I can see in Segger Embedded Studio v4.52 under the Build Tab, there are two methods to build the project.
1- Build > Build zephyr/zephyr.elf
2- Build > Build solution
What is the difference between the two methods?
Kind regards
Kind regards
Hi! Could you please attach your project as well? :)
Here it is zipped up. change extension to 7z.
Note, It was working fine this morning.
7z��' �Lb # ��v��L�] ���\�����g�+mRG�ԽN����ڠq�؏c�r��~�z�S&F@���`��-�ܱ�Gpj%EF%x#DI��s�9��#�M�fr�%�]y�q"s%��O����M��SGR��sdU�m����ǤB��0��_g���]S58sIz����K�h���8{,f�&�XL����qnۯ\�e}�c�����uG1M�F��I��g8���R��Su�]����E�?|19yɠL�ѵ�i�dP�q ��n!:��������7W�t}�^}Ty��M�
�Q�p�l��Yy��2G���V[W��`��;�$G�����H����Գ��T�FJ�k��^�gN������?�����?��SLyZh��P�ҏF�1!�<wm�c���/ˡ���wo�M���^d6�_}K9��:��j�(�t8Y$�Q�B���H��0t;w�l�Άw�oW�
.$݈��_H�����LA���玦�}�,[�,�������Lq�1a���7��P�G~�tq[r$6�/羧� �ZK���"��W��=�`!��ZU���������yS�Cw�g�_�#�2I(<S��d�l�HQ�v�9T3�MG�8[p�TK�h!H�L)�|�|�� ��9�pl�yj��m�|u�se�\��_N����:W~dw��b��&��a��Nc"������q�Zf��^�Q��sצg4�W&�'���'G��)|�.�v�����ט�N��Ġ[�Ċ��'��0�q?�BF�a��ܸ�_Ru3q���[K�̥�F�`��Cy \7�
\i���Y��h���r�)�7��� o���1�(�6�a^��#$���Is�Oj�k3'��Eb�wM�Wy ���4�L�_��L ��Tx�n�::�����N���^y:��C��cƻ
#��F�)���%Y$=YKgV���wW��<�S�]�%_�.��Vq)�Ԭ�䓡@����C�f�`����]��K��O��O�L`N��S:*��=�_�'�/�y�@H� ����-8���a��:o��@F3�9]�K�?�J��r���/9��������SO'�w?D�����E��6�Y�qa�J�=������"�����.yU2,8�ݼ��,�"G
����:c���q`��eѥ�B�;0�Va$\m?~
���l����z�����̸d{�YIc���PC�W6 7 ��$ց>�z�0��Gck��.5���lM�0��͊�|��Y�o���*�ٖ�ӹZ+�O�!��M-��z�Sw R��=E�K;�&�Hx�]��R������q�
����d��%v&2�,���P���~G�𤧈��h�9m�Xx�O��&M�/b�(�b����v����4�H��|ha3s��j��C�y�ʲ�����؞�~�lﳽw!�YR��v��q7Y�n���li�vt�MH=G�I�G/���G��msWPʥ佅c.3#���T<
�궍���;�$�'�4�d贀϶T�;��"�̿I:�D�������.ZHV��4-�Wx&cA0����#��zh0-��j���/d�������Ѽ�!yFx"�6��X�``��ƝI��>�����
�Yw�6���:���~��tpR�
�Wǖ:�H��I���dxSQ���@��!�E����[{P��?5ί=������]��9X�]�|s��RWi�m����@#$�Z.�q�i�����#RSwB�>�nb�z/���N�w:>h�H`�� ���m��e�l�x�}�lQϰ�k!V/�z:�z�������V~�*��0����/���v��~�䗗���%^?B�qg;_l#���4q�A0�c&��S=*�3�s"�_�e)i�hɊ�H�q���H���(��X�/T��H�wc(ht�o��*���&G}+<�`^e8s;�� �XY�@˯��>����n8��w,l5�[*$kc�[��!�8���+i���Y� 0�q��0���;)�r�WMZ��e��L��IP#v �Pl�[�d�B����L{afS��@�{.���q���mܙ CLU��Z���ś�j'����O��Dm��4]�i�.U�L�����$X�;Wtn�vwj)@5�+t�Ƣ(�W�W��\J����� ��T�裓ԐEŭ�{;m�L�ޅ����:�pdݙ��&��$����U���a�OVH�샶�B�M����
�A���%"P�^�ٛ��C!��^Vz�Hp��ڣ�#�-#��]
m5����J��G!͆�D�]��V,I��� ��m���r�k����
���'_� -@#�I��6�F�7j��U����?�7��
�~�w @1�^���o%��~���<6)�� �%���^��4��R�m��U�J�<�x��M
�SL�Uߣ��`�
�o�(i_����5&DΡ-�pM�u��Q3�����M������E���Q��!#�<�u\�#0��+��'q���}T�
1I���Xo�_�~�F�`"]��V��mx忝�����fx�Z8G,-���}
�q� eɀT�v��r�{�҂M�<`����L�=���o:=��'��|�g㛁�d���B))��H�
