Segger Embedded Studio: Debug and Release build configurations
I created two build configurations a Debug and a Release in SES IDE.
Build > Build Configurations...
I wanted to select the  DEBUG_OPTIMIZATIONS level for the Debug build configuration and the SPEED_OPTIMIZATIONS for the Release one.
In Project Explorer, select the top Solution then select the 'Debug' build Configuration
Project > Configure nRF Connect Project... > DEBUG_OPTIMIZATIONS > Configure > Save solution (if prompted)
Then in Project Explorer, select the top Solution then select the 'Release' build Configuration
Project > Configure nRF Connect Project... > SIZE_OPTIMIZATIONS > Configure > Save solution (if prompted)
However, when I go back and select the 'Debug' build configuration to view its optimisation setting I find
NOT DEBUG_OPTIMIZATIONS as expected.
It looks like whichever build configuration is set last overwrites the other one.
Can you please tell me what I am doing wrong.
Thank you.
Mohamed Belaroussi
  • I suggest to use Visual Studio Code instead of SES, I know that SES may "cache" some of the configuration unless you re-open the project in SES after doing modifications to prj conf files.
    Kenneth
  • Hi Kenneth,
    Thank you for your response but that is not the answer I was hoping for.
    Switching IDE at this critical time in the development phase of the project is not an option.
    I am aware of the "cache" problem SES suffers from so, I do reload the project after each mod to prj.conf.
    Can you please try to find out how I can build a debug and a release version of my project under SES. I would like to be able to achieve this using two project configuration files, prj_debug.conf and prj_release.conf.  Note, since I initially submitted this ticket I have moved to a new SES version,
    SEGGER Embedded Studio for ARM
    Release 5.60  Build 2021081102.47262
    Nordic Edition
    Windows x64
    © 2014-2021 SEGGER Microcontroller GmbH
    © 1997-2021 Rowley Associates Ltd.
    segger-as: version 2.11
    segger-cc: version 12.2.1
    segger-cc-ng: version 12.91.6
    segger-ld: version 4.12.1
    segger-rtl: version 2.22.0
    Thank you for your support.
    Kind regards
    Mohamed
  • Migrating is very easy:
    https://www.youtube.com/watch?v=ptJBEAOIm5w&list=PLx_tBuQ_KSqEt7NK-H7Lu78lT2OijwIMl&index=6
    That said, the description for SES should be as stated here (seems there are two different ways it can be done in SES if you see the Note also below the first suggestion): https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/gs_modifying.html?highlight=dconf_file#selecting-a-build-type-in-ses
    Kenneth
  • Creating solution HomeBeacon_v121+_sb.emProject
    C:/Zypher/v1.7.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf52833dk_nrf52833 -DBOARD_DIR=C:\Zypher\v1.7.0\zephyr\boards\arm\nrf52833dk_nrf52833 -BC:\Sandbox\HomeBeacon_v121+_sb\build_nrf52833dk_nrf52833_mcuboot_OTA_rel2 -SC:\Sandbox\HomeBeacon_v121+_sb -DNCS_TOOLCHAIN_VERSION=1.7.0 -DCONF_FILE=prj_release.conf -DDTC_OVERLAY_FILE=C:/Sandbox/HomeBeacon_v121+_sb/nrf52833dk_nrf52833.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\Zypher\v1.7.0\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
    -- Application: C:/Sandbox/HomeBeacon_v121+_sb
    -- Zephyr version: 2.6.99 (C:/Zypher/v1.7.0/zephyr), build: v2.6.99-ncs1
    -- Found Python3: C:/Zypher/v1.7.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
    -- Board: nrf52833dk_nrf52833
    -- Cache files will be written to: C:/Zypher/v1.7.0/zephyr/.cache
    -- Found dtc: C:/Zypher/v1.7.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/Zypher/v1.7.0/toolchain/opt)
    -- Found BOARD.dts: C:/Zypher/v1.7.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts
    -- Found devicetree overlay: C:/Sandbox/HomeBeacon_v121+_sb/nrf52833dk_nrf52833.overlay
    -- Generated zephyr.dts: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/zephyr/dts.cmake
    Parsing C:/Sandbox/HomeBeacon_v121+_sb/Kconfig
    Loaded configuration 'C:/Zypher/v1.7.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig'
    Merged configuration 'C:/Sandbox/HomeBeacon_v121+_sb/prj_debug.conf'
    Configuration saved to 'C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/zephyr/.config'
    Kconfig header saved to 'C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: C:/Zypher/v1.7.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
    -- Application: C:/Zypher/v1.7.0/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: C:/Zypher/v1.7.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/mcuboot/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/mcuboot/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/mcuboot/zephyr/dts.cmake
    Parsing C:/Zypher/v1.7.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Merged configuration 'C:/Sandbox/HomeBeacon_v121+_sb/cfg/mcuboot.conf'
    Merged configuration 'C:/Zypher/v1.7.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Configuration saved to 'C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/mcuboot/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Sandbox/HomeBeacon_v121+_sb/build_nrf52833dk_nrf52833_mcuboot_OTA_rel2/mcuboot
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    Dropping partition 'nvs_storage' since its size is 0.
