My application board do not run example project
Dear
                                I have finished completed the Blue tooth Mesh light-switch example function testing , secure button dfu and secure buttonless dfu on DK and dongle of nrf52840 chips.
                                Right now I build a testing circuit by nrf52840 module which was bought from vendor (The vendor said the modules are  bran-new which mean there is nothing in the nrf52840 chips). The circuit is built according to No5 circuit configuration schematic of nrf54280 datasheet(on page 593). A 3v3 exteral power connect to VDD and VDDH; Vbus be connect to USB power separately, which should be 5V. A SWD interface be connect to P19 of Dk(pca10056).
Below is some experiments I did and the result:
E1: Example:  open_bootloader of nRF5_SDK_16.0.0_98a08e2 : which locat at "nRF5_SDK_16.0.0_98a08e2\examples\dfu\open_bootloader\pca10056_usb_debug"
The " open_bootloader_usb_mbr_pca10056_debug.emProject" project be programmed to the module by SES through P19 of pca10056.
Every thing is ok. Becouse the LED blink to show it have enter the DFU state
Then I programmed the s140.hex and light_switch_server_nrf52840_xxAA_s140_7.0.1.hex to the module by USB with a 3v3 exteral power(The PCA10056 board be disconnected). the process looks good. But the code do not run, the led still blink after I push the reset button. there also is not any advertisements and LED also stay off.
E2: Example: secure_bootloader of nRF5_SDK_16.0.0_98a08e2 : which locat at "nRF5_SDK_16.0.0_98a08e2\examples\dfu\secure_bootloader\pca10056_usb_debug" and " nRF5_SDK_16.0.0_98a08e2\examples\dfu\secure_bootloader\pca10056_s140_ble_debug"
In this experiment, I will try 2 example project for USB dfu and ble dfu
After the module be erased by "nrfjprog -e" command through SWD interface which connect to P19 of pca10056, I programmed those 2 projects severally by SES and SWD interface.
After programmed "secure_bootloader_usb_mbr_pca10056_debug.emProject ", the desktop programmer tools can connect the module and also can write " the s140.hex and light_switch_server_nrf52840_xxAA_s140_7.0.1.hex". but the example code still do not run. it is same with E1.
After programmed " secure_bootloader_ble_s140_pca10056_debug.emProject ", the led is correct like as PCA10056 board, but there is not any advertisements.
The RF parts of the module does not work all the time. the light-switch server code can not be started by bootloader althrough it can be started on PCA10056 board.
Q1: Is there anything special we need to do to make a new NRF52840 chip work properly? (For example, the hard disk needs to be formatted before use)
Q2: Those testing result show me that the light-switch server code make the all of the pin stop output? why?
Q3: Is there any key to lock the flash so that the application code can not be write to flash?
Di-sheng