k�ւc<i~,M=�@�����X�ʀyN+��;��ʣ�B1����cp�7z�)���D7pě%�N���$�Yx��@7�����,Uhj'�ȅg5�ni��[ ~�JS�>�y2u�I�d��c�!��G�2�+uZ�u@����|�&��ȫR��
?���,��g�Y�^_�>A�R��-�?��P4n���"\]=.���i��e�F����
rn�V���W�k� )>���b-���!/��-���X
�Z�����?��̃�S���=4p}���~쩚K�����u�n
�ƉK��Gn�u��Z츳��^���1�L�u����x��Z��DF�
����|u�L�
���4�[��濕/$���Ҙ��ͥ ���d�,U���юnH�?(�F_�ꦇ� %� S���T���R�y3 D�+Un�����L�����W��aw
���#WxF�|'�������)8�f�����C�'��~�3�8���q����3�v,�n��$`E��"��
�RTe�vr��:�X/�����
�{ȉm?Ɠ���j�oڣ�>�� �ޫO��۷�fk���Zy�aZ�>-����J;p��G�0�.`1�Vso�<�ަ�n,�6}�A��-�ά��t{����%az� �o��C��S������/��e� ����$Ѥu)�%6�[�I��t�A��uV��f@�~%_oV���cqm
�ח�V����c{t$� ��e��>�$W/�-�B�'i�?����Ϛ.{�)�_���#�Za�I���6�E:����v�bMb;7<(�tu�{�!����Ťq�O�Q���R��.�u�-�
S�)@��!sg�����? 5/�����o�}�뤥<'${ZG:x��m��/jn�:��~U� ��1�=~e%R۰�?�D/�l��5C���\j��m�r�� ���7[�����tWl*�-J�r�ܸwoW+�tov�+��t ����x���Kv��2.|�žJ!,�*�~xW�7��I���9j`�׀d�QUI�'��TM6��WB>d�%NH ��J�3��!�����L��T\��
r�t]�!�a�I�{���//l'�Z��=���[��~&�/�)Gm�_�Q��q��^�3�,@���;�
��\tj~�gBW$]�Yѷ��A䧃�R
ge�pk.��-]7�0VwI�����F��Y^A��@*��ү�wBc<�߸т_�}�ȡ%��_�� h4�_�{q�!<1Ժ�Ol
��*I�j��W�~�� �n����3������ح�H��h��SU<M�HQy������
ڷLR��Րg#�Bg�d�A��15�
~�ģ�3LGބg��7t�D�Ur�� ��ᆯ
�+�fVP���*�|&�(P��*LB���х��ᬓl�K����<���.�?�I� SV�,���g!6ԝ -�����D�RsUc<_�e�K���W�U��2�h1F;����Ԩk��K��������9
nGf�TL�{9n^�ҋ���ax��;(��%��/n��� �J�s�Bp�a�/����+s�{ݐo�WL�s�Q�F|��͏�#Hbw+��s�L)�I���
Oˏ�Y�^
�� �GT���P��~�:��r��g<4���Jx�$����-͵P�J��q�=��>��b�.���!�<�v���9�EK�E��~I�͒"����M�.� �N�ˎ@Q���tH���,�C9{?w��4�L�T��J;��=�I�?6D]&7#s�Lo�s/��\�`��Y�N�ݸU�}���P��<���ݕK�Q�"\�*�z0�ݐ?eKoX�
��\�qy��a������8M,aݩ&��C�����Q��y�i�t��������X��0%&�q�(��Y��������ՠN���#ׁ+휆uVo�A mUj�JCÀ���xU��Z��A���2Q��9�ꎿ���1eB���J�w�,aO�L�+�J�S=�Y������τ������s�ڴ'�4��v���Deӫ�:��VoD�]�����ԛ�O�d�ǨCВ��B��-��;�[Z�Ǎ� �C�����GL�_&�T��(pb���� džʧ�ٯ�;;�!.%�FfP�W��w,���p^"Б��^4��ҽ�]%����"~�����q�
��q���u�N�y'Y�ݚ��:�O��b��ٗM�d�)�$��/��T�+��D�B��>�_��2�2�]h@���6�42Q;�Dc����Rz�y�x*����yV.!Xf���^c�(+�%��>2%q|@�1�-,�F����Նv����yj3���8=@��S[~o�Bn�|i�-,��h�-
�<7m�T
�;�|"x�mU�Q�6N:��j+����F��c()��Z��<�>�5�q/�mު�i�~̑���O&�'_1��r�`�E��2�Q�P �� q2�� �ES/���xD_z(�{m��I�%Et������Y�e�7���u�c5پ\�y3'RkՔ�*XXZ����f����7�;�/zRKO�UMW�����|��Y�r���s��'{t��(�#%�&�y������GRCх&7H��A�}�����p6��
d7�{W��67묖9V��&�zks��+O�r���D`ލ �
�Rɂ�����TL1���{@�~�*�qY�;�9(Ҷ�q4��� V�O�?�>����?'2���A_f-Z���)N�����\�KB�G����A=�#O7k�Y�Ѓu�:��=Ÿ��w���� ���}
릈[�6[Glr�7�n�Ɵk� vp�H�U`�
jc�p'A�~�t�҂�Z�Ylq�%��f�t�(��Sl�y�O.��+'�cj`,9���b��p�X�8q�s�|��]�*-��o�3�י �c�]
��j�ݖ��*�U��[����'X��
�[rU�rʳf���ۋiE:�4L�[��;����W\�'0p<9C��lФU5��r>5Kz�|�a�fy��9)Su6C5��t��i�~���۬��AC �;��m�5
��Tc�f1�������EC�T�p�J9��\���Fw +"| �Z3�o�,�n�cbGf���~MqR
