hi ...
how to update the advertisement packet .. I have seen many post regarding this ,I am not getting clear , anyone can share me the piece of code which will help me
hi ...
good to hear you karl ..
yes I tried i am getting the data as 0x47 raw output . I should get 0x32
Here i am sharing the full code what are the changes i made here. Kindly check please ,
volatile static uint8_t my_temp[1]; // initially i am assigning
static ble_gap_adv_data_t m_adv_data1 =
.adv_data =
.p_data = m_raw_data_buffer1,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
static ble_gap_adv_data_t m_adv_data2 =
.adv_data =
.p_data = m_raw_data_buffer2,
.scan_rsp_data =
.p_data = NULL,
.len = 0
Here it is advertising init function
uint32_t err_code;
ble_advdata_t advdata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
// UICR instead of using the default values. The major and minor values obtained from the UICR
// are encoded into advertising data in big endian order (MSB First).
// To set the UICR used by this example to a desired value, write to the address 0x10001080
// using the nrfjprog tool. The command to be used is as follows.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
// the following command should be used.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) my_temp;
manuf_specific_data.data.size = 1;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0; // Never time out.
err_code = ble_advdata_encode(&advdata, m_adv_data1.adv_data.p_data, &m_adv_data1.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data1, &m_adv_params);
then i am sending the sensor data to it
update_advertising_data function
static void sensor_data()
my_temp[1]=50;
static void update_advertising_init(void)
uint32_t err_code;
sensor_data();
manuf_specific_data.data.p_data = sensor_data; // calling the above function uint8_t my_temp[1]={50}
err_code = ble_advdata_encode(&advdata, m_adv_data2.adv_data.p_data, &m_adv_data2.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data2, NULL);
// Initialize.
log_init();
timers_init();
leds_init();
power_management_init();
ble_stack_init();
advertising_init();
update_advertising_init(); //added
// Start execution.
NRF_LOG_INFO("Beacon example started.");
advertising_start();
// Enter main loop.
for (;; )
idle_state_handle();
ps_anu said:yes I tried i am getting the data as 0x47 raw output . I should get 0x32
From you code I can not see any content going into m_raw_data_buffer1 and 2. What are the contents of these?
Furthermore, you are initializing your advertising manufacturer specific data to your my_temp variable - but you never actually initialize the contents of my_temp to anything. Is this on purpose?
I see that my_temp is volatile - why is this?
Do I understand you correctly that you are seeing 0x47 as your manufacturing specific data with the above code, but you expected to see 0x32? Please elaborate on where you are getting these values from - what made you expect 0x32, and where does 0x47 come from?
I also would like to point out that you main function will only change the advertising data once, and this happens before advertising actually starts - so you are not here changing it 'during advertisement', just to be clear.
As a side note, I would also advice against using any magic numbers in your code. Instead, you should create a define or const variable together with your array declaration, to keep track of its intended size.
Karl
so i need to assign with my_temp
uint8_t my_temp[1]={90};
m_raw_data_buffer1[]= my_temp;
is it so ? or wrong
then
because in update_advertising_init() function i am passing the my_temp as 40 .. 40 hex value is 0x32 .
myself i dono where i am getting the 0x47
because , my_temp will change it is not constant value
i want dynamical data
is it so ? or wrong
Well, you could do this, but you are here just creating a shallow copy of the my_temp variable.
I do not know if this is intentional in your case.
But yes, you should initialize the variables. If you do not initialize them, you have no way of knowing what the variable might start out to be. For example, the 0x47 you saw earlier could have been a result of your random initialization here.
Could you try to test this again, but this time, having initialized your my_temp variable to something else - like dec 0 or dec 100, and then changing it in the sensor_data funtion to dec 50. Try this, and let me know if you are seeing the same results.
I see that you have made additions and edits to your previously shared code - please do not do this.
I do not recommend doing this, since I then have to read through the code and remember what you might have changed since my last comments. Instead, you should share only the snippets you have changed in your new replies, for example: "I have changed this and that function as shown below, and I am not seeing ... ".
By adding and editing the previously shared code, you are also voiding all my previously written comments - as they are comments to code that no longer exist or is structured in the way that it was. This makes it hard for you too, if you ever are to go back and read these comments.
In your appended sensor_data function, you are trying to write my_temp[1], buy my_temp is an array of length 1. You probably meant to write to my_temp[0] here.
Furthermore, the change you have made in line 17 of your code snippet titled update_advertising_data function does not make sense, as sensor_data is first called as a function, and then subsequently used as a variable. I think you meant to use my_temp here, but please do not make such additions and edits because it is incredible hard to read and account for, and in this case probably also wrong entirely.
In your appended sensor_data function the value of my_temp[1] is set to 50, for the record. 50 decimal value is 0x32 in hex value, 40 decimal value is 0x28 in hex value.
That is fine. The volatile modifier is used when a register or value might change without the compiler seeing that it can happen - such as if you are pointing to a register that is connected to an external interrupts.
Global variables that are not declared const can be changed as normal.
Karl
Thanks alot.. It worked , I have made changes as per you said and one more here i need to advertise my own name how to do that ? I am working on beacon example in this example gap function is not there
