2 UART sample code not working as expected
We are using the Serial port library with two UARTEs. It defines two instances of the serial port interface: one for receiving data, and one for sending data.
After power-up, the example sends a "Hello nrf_serial!" string to the J-Link serial port. Then, it starts operating in loopback, which means that it sends every
byte that it receives through the first serial instance back to the serial port through the second serial instance.it's woking properly
when we send data from tx pin of  both UART`S UART0 and UART1  to Hterm  then data send successfully and vice varsa,but when we use single UART0 with our Device (meter)
we are not getting response in Rx buffer .if we short TX and RX pin we got data in Rx buffer.
example:
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
                      RX_PIN_NUMBER,TX_PIN_NUMBER ,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_115200,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
                      ARDUINO_SDA_PIN,ARDUINO_SCL_PIN,
                      RX_PIN_NUMBER, ARDUINO_SCL_PIN,
                      ARDUINO_SDA_PIN, TX_PIN_NUMBER,
#define SERIAL_FIFO_TX_SIZE 1024
#define SERIAL_FIFO_RX_SIZE 1024
NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
                      &serial0_queues, &serial0_buffs, NULL, sleep_handler);
NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
                      &serial1_queues, &serial1_buffs, NULL, sleep_handler);
NRF_SERIAL_UART_DEF(serial0_uarte, 0);
NRF_SERIAL_UART_DEF(serial1_uarte, 1);
    ret_code_t ret;
    ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    ret = nrf_drv_power_init(NULL);
    ret = app_timer_init();
    // Initialize LEDs and buttons.
    bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
    ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
    ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
    uint8_t tx_message[34] ={0x7e, 0xa0, 0x20, 0x03, 0x21, 0x93, 0x7d, 0xd9, 0x81, 0x80, 0x14, 0x05, 0x02, 0x02, 0x00, 0x06, 0x02, 0x02, 0x00, 0x07, 0x04, 0x00, 0x00, 0x00, 0x01, 0x08, 0x04, 0x00, 0x00, 0x00, 0x01, 0x6f, 0xef, 0x7e};
      unsigned char c[100];                                                     // Rx Buffer
      ret = nrf_serial_write(&serial0_uarte,
                           tx_message,
                           sizeof(tx_message),
                           NULL,
                           NRF_SERIAL_MAX_TIMEOUT);                             // use only UART0
          (void)nrf_serial_flush(&serial0_uarte, 0);
        memset(&c,0,100);
        /*ret = nrf_serial_read(&serial0_uarte, &c, 34, NULL, 10000);
        if( strlen(c))
        (void)nrf_serial_write(&serial0_uarte, &c, 100, NULL, 10000);
     while (true)
        if (ret != NRF_SUCCESS)
            continue;
        if( strlen(c))
Please support us
  • Hi Simon,
    We have another idea in mind as well.
    We want to use the same UART example code and see if we can change the pins to talk to two devices one at a time. So basically if we consider that P0.1 is tx0 and P0.2 is rx0 to which we have connected our first device, and P0.3 is tx1 and P0.4 is rx1 to which we have connected our second device.
    Once we get data from tx0 and rx0 how do we switch to tx1 and rx1 at run time to then use the same interrupt code to retransmit the data.
    Hope this makes sense.
    Let me know your thoughts.
    Neel.
  • Hi
    First off, P0.01 needs to be configured specifically as a GPIO as it is set to be used with the external LF crystal by default. This will be configured as a GPIO by setting the device to use the internal RC oscillator instead.
    You can check out this thread, where switching between UART pins has been discussed in detail.
    Simon
  • Hi Simon,
    Reviewed the thread but it still doesn't help us.
    What we need is to be able to read data using one set of Tx/Rx pins (using the interrupt based code) from one device and then using the same interrupt driven logic communicate with another device. Since the two UART example isn't based on interrupts we were thinking if we can configure UART0  from one set of Tx/Rx pins to another set of Tx/Rx pins.
    Basically uninitiaze one set of UART pins and initialize another set of UART pins.
    We are using the nRF52840
  • Hi
    If you only need to use one device at a time you could keep switching the pin selection in the UART around in software by uninitializing and initializing the peripheral with different TX/RX pins. For example, have a UART_INIT1 and a UART_INIT2 function that uses different TX/RX pins and, when uninitialized, calls to initialize the other function. This won't help if you need access to all the devices constantly though. In that case you can try bitbanging the UART; but that's not something we would recommend.
    Simon
