External GPS antenna on Thingy:91/PCA20035 1.4.0
I received a bunch of Thingy:91/PCA20035 version 1.4.0 which upgraded the SWF connector for GPS antenna to a uFL/IPX connector which is great. I also have a few PCA20035 version 1.0.0 and the GPS fix time was horrible with the internal antenna. The documentation still mentions a SWF adapter so I guess it wasn't updated.
I have a few questions reguarding the use of an external antenna:
  • It the Errata v1.0 still valid? I guess so because the Fractus internal antenna is the same reference.
  • Do you have a suggestion for an external GPS antenna (that may fit inside the case)? I tried an active antenna but the performance is terrible.
  • DurandA said:
    Is it correct than we can either use a passive antenna and keep the LNA enabled or an active antenna and disable the LNA?
     Yes.
    Yes, the configuration you referred to does not have support for Thingy:91 yet. However, the PR 3077 (which I see you've already found) will fix this.
    As for your questions on the PR:
    • Does the LNA act as a passthru when COEX0 is high?
    First could you clarify what you mean by "passthru".
    The answer depends on how you configure COEX0.
    COEX0 is input to the LTE modem from the external device. When active high, indicates that the external device transceiver is turned on.
    When the internal GPS is used, COEX0 can be used as active-high control for the external LNA component.
    • How is MAGPIO used?
    The MAGPIO pins can be used for example to control an external antenna tuner or any GPIO controller device whose state depends on the modem's RF frequency. They are configured using the AT command: %XMAGPIO
    • For Thingy:91, is it ok to use an external antenna with this configuration:
      • passive antenna with LNA enabled
      • active antenna with LNA disabled
    Yes.
    You can read more about the LTE modem coexistence interface and the LTE modem RF control external interface in the links attached.
  • Many thanks for the extensive answer. I misread the schematic and thought that the external antenna connector was connected to ANT_GPS while it is J2.
    In that case, the signal from the external antenna does not go through the LNA so I assume only an active GPS antenna will work.
