Radio test in 802.15.4 -mode
I'm running the SDK 17 radio test example on two nRF52840 DKs. My goal is to do a PER measurement in 802.15.4 -mode.
I configure the boards to use ieee802154_250Kbit mode, the same channel and same payload pattern for both boards.
I can get the reception to work for a little while. If I tell the sender to send 100 packets, I usually get 100 received packets. But for anything longer the reception seems to stop at some point.
For instance if I set the transmitter to send 10000 packets (start_tx_modulated_carrier 10000) and monitor the reception by issuing "print_rx"-commands on the receiver, the packet count initially increments but stops at some point. Usually at a few hundred packets. Now if I issue a new "start_rx"-command the packet count again starts to increment from zero (as expected), but again stops at some lowish value.
I also tried a lower packet rate by setting the transmitter to duty cycle modulation. If I do "start_duty_cycle_modulated_tx 10", ie 10% duty cycle, it is even easier to monitor the received packet count as it increments slower. But again the count stops incrementing fairly soon. And restarting the rx makes the reception work again for a while.
If I redo all of the above using ble_1Mbit -mode it all works. I can send 10000 packets and receive 10000 packets. So it seems to be related to the 802.15.4-mode.
All testing so far has been done at my desk, with the DKs a few centimeters apart.
Any ideas on how to make this work would be appreciated.
