Documentation on generating/using custom signing key for FOTA in nRF Connect SDK
Hello Nordic Team,
Over the course of development I have had to reverse engineer and pick apart various sources (DevZone, Google, Zephyr documentation, etc) in order to figure out how to properly generate and utilize a custom, private signing key for our FOTA images. I currently have a working solution but it feels more like a hack and as I frequently test on the master branch to prepare for upcoming changes, it appears that the method I am using is generating warnings.
My question is: is there any official documentation and/or guide on how to properly generate and sign images using a custom signing key and how that is integrated into a project (ie asset_tracker)?
I want to make sure that I am doing it right and that it is properly integrated into my project and build system.
Cody
  • Hey @Simon,
    I reviewed the the other ticket and I am now on nRF Connect SDK v1.4.2, in the thread someone mentions that in v1.4.0+ you only need to provide the following lines in the mcuboot configuration file:
    CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=n
    CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
    CONFIG_BOOT_SIGNATURE_KEY_FILE="custom_key_rsa-2048.pem"
    That appears to be in line with the asset_tracker/connectivity bridge examples in v1.4.2 where they have a mcuboot_overlay-rsa.conf file in the root and then added to the MCUBoot configuration in CMakeLists. with the following code:
    list(APPEND mcuboot_OVERLAY_CONFIG
      "${CMAKE_CURRENT_SOURCE_DIR}/mcuboot_overlay-rsa.conf"
    Doing so in my project still leads to the following scary warning message from MCUBoot -
    --- WARNING: Using default MCUBoot key, it should not ---
    --- be used for production. ---
    Do you know if I am doing something wrong? What's weird is I think it is still working, if I put a log statement in mcuboot.cmake where that message is printed out, my custom defined signature key file is being set....
    # Set default key
    if (NOT DEFINED mcuboot_key_file)
    message(WARNING "
      \n"
    set(mcuboot_key_file ${MCUBOOT_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
    message(WARNING "mcuboot_key_file ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}")
    endif()
    Cody
  • The warning just tells you that you're using the default key from NCS, and you should definitely not use this key on the deivices that goes out to production, as it will make your devices unprotected. That key is only meant for testing. You should geneate your own keys for the production versions.
  • I have generated my own private key and am following the same/similar setup as asset_tracker/connectivity bridge in nRF Connect SDK v1.4.2.
    It is very strange though because CONFIG_BOOT_SIGNATURE_KEY_FILE is being set to my custom key file name and appears to be utilized.
    CMake Warning at /Users/crsharff/Development_Tools/ncs_v1.4/nrf/cmake/mcuboot.cmake:125 (message):
    CMake Warning at /Users/crsharff/Development_Tools/ncs_v1.4/nrf/cmake/mcuboot.cmake:133 (message):
      mcuboot_key_file /cody-custom-rsa-2048.pem
    Doing more research it appears that this error is shown because the following code block doesn't set the mcuboot_key_file because mcuboot_CONF_DIR and mcuboot_CONF_DIR appear undefined.
      if (DEFINED mcuboot_CONF_FILE)
        message(WARNING "DEFINED mcuboot_CONF_FILE")
        get_filename_component(mcuboot_CONF_DIR ${mcuboot_CONF_FILE} DIRECTORY)
        if (EXISTS ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
          message(WARNING "EXISTS ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}")
          set(mcuboot_key_file ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
        endif()
      endif()
      # Set default key
        message(WARNING "
          \n"
      endif()
  • I'll look into it tomorrow morning (CET).
  • Thanks Simon, much appreciated. The more I delve into it the more it looks like its just an issue with the logic inside mcuboot.cmake. It will print the scary message 100% of the time as long as mcuboot_CONF_FILE is not defined and mcuboot_CONF_FILE being defined does not look like a requirement for CONFIG_BOOT_SIGNATURE_KEY_FILE to be properly set by the MCUBoot overlay configuration file in my project.
    Found this other thread on the DevZone that seems to be discussing a lot of the same issues: devzone.nordicsemi.com/.../problem-with-signing-images-for-ota-dfu