����ݓs�����*�W5*U��53&��ȍu��� ��b�:��-��\
*����%Mm�'���=D�m�c��
�c����fMz�y*�*���5�շ�&����+(�[tdy��yj��Z;j�����
|� ~��lNZ UN�~�x؈W��'H� �Q[���JR����L)�� ~x�!w��Q�1���q�~��
'P�v�e�ZM;*t���D�L�W${�^�jˮ`6[U��Y�7B&��Oay�a
��\��==����7�| �h|��I�#��
�����\���Y����ң�)�L@�y`�;c!�K �G�SJ�
|�wOo)�u��06��{������E��*� �A��'�Ut�� l���5�����F����oFQ���9^�~�m�TG^g��"k#>��:�8�1�9���
X>K��)�6��%�����b�ge���tc�%��F� A>+e��;JW���Ƿ�I��+V ���?>�����pC~�8�ᑅ2qU]�
�Ý<1��ލ�$k��67�%��ܫH�|U@tv$,�O[���Pt�3vIiOe<M����:�����A�#�6pU`#a��@��$3@�:�)��-M�"K�A.���_Iؒ)$ƾiK�B!��Qzw�J+�Y�zÝ�(�
�t��u��n�=�+��������uR�"��+tTF;LAk�Wu�X"n�bq�v�q*�³.�DE��)�i�v�2�ܚZv�r4��l�m���z��H�q����̏Ӣ8�����Ą�K@ͧQ���
�"N/c�E~����#���M3�[�ؠMB���'��ɢ`��j����� ,��i�نl�7K"�za~�������5����&W1g�e�<�K��5��uƲny�}�����YGف�v4I�)a>���y��/�!�z�u^�f�A�n߂�<�"g�'����:1��/|T�&�&_��P�6���Ŷ��QջĘR��ې��q��j�"Lᖠ�f1ᒁ�� D=t�h�^~��3��ϸ)@2r��T�m-hn�y�����I�������5
)��`ѱ~Mz0?7t^���%R^�д�4�|���$#(_��.)q0�>�����E#G^xf��8����b��"����̪nBdڭmf�e$W`x����>��ᴣSGB�G����sw�p&E���[^�{X5����iWs<�0-�e��x�*?�i ����"��'u�[jM�|w
�r
&�ǩΟ�KT��s����o{p� UJ8��SM0A�7G��2c�-�ߦ��"�}�
N3�^��7
�D<ukj#���.c�Y�NSg�NC�!�7=6|�0�Bb�r3�lʗ��N8���~K�U�ZVOs [��1���]7�&ư����w>}�P*�}ْ?�i���s�w�-@Nƪ����=�13S�3��[��|�D� �3��d�Vl)H��R^�x�c�pe��O��7x������@�P��B����%��ן�磊��^���H�'���>���k#(bd" �|�[4Vݜ�Be�?�݃%9"�]�7����h2x��=�+ �u���:��ԟ��?tI����j�EI�
?(Y�]�}���dE�Ւ�,p���/�"�i�s�D�m�laمZ�$:�
�o�)��ͷڰ���_�ɳ2>h�c'��� �[��:���, �����w�+_����[�%U�7�ATl��b�7��i6���P+����)� <�C��oA���+�"%��0�d�=\= �KJ6ܵ�'P�H�Q�7ܤ��zG���O���n�^�����8l�؏�5H�G%�S���a��N�3�nc�3�P���M.��S�8M���)���"m 8����I}uj�>��&�
-����axo�t�(N�-�G��6�.ٶ�kB/�1�a'�6��i?���EV�կCP�ÒQ�������+����`�:�}ƅ��G�g;D�b��W�F[O�q�C��������8<�H��]]�����t]a ��K����p#�=�-q~�\^b.^���E��V�� �z #] ��
�O^
Good morning Heidi,
Any update on why the light intensity controller project stopped loading?
I restarted my machine and tried to re-load it this morning but it is still failing to load with the same error message. I already sent you the zipped up project. Thank you.
Kind regards
Mohamed
Hi!
The problem with your sample is the .overlay file. That isn't the correct way to set up the ADC peripheral.
However, I'm still working on finding a solution to this and I will get back to you later on in the week.
Heidi
Hi Heidi,
Spot on!
I managed to get the 'light intensity controller' project to load successfully. This is what I did: I deleted the content of the build folder and got rid of the overlay DT overlay file. However, I do need to the overlay file and I am eagerly looking forward to your solution.
Thank you.
Kind regards
Mohamed
