characteristic_add(p_nus->service_handle,
                                               &char_md,
                                               &attr_char_value,
                                               &p_nus->rx_handles);
    /**@brief Function for adding TX characteristic.
    static uint32_t tx_char_add(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
    //    char_md.char_props.notify = 1;
        char_md.char_props.write_wo_resp = 1;
        char_md.p_cccd_md                = NULL;
        ble_uuid.uuid = BLE_UUID_NUS_TX_CHARACTERISTIC;
        attr_md.vlen    = 1;
        attr_char_value.max_len   = BLE_NUS_MAX_TX_CHAR_LEN;
                                               &char_md,
                                               &attr_char_value,
                                               &p_nus->tx_handles);
    void ble_nus_on_ble_evt(ble_nus_t * p_nus, ble_evt_t * p_ble_evt)
        if ((p_nus == NULL) || (p_ble_evt == NULL))
            return;
            case BLE_GAP_EVT_CONNECTED:
                on_connect(p_nus, p_ble_evt);
                on_disconnect(p_nus, p_ble_evt);
            case BLE_GATTS_EVT_WRITE:
                on_write(p_nus, p_ble_evt);
                // No implementation needed.
    uint32_t ble_nus_init(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
        uint32_t      err_code;
        ble_uuid128_t nus_base_uuid = NUS_BASE_UUID;
        VERIFY_PARAM_NOT_NULL(p_nus);
        VERIFY_PARAM_NOT_NULL(p_nus_init);
        // Initialize the service structure.
        p_nus->data_handler            = p_nus_init->data_handler;
        /**@snippet [Adding proprietary Service to S110 SoftDevice] */
        // Add a custom base UUID.
        err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
        VERIFY_SUCCESS(err_code);
        ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
        // Add the service.
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                            &ble_uuid,
                                            &p_nus->service_handle);
        // Add the RX Characteristic.
        err_code = rx_char_add(p_nus, p_nus_init);
        // Add the TX Characteristic.
        err_code = tx_char_add(p_nus, p_nus_init);
        return NRF_SUCCESS;
    uint32_t ble_nus_string_send(ble_nus_t * p_nus, uint8_t * p_string, uint16_t length)
        ble_gatts_hvx_params_t hvx_params;
        if ((p_nus->conn_handle == BLE_CONN_HANDLE_INVALID) || (!p_nus->is_notification_enabled))
        if (length > BLE_NUS_MAX_DATA_LEN)
            return NRF_ERROR_INVALID_PARAM;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_nus->rx_handles.value_handle;
        hvx_params.p_data = p_string;
        hvx_params.p_len  = &length;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        return sd_ble_gatts_hvx(p_nus->conn_handle, &hvx_params);
    #endif // NRF_MODULE_ENABLED(BLE_NUS)
    Swetha.
    #include <stdbool.h>
    #include <stdint.h>
    #include "app_button.h"
    #include "nrf_delay.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "app_uart.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "nrf_queue.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log.h"
    #include "boards.h"
    #include "sdk_errors.h"
    #include "nrf_drv_gpiote.h"
    #define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
    #define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           1
    static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define DEVICE_NAME                     "Keybox2"                	               /**< Name of device. Will be included in the advertising data. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(10, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(1000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
    size_t               received_data_len = 0;
    #define MAX_PACKET_SIZE          512
    NRF_QUEUE_DEF(uint8_t, ble_nrf_queue, MAX_PACKET_SIZE, NRF_QUEUE_MODE_NO_OVERFLOW);
    /**@brief Function for the application's SoftDevice event handler.
     * @param[in] p_ble_evt SoftDevice event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t err_code;
                break; // BLE_GAP_EVT_CONNECTED
                break; // BLE_GAP_EVT_DISCONNECTED
                // Pairing not supported
                break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
                break; // BLE_GATTS_EVT_SYS_ATTR_MISSING
            case BLE_GATTC_EVT_TIMEOUT:
                break; // BLE_GATTC_EVT_TIMEOUT
            case BLE_GATTS_EVT_TIMEOUT:
                break; // BLE_GATTS_EVT_TIMEOUT
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
                break; // BLE_EVT_USER_MEM_REQUEST
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
    #if (NRF_SD_BLE_API_VERSION == 3)
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                           NRF_BLE_MAX_MTU_SIZE);
                break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
    /**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
     *        event handler.
     * @details This function is called from the SoftDevice event interrupt handler after a
     *          SoftDevice event has been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_nus_on_ble_evt(&m_nus, p_ble_evt);
        ble_advertising_on_ble_evt(p_ble_evt);
    //    bsp_btn_ble_on_ble_evt(p_ble_evt);
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    uint32_t handle_ble_data(uint8_t *p_data, size_t p_data_len)
       if((NULL == p_data) || (0 == p_data_len))
          return 0;
       nrf_queue_write(&ble_nrf_queue, p_data, p_data_len);
       received_data_len = p_data_len;
       return 0;
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_data   Data to be send to UART module.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    //    for (uint32_t i = 0; i < length; i++)
    //        while (app_uart_put(p_data[i]) != NRF_SUCCESS);
    //    while (app_uart_put('\r') != NRF_SUCCESS);
    //    while (app_uart_put('\n') != NRF_SUCCESS);
           handle_ble_data(p_data, length);
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    	uint32_t err_code;
    //    uint32_t err_code = bsp_indication_set(BSP_INDICATE_IDLE);
    //    APP_ERROR_CHECK(err_code);
        // Prepare wakeup buttons.
    //    err_code = bsp_btn_ble_sleep_mode_prepare();
    //    uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
    //            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ble_advdata_t          advdata;
        ble_advdata_t          scanrsp;
        ble_adv_modes_config_t options;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = false;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
        memset(&options, 0, sizeof(options));
        options.ble_adv_fast_enabled  = true;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
     * @brief Function for application main entry.
    	ret_code_t err_code;
        // Initialize.
    //    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    //    uart_init();
    //    buttons_leds_init(&erase_bonds);
        ble_stack_init();
        gap_params_init();
        services_init();
        advertising_init();
        conn_params_init();
    //    APP_ERROR_CHECK(1);
    //    printf("\r\nUART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    	for (;;)
  • So this means that you were able to set up your project in eclipse, then?
    If you have application specific questions, I think it is better that you start a new thread. This has nothing to do with the makefile based project, as the title of this issue suggests.
    To answer short:
    I don't know how you set up your service and characteristic, or what you do on your central when you receive the BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST event. That is not clear. It looks like you are trying to read a characteristic on the nRF from the central (a phone?). Write a detailed description in the new ticket how you set up the service and characteristics, and what you did to trigger the BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST event.
