The issue in ADC in nrf52840
I am trying to integrate ADC in my project(ble_app_template) but getting garbage data. I have nothing connected with pin P0.4(NRF_SAADC_INPUT_AIN1). (Means not applied any voltage)
The behavior is the same with/without connecting NRF_SAADC_INPUT_AIN1 with input signal.
Here is my implementation.
void saadc_init(void)
	// A variable to hold the error code
  ret_code_t err_code;
  // Create a config struct and assign it default values along with the Pin number for ADC Input
  // Configure the input as Single Ended(One Pin Reading)
  // Make sure you allocate the right pin.
//  nrf_saadc_channel_config_t channel_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
 nrf_saadc_channel_config_t channel_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_DIFFERENTIAL(NRF_SAADC_INPUT_VDD,NRF_SAADC_INPUT_AIN1);
  // Initialize the saadc
  // first parameter is for configuring the adc resolution and other features, we will see in future tutorial
  //on how to work with it. right now just pass a simple null value
  err_code = nrf_drv_saadc_init(NULL, saadc_callback_handler);
// Initialize the Channel which will be connected to that specific pin.
  err_code = nrfx_saadc_channel_init(0, &channel_config);
    // Enter main loop.
    for (;;)
        idle_state_handle();
		// a blocking function which will be called and the processor waits until the value is read
		// the sample value read is in 2's complement and is automatically converted once retrieved
		// first parameter is for the adc input channel
		// second parameter is to pass the address of the variable in which we store our adc sample value
      nrfx_saadc_sample_convert(0, &adc_val);
		// print this value using nrf log : here %d represents the integer value
      NRF_LOG_INFO("Sample value Read: %d", adc_val);
		// use nrf log and float marker to show the floating point values on the log
		// calculate the voltage by this: input_sample * 3.6 / 2^n (where n = 8 or 10 or 12 or 14 depending on our configuration for resolution in bits)
      NRF_LOG_INFO("Volts: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(adc_val  / 16384));
	   // give 500ms delay
       nrf_delay_ms(2000);
Any suggestions, please?
  • Thanks,
    It's working perfectly fine.
    Can you please mention/remove the timer? I want a function, when I call that function it gives me current ADC reading on P0.3. Can you please guide how can I do that(remove the timer from this code)? I have tried but it's not working.
    Thanks again
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
       Author : Abdelali Boussetta @rmptxf
       Description : This saadc example uses one channel (AIN1 (P0.3)), samples at 100ms (10 samples) =  get result each (1 second).
       It uses 14Bit as a resolution.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SAMPLES_IN_BUFFER 10
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    // RESULT = [V(P) – V(N) ] * GAIN/REFERENCE * 2(RESOLUTION - m)
    // (m=0) if CONFIG.MODE=SE, or (m=1) if CONFIG.MODE=Diff.
    // V(N) = 0;
    // GAIN = 1/6;
    // REFERENCE Voltage = internal (0.6V);
    // RESOLUTION : 12 bit;
    // m = 0;
    // 12bit
    // V(P) = RESULT x REFERENCE / ( GAIN x RESOLUTION) = RESULT x (600 / (1/6 x 2^(12)) =  ADC_RESULT x 0.87890625;
    //#define ADC_RESULT_IN_MILLI_VOLTS(ADC_RESULT) ((ADC_RESULT * 0.87890625))
    // 14bit
    // V(P) = RESULT x REFERENCE / ( GAIN x RESOLUTION) = RESULT x (600 / (1/6 x 2^(14)) =  ADC_RESULT x 0.2197265625;
    #define ADC_RESULT_IN_MILLI_VOLTS(ADC_RESULT) ((ADC_RESULT * 0.2197265625))
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
        /* setup m_timer for compare event every 100ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 100);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
            uint32_t buffer_samples = 0;
            uint16_t adc_result = 0;
            uint16_t adc_voltage_mv = 0;
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            m_adc_evt_counter++;
            NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
            for (uint8_t i = 0; i < SAMPLES_IN_BUFFER; i++)
                buffer_samples += p_event->data.done.p_buffer[i];
            adc_result = buffer_samples/SAMPLES_IN_BUFFER;
            adc_voltage_mv = ADC_RESULT_IN_MILLI_VOLTS(adc_result);
            NRF_LOG_INFO("adc result : %d.", adc_result);
            NRF_LOG_INFO("voltage : %d mV.", adc_voltage_mv);
            NRF_LOG_INFO("---------------------------");
        // Using the channel default single ended (SE) config
        // pin NRF_SAADC_INPUT_AIN1 : P0.03
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
        // changing the saadc resolution to 12bit
        nrf_drv_saadc_config_t saadc_config ;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_14BIT;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
        uint32_t err_code = NRF_LOG_INIT(NULL);
        ret_code_t ret_code = nrf_pwr_mgmt_init();
        APP_ERROR_CHECK(ret_code);
        saadc_init();
        saadc_sampling_event_init();
        NRF_LOG_INFO("SAADC HAL simple example started.");
        while (1)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
  • Just call nrfx_saadc_sample instead of triggering the sample task via the timer.
  • Hi ,
    I have made function and commented timer functions.
    But now the code is not working. Can you please refer to any example or guide how can I implement this   nrfx_saadc_sample?
    Really Thanks!
  • Try this:
    /** @file
     * @defgroup nrf_adc_example main.c
     * @ingroup nrf_adc_example
     * @brief ADC Example Application main file.
     * This file contains the source code for a sample application using ADC.
     * @image html example_board_setup_a.jpg "Use board setup A for this example."
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "boards.h"
    volatile uint8_t state = 1;
        /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                       ticks,
                                       false);
            int i;
            for (i = 0; i < SAMPLES_IN_BUFFER; i++)
                NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
        err_code = nrf_drv_saadc_init(NULL, saadc_callback);
        saadc_init();
        //saadc_sampling_event_init();
        //saadc_sampling_event_enable();
        while (1)
            err_code = nrf_drv_saadc_sample();
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
  • Hi
    Trying to build your code but getting the following issue.