    -- Configuring done
    -- Generating done
    Including boilerplate (Zephyr base): C:/Zypher/v1.7.0/zephyr/cmake/app/boilerplate.cmake
    -- Using NCS Toolchain 1.7.0 for building. (C:/Zypher/v1.7.0/toolchain/cmake)
    warning: UART_CONSOLE (defined at drivers/console/Kconfig:47) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n). See
    http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_UART_CONSOLE.html and/or look up
    UART_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: I2C_0 (defined at drivers/i2c/Kconfig.esp32:15) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: I2C_ESP32 (=n). See
    http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_I2C_0.html and/or look up I2C_0 in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    === child image mcuboot -  begin ===
    too.
    MCUBoot bootloader key file: C:/Zypher/v1.7.0/bootloader/mcuboot/root-rsa-2048.pem
    === child image mcuboot -  end ===
    CMake Warning at C:/Zypher/v1.7.0/nrf/modules/mcuboot/CMakeLists.txt:204 (message):
            --- WARNING: Using default MCUBoot key, it should not ---
            --- be used for production.                           ---
    Loading solution HomeBeacon_v121+_sb.emProject
    Loading solution build.emProject
    Mapping project information
    Mapping project zephyr/merged.hex
    Mapping project all
    Mapping project app/libapp.a
    Mapping project cmake_object_order_depends_target_app
    Mapping project zephyr/driver_validation_h_target
    Mapping project zephyr/CMakeFiles/driver_validation_h_target
    Mapping project zephyr/include/generated/driver-validation.h
    Mapping project zephyr/parse_syscalls_target
    Mapping project zephyr/CMakeFiles/parse_syscalls_target
    Mapping project zephyr/misc/generated/syscalls.json
    Mapping project C:/Zypher/v1.7.0/zephyr/include/dt-bindings/gpio/gpio.h
    Mapping project C:/Zypher/v1.7.0/zephyr/include/dt-bindings/i2c/i2c.h
    Mapping project zephyr/misc/generated/struct_tags.json
    Mapping project zephyr/kobj_types_h_target
    Mapping project zephyr/CMakeFiles/kobj_types_h_target
    Mapping project zephyr/include/generated/kobj-types-enum.h
    Mapping project zephyr/include/generated/otype-to-str.h
    Mapping project zephyr/include/generated/otype-to-size.h
    Mapping project zephyr/syscall_list_h_target
    Mapping project zephyr/CMakeFiles/syscall_list_h_target
    Mapping project zephyr/include/generated/syscall_list.h
    Mapping project zephyr/include/generated/syscall_dispatch.c
    Mapping project zephyr/zephyr_generated_headers
    Mapping project zephyr/offsets_h
    Mapping project zephyr/CMakeFiles/offsets_h
    Mapping project zephyr/include/generated/offsets.h
    Mapping project zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    Mapping project cmake_object_order_depends_target_offsets
    Mapping project mcuboot_primary_app_hex
    Mapping project CMakeFiles/mcuboot_primary_app_hex
    Mapping project zephyr/mcuboot_primary_app.hex
    Mapping project zephyr/zephyr.elf
    Mapping project C:/Zypher/v1.7.0/zephyr/misc/empty_file.c
    Mapping project cmake_object_order_depends_target_zephyr_final
    Mapping project cmake_object_order_depends_target_..__nrf__subsys__dfu__dfu_target
    Mapping project cmake_object_order_depends_target_arch__arm__core__aarch32
    Mapping project cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m
    Mapping project cmake_object_order_depends_target_arch__arm__core__aarch32__mpu
    Mapping project cmake_object_order_depends_target_arch__common
    Mapping project cmake_object_order_depends_target_isr_tables
    Mapping project cmake_object_order_depends_target_drivers__adc
    Mapping project cmake_object_order_depends_target_drivers__entropy
    Mapping project cmake_object_order_depends_target_drivers__flash
    Mapping project cmake_object_order_depends_target_drivers__gpio
    Mapping project cmake_object_order_depends_target_drivers__i2c
    Mapping project cmake_object_order_depends_target_drivers__pwm
    Mapping project cmake_object_order_depends_target_drivers__sensor__nrf5
    Mapping project cmake_object_order_depends_target_drivers__spi
