AN36 question
this is quote from AN36> 4.2 Set up
The nRF51822 Evaluation Kit is needed for this application example. However, it is possible to modify the project to also work with the Development Kit. 4.2.1 Setting up the Evaluation board Since the nRF51822 Evaluation Kit has an onboard SEGGER chip, you can connect the Evaluation board through a USB cable and immediately start working on it. 4.2.2 Setting up the application A lot of boilerplate code is needed to get started creating an application and a service, so the first step is to copy code from the SDK:
  1. Go to Board\nrf6310\ble\ble_app_template folder.
  2. Copy this folder to Board\pca10001\ble\ and rename it to ble_app_lbs.
  3. Inside the Arm subfolder of ble_app_lbs change the name of the project files from ble_app_template to ble_app_lbs.
At the same time AN36 has folder code[u][/u] which includes ble_app_lbs.uvproj
Could someone please clarify.
The second question/clarification is where can I find parameters SD110 used on pca10005 and pca10004 for keil?
Thank you.
