How to add new i2c based sensor device to ncs\v1.3.0\zephyr\drivers\sensor.
Can you suggest any tutorial to do so as i want to use sensor subsystem which in turn uses i2c driver.
Thanks
Chandra
Thanks
Chandra
Try to do this:
// You need this in order for DT_ANY_INST_ON_BUS_STATUS_OKAY to work
#define DT_DRV_COMPAT tdk_icm20948
// code
// code
// code
#if DT_ANY_INST_ON_BUS_STATUS_OKAY(spi)
//Do stuff
#elif DT_ANY_INST_ON_BUS_STATUS_OKAY(i2c)
//Do stuff
#else
#error "BUS MACRO NOT DEFINED IN DTS"
Take a look at the zephyr/include/devicetree.h for more information about the macro DT_ANY_INST_ON_BUS_STATUS_OKAY.
Simon
This part i got it. it works for me early this week.
but i have following code in driver.
#if defined(DT_TDK_ICM20948_BUS_SPI)
icm20948_spi_init(dev);
#elif defined(DT_TDK_ICM20948_BUS_I2C)
icm20948_i2c_init(dev);
#else
DT_TDK_ICM20948_BUS_SPI, DT_TDK_ICM20948_BUS_I2C: what are these?
I just repalced these with DT_ANY_INST_ON_BUS_STATUS_OKAY(spi) and DT_ANY_INST_ON_BUS_STATUS_OKAY(I2C).
How to enable these macros : DT_TDK_ICM20948_BUS_SPI ,DT_TDK_ICM20948_BUS_I2C? we can just ignore.
I'm not sure where you get those DTS defines from, and why you think those should be generated. Could you give me some pointers?
I think you should be fine using DT_ANY_INST_ON_BUS_STATUS_OKAY and DT_ANY_INST_ON_BUS_STATUS_OKAY, that is what all the other sensor drives in NCS v1.3.0 are using:
https://github.com/nrfconnect/sdk-zephyr/blob/v2.3.0-rc1-ncs1/drivers/sensor/stts751/stts751.c#L207
https://github.com/nrfconnect/sdk-zephyr/blob/v2.3.0-rc1-ncs1/drivers/sensor/lsm6dso/lsm6dso.c#L755
Simon
OK thanks for all the clarifications. Thank you very much.
I could succeed with DT_ANY_INST_ON_BUS_STATUS_OKAY , could communicate with sensor.
Need to improve sensor driver.
for now I am going to close this ticket.
Thanks
Chandra