    Mapping project cmake_object_order_depends_target_kernel
    Mapping project cmake_object_order_depends_target_lib__libc__newlib
    Mapping project cmake_object_order_depends_target_lib__posix
    Mapping project cmake_object_order_depends_target_mcuboot_util
    Mapping project cmake_object_order_depends_target_modules__hal_nordic__nrfx
    Mapping project cmake_object_order_depends_target_modules__segger
    Mapping project cmake_object_order_depends_target_soc__arm__common__cortex_m
    Mapping project cmake_object_order_depends_target_soc__arm__nordic_nrf__nrf52
    Mapping project cmake_object_order_depends_target_subsys__bluetooth__common
    Mapping project cmake_object_order_depends_target_subsys__bluetooth__controller
    Mapping project cmake_object_order_depends_target_subsys__bluetooth__host
    Mapping project cmake_object_order_depends_target_subsys__dfu__boot
    Mapping project cmake_object_order_depends_target_subsys__net
    Mapping project cmake_object_order_depends_target_subsys__random
    Mapping project zephyr/dev_handles.c
    Mapping project zephyr/zephyr_prebuilt.elf
    Mapping project cmake_object_order_depends_target_zephyr_prebuilt
    Mapping project zephyr/linker_zephyr_prebuilt_script_target
    Mapping project zephyr/CMakeFiles/linker_zephyr_prebuilt_script_target
    Mapping project zephyr/linker_zephyr_prebuilt.cmd
    Mapping project zephyr/include/generated/autoconf.h
    Mapping project zephyr/libzephyr.a
    Mapping project zephyr/arch/common/libarch__common.a
    Mapping project zephyr/arch/common/libisr_tables.a
    Mapping project zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    Mapping project zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    Mapping project zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    Mapping project zephyr/lib/libc/newlib/liblib__libc__newlib.a
    Mapping project zephyr/lib/posix/liblib__posix.a
    Mapping project zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    Mapping project zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a
    Mapping project zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
    Mapping project zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
    Mapping project zephyr/subsys/bluetooth/controller/libsubsys__bluetooth__controller.a
    Mapping project zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a
    Mapping project zephyr/subsys/net/libsubsys__net.a
    Mapping project zephyr/subsys/random/libsubsys__random.a
    Mapping project zephyr/drivers/adc/libdrivers__adc.a
    Mapping project zephyr/drivers/gpio/libdrivers__gpio.a
    Mapping project zephyr/drivers/i2c/libdrivers__i2c.a
    Mapping project zephyr/drivers/pwm/libdrivers__pwm.a
    Mapping project zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a
    Mapping project zephyr/drivers/spi/libdrivers__spi.a
    Mapping project zephyr/drivers/flash/libdrivers__flash.a
    Mapping project zephyr/drivers/entropy/libdrivers__entropy.a
    Mapping project modules/nrf/subsys/dfu/dfu_target/lib..__nrf__subsys__dfu__dfu_target.a
    Mapping project modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    Mapping project modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    Mapping project modules/segger/libmodules__segger.a
    Mapping project zephyr/kernel/libkernel.a
    Mapping project zephyr/linker_zephyr_final_script_target
    Mapping project zephyr/CMakeFiles/linker_zephyr_final_script_target
    Mapping project zephyr/linker.cmd
    Mapping project zephyr/isrList.bin
    Mapping project zephyr/isr_tables.c
    Mapping project zephyr/zephyr.hex
    Mapping project mcuboot_primary_hex
    Mapping project CMakeFiles/mcuboot_primary_hex
    Mapping project zephyr/mcuboot_primary.hex
    Mapping project merged_hex
    Mapping project CMakeFiles/merged_hex
    Mapping project mcuboot/zephyr/zephyr.hex
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-configure
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-patch
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-update
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-download
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-mkdir
