Nrf52832 ble_app_uart DFU No bootloader found(NRF_ERROR_NO_MEM) | SDK 15.3.0 | Soft device S132 6.1.1
I am trying to integrate buttonless DFU with FDS in ble_app_uart example from sdk 15.3.0. Merge hex was done properly which includes bootloader_settings.hex+bootloader.hex+softdevice.hex+application.hex and programmed using JLink prior to that i erased the chip using nrfjprog -f nrf52 -e command successfully. Then i resetted the board, application started and reaches ble_dfu_buttonless_async_svci_init() which gives NRF_ERROR_NO_MEM error. I went into debug mode and found uint32_t bootloader address was 0xFFFFFFFF. I checked UICR register value using JLink command -> mem8 0x10001014 4 which results 0xFFFFFFFF. The bootloader i programmed was debug version and i got the below prints.
PRINT_START
00> <info> app: Inside main
00>
00> <debug> app: In nrf_bootloader_init
00>
00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
00>
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
00>
00> <debug> nrf_dfu_settings: Using settings page.
00>
00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
00>
00> <info> nrf_dfu_settings: Old settings page detected. Upgrading info.
00>
00> <debug> nrf_dfu_settings: Writing settings...
00>
00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x20009188, len=896 bytes), queue usage: 1
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
00>
00> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
00>
00>
00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 1
00>
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 0
00>
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20009508, len=896 bytes), queue usage: 1
00>
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 0
00>
00> <debug> app: Enter nrf_bootloader_fw_activate
00>
00> <info> app: No firmware to activate.
00>
00> <debug> nrf_dfu_validation: CRC check of app failed. Return 1
00>
00> <debug> app: App is valid
00>
00>
00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
00>
00> <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
00>
00> <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
00>
00> <info> app: Setting vector table to bootloader: 0x00072000
00>
00> <info> app: Setting vector table to main app: 0x00026000
00>
<debug> No bootloader found
00> <error> app: Fatal error
00>
PRINT_ENDS
The application Linker script has
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x53000
RAM_START= 0x200030E0
RAM_SIZE=0xCF20
I don't know why UICR has 0xFFFFFFFF value and i know that because this my application stucks in Fatal error. Why UICR is not programmed properly?
I am attaching nrf52832_xxaa_s132.map(from pca10040_ble_debug\armgcc\build), bootloader_settings.hex, bootloader.hex, application.hex and sd_app_boot.hex for reference.  74862.nrf52832_xxaa_s132.map6567.bootloader_settings.hex1667.nrf52832_xxaa_s132.hex8524.sd_app_boot.hex0513.ble_app_uart_pca10040_s132.hex
