Bootloader inactivity timeout not triggering when interrupting USB DFU
Hello! I'm using SDK 15.2
I have a bootloader that has both BLE and USB DFU capabilities
Everything is working fine, the inactivity timeout of bootloader triggers in all of the expected situations but one: when the USB DFU process is interrupted while the device is being programmed
I'm using NRFUtil to test this and while the progress bar is being shown I kill the process with a CTRL+C and then the bootloader hangs, it never resets.
I have a snippet of the output while the DFU process is happening:
00> <debug> app: restarting timer
00> <debug> app: timer_stop (0x200057D4)
00> <debug> app: timer_start
00> <debug> app: timer_activate (0x200057D4)
00> <debug> app: Shutting down transports (found: 2)
00> <debug> nrf_dfu_ble: Shutting down BLE transport.
00> <debug> app: Failed to shutdown transport 1, error 8
00> <debug> nrf_dfu_serial_usb: Allocated buffer 200062B4
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0008A000, len=1 pages), queue usage: 1
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0008A000, pending 0
00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000D000, CRC: 0xEE501589
00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
00> <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
00> <debug> nrf_dfu_serial_usb: Allocated buffer 20005AB0
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0008A000, src=0x200062B8, len=1024 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0008A000, pending 0
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0008A400, src=0x20005AB4, len=1024 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0008A400, pending 0
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0008A800, src=0x200062B8, len=1024 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0008A800, pending 0
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0008AC00, src=0x20005AB4, len=1024 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0008AC00, pending 0
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
00> <debug> nrf_dfu_req_handler: Offset:57344, CRC:0x6A58AE2A
00> <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
00> <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0008B000, len=1 pages), queue usage: 1
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0008B000, pending 0
00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000E000, CRC: 0x6A58AE2A
(The last line of that log corresponds to the last line printed in the RTT viewer after I kill the NRFUtil process)
I can see that there's an error when the code tries to shut down the BLE transport layer. Can that be related to the problem that I have?
Thank you so much!