    Mapping project zephyr/app_signed.hex
    Mapping project mcuboot/zephyr/zephyr.elf
    Mapping project modules/mcuboot/mcuboot_sign_target
    Mapping project modules/mcuboot/CMakeFiles/mcuboot_sign_target
    Mapping project zephyr/app_update.bin
    Mapping project zephyr/app_test_update.hex
    Mapping project zephyr/app_moved_test_update.hex
    Mapping project modules/mcuboot/CMakeFiles/mcuboot_subimage
    Mapping project modules/mcuboot/CMakeFiles/mcuboot_subimage-complete
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-install
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build
    Mapping project modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-done
    Mapping project zephyr/all
    Mapping project zephyr/arch/all
    Mapping project zephyr/arch/common/all
    Mapping project zephyr/arch/arch/arm/all
    Mapping project zephyr/arch/arch/arm/core/aarch32/all
    Mapping project zephyr/arch/arch/arm/core/aarch32/cortex_m/all
    Mapping project zephyr/arch/arch/arm/core/aarch32/mpu/all
    Mapping project zephyr/lib/all
    Mapping project zephyr/lib/libc/all
    Mapping project zephyr/lib/libc/newlib/all
    Mapping project zephyr/lib/posix/all
    Mapping project zephyr/lib/gui/all
    Mapping project zephyr/lib/os/all
    Mapping project zephyr/lib/util/all
    Mapping project zephyr/soc/arm/all
    Mapping project zephyr/soc/arm/common/cortex_m/all
    Mapping project zephyr/soc/arm/nordic_nrf/all
    Mapping project zephyr/soc/arm/nordic_nrf/nrf52/all
    Mapping project zephyr/soc/arm/nordic_nrf/common/all
    Mapping project zephyr/boards/all
    Mapping project zephyr/subsys/all
    Mapping project zephyr/subsys/debug/all
    Mapping project zephyr/subsys/logging/all
    Mapping project zephyr/subsys/bluetooth/all
    Mapping project zephyr/subsys/bluetooth/common/all
    Mapping project zephyr/subsys/bluetooth/host/all
    Mapping project zephyr/subsys/bluetooth/services/all
    Mapping project zephyr/subsys/bluetooth/controller/all
    Mapping project zephyr/subsys/fs/all
    Mapping project zephyr/subsys/fs/nvs/all
    Mapping project zephyr/subsys/ipc/all
    Mapping project zephyr/subsys/mgmt/all
    Mapping project zephyr/subsys/dfu/all
    Mapping project zephyr/subsys/dfu/boot/all
    Mapping project zephyr/subsys/dfu/img_util/all
    Mapping project zephyr/subsys/net/all
    Mapping project zephyr/subsys/net/lib/all
    Mapping project zephyr/subsys/net/lib/utils/all
    Mapping project zephyr/subsys/random/all
    Mapping project zephyr/subsys/storage/all
    Mapping project zephyr/subsys/storage/flash_map/all
    Mapping project zephyr/subsys/storage/stream/all
    Mapping project zephyr/subsys/fb/all
    Mapping project zephyr/subsys/portability/all
    Mapping project zephyr/subsys/pm/all
    Mapping project zephyr/subsys/pm/policy/all
    Mapping project zephyr/subsys/stats/all
    Mapping project zephyr/subsys/task_wdt/all
    Mapping project zephyr/subsys/testsuite/all
    Mapping project zephyr/subsys/tracing/all
    Mapping project zephyr/subsys/canbus/all
    Mapping project zephyr/subsys/modbus/all
    Mapping project zephyr/drivers/all
    Mapping project zephyr/drivers/console/all
    Mapping project zephyr/drivers/interrupt_controller/all
    Mapping project zephyr/drivers/misc/all
    Mapping project zephyr/drivers/pcie/all
    Mapping project zephyr/drivers/disk/all
    Mapping project zephyr/drivers/adc/all
    Mapping project zephyr/drivers/clock_control/all
    Mapping project zephyr/drivers/gpio/all
    Mapping project zephyr/drivers/i2c/all
    Mapping project zephyr/drivers/pwm/all
    Mapping project zephyr/drivers/sensor/all
    Mapping project zephyr/drivers/sensor/grove/all
    Mapping project zephyr/drivers/sensor/nrf5/all
    Mapping project zephyr/drivers/spi/all
    Mapping project zephyr/drivers/flash/all
    Mapping project zephyr/drivers/bluetooth/all
    Mapping project zephyr/drivers/bluetooth/hci/all
    Mapping project zephyr/drivers/entropy/all
    Mapping project zephyr/drivers/timer/all
    Mapping project modules/nrf/all
    Mapping project modules/nrf/ext/all
    Mapping project modules/nrf/lib/all
    Mapping project modules/nrf/lib/bin/all
    Mapping project modules/nrf/lib/flash_patch/all
    Mapping project modules/nrf/lib/fatal_error/all
    Mapping project modules/nrf/samples/all
    Mapping project modules/nrf/subsys/all
    Mapping project modules/nrf/subsys/bluetooth/all
    Mapping project modules/nrf/subsys/net/all
    Mapping project modules/nrf/subsys/net/lib/all
    Mapping project modules/nrf/subsys/dfu/all
    Mapping project modules/nrf/subsys/dfu/dfu_target/all
    Mapping project modules/nrf/subsys/debug/all
    Mapping project modules/nrf/subsys/partition_manager/all
    Mapping project modules/nrf/modules/all
    Mapping project modules/nrf/drivers/all
    Mapping project modules/nrf/drivers/sensor/all
    Mapping project modules/nrf/drivers/hw_cc310/all
    Mapping project modules/nrf/drivers/entropy/all
    Mapping project modules/nrf/drivers/flash/all
    Mapping project modules/nrf/drivers/gps/all
    Mapping project modules/nrf/drivers/serial/all
    Mapping project modules/nrf/tests/all
    Mapping project modules/mcuboot/all
    Mapping project modules/mcuboot/dfu_application_zip
    Mapping project modules/mcuboot/CMakeFiles/dfu_application_zip
    Mapping project zephyr/dfu_application.zip
    Mapping project modules/mcuboot/boot/bootutil/zephyr/all
    Mapping project modules/trusted-firmware-m/all
    Mapping project modules/cjson/all
    Mapping project modules/openthread/all
    Mapping project modules/pelion-dm/all
    Mapping project modules/cddl-gen/all
    Mapping project modules/memfault-firmware-sdk/all
    Mapping project modules/CANopenNode/all
    Mapping project modules/civetweb/all
    Mapping project modules/cmsis/all
    Mapping project modules/cmsis/CMSIS/all
    Mapping project modules/cmsis/CMSIS/Core/all
    Mapping project modules/fatfs/all
    Mapping project modules/hal_nordic/all
    Mapping project modules/hal_nordic/nrfx/all
    Mapping project modules/st/all
    Mapping project modules/libmetal/all
    Mapping project modules/littlefs/all
    Mapping project modules/loramac-node/all
    Mapping project modules/lvgl/all
    Mapping project modules/lz4/all
    Mapping project modules/mbedtls/all
    Mapping project modules/mcumgr/all
    Mapping project modules/mipi-sys-t/all
    Mapping project modules/nanopb/all
    Mapping project modules/nrf_hw_models/all
    Mapping project modules/open-amp/all
    Mapping project modules/segger/all
    Mapping project modules/tinycbor/all
    Mapping project modules/tinycrypt/all
    Mapping project modules/TraceRecorder/all
    Mapping project modules/nrfxlib/all
    Mapping project modules/nrfxlib/nrfxlib/all
    Mapping project modules/nrfxlib/nrfxlib/softdevice_controller/all
    Mapping project modules/nrfxlib/nrf_802154/all
    Mapping project modules/connectedhomeip/all
    Mapping project zephyr/kernel/all
    Mapping project zephyr/cmake/flash/all
    Mapping project zephyr/cmake/usage/all
    Mapping project zephyr/cmake/reports/all
    Preparing solution �HomeBeacon_v121+_sb�
    Preparing project �zephyr/merged.hex�
    Preparing solution �build�
    Preparing project �all�
    Preparing project �app/libapp.a�
    Preparing project �zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj�
    Preparing project �zephyr/zephyr.elf�
    Preparing project �zephyr/zephyr_prebuilt.elf�
    Preparing project �zephyr/libzephyr.a�
    Preparing project �zephyr/arch/common/libarch__common.a�
    Preparing project �zephyr/arch/common/libisr_tables.a�
    Preparing project �zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a�
    Preparing project �zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a�
    Preparing project �zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a�
    Preparing project �zephyr/lib/libc/newlib/liblib__libc__newlib.a�
    Preparing project �zephyr/lib/posix/liblib__posix.a�
    Preparing project �zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a�
    Preparing project �zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a�
    Preparing project �zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a�
    Preparing project �zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a�
    Preparing project �zephyr/subsys/bluetooth/controller/libsubsys__bluetooth__controller.a�
    Preparing project �zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a�
    Preparing project �zephyr/subsys/net/libsubsys__net.a�
    Preparing project �zephyr/subsys/random/libsubsys__random.a�
    Preparing project �zephyr/drivers/adc/libdrivers__adc.a�
    Preparing project �zephyr/drivers/gpio/libdrivers__gpio.a�
    Preparing project �zephyr/drivers/i2c/libdrivers__i2c.a�
    Preparing project �zephyr/drivers/pwm/libdrivers__pwm.a�
    Preparing project �zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a�
    Preparing project �zephyr/drivers/spi/libdrivers__spi.a�
    Preparing project �zephyr/drivers/flash/libdrivers__flash.a�
    Preparing project �zephyr/drivers/entropy/libdrivers__entropy.a�
    Preparing project �modules/nrf/subsys/dfu/dfu_target/lib..__nrf__subsys__dfu__dfu_target.a�
    Preparing project �modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a�
    Preparing project �modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a�
    Preparing project �modules/segger/libmodules__segger.a�
    Preparing project �zephyr/kernel/libkernel.a�
    Restoring state from previous session
    Preparing to load data
    Loading session data from file
    SEGGER Embedded Studio is ready to use
    SES_Building_Solution_Log.txt
    Thank you Kenneth.
    "You can also specify the build type in the Additional CMake Options field in Tools > Options > nRF Connect. However, the changes will only be applied after re-opening the project. Reloading the project is not sufficient."
    I am not sure what the difference is between re-opening and re-loading a project.
    In SES I did
    Tools > Options > nRF Connect then added -DCONF_FILE=prj_release.conf
    File > Open nRF Connect SDK Project... to re-open the project
    Then did a new build in a new empty build folder but the .config file is still not being updated with my config that is in prj_release.conf.
    For example I set CONFIG_LOG=n in prj_release.conf but in .config in the new build folder I see CONFIG_LOG=y.
    Looking closely at the logs when opening the project and creating the solution I can see that it is the content of prj_debug.conf that is merged in the configuration NOT prj_release.conf as expected. This is despite the fact that the cmake.exe command line includes -DCONF_FILE=prj_release.conf.
    Creating solution HomeBeacon_dev_sb.emProject
    C:/Zypher/v1.7.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf52833dk_nrf52833 -DBOARD_DIR=C:\Zypher\v1.7.0\zephyr\boards\arm\nrf52833dk_nrf52833 -BC:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_release -SC:\Sandbox\HomeBeacon_dev_sb -DNCS_TOOLCHAIN_VERSION=1.7.0 -DCONF_FILE=prj_release.conf -DDTC_OVERLAY_FILE=C:/Sandbox/HomeBeacon_dev_sb/nrf52833dk_nrf52833.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\Zypher\v1.7.0\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
    -- Application: C:/Sandbox/HomeBeacon_dev_sb
    -- Found devicetree overlay: C:/Sandbox/HomeBeacon_dev_sb/nrf52833dk_nrf52833.overlay
    -- Generated zephyr.dts: C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_release/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_release/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_release/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_release/zephyr/dts.cmake
    Parsing C:/Sandbox/HomeBeacon_dev_sb/Kconfig
    Merged configuration 'C:/Sandbox/HomeBeacon_dev_sb/prj_debug.conf'
    Configuration saved to 'C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_release/zephyr/.config'
    Kconfig header saved to 'C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_release/zephyr/include/generated/autoconf.h'
    Please explain what is going on here and help sort this problem out.
    Thank you.
    Kind regards
    Mohamed
  • Hi Kenneth,
    From the link you sent me, it is stated in step 4 Do not select Clean Build Directory.
    Why is this the case?
    I thought starting with a clean build folder is often if not always good practice.
    Please clarify.
    Thank you.
    Kind regards
    Mohamed
