I can see in Segger Embedded Studio v4.52 under the Build Tab, there are two methods to build the project.
1- Build > Build zephyr/zephyr.elf
2- Build > Build solution
What is the difference between the two methods?
Kind regards
Kind regards
Thank you Heidi.
I would like to 'Verify Answer' but there bits bits of information spread over multiple posts. One way to do this would be to add the bits of missing information to the post that has most of the correct info. Please let me know and I will Verify.
Kind regards
Mohamed
Hi! I can try to summarize the most important parts of this very long thread in this comment. :)
To set up the ADC peripheral as IO-channels in the overlay file, we need to create a new node under the root node like this:
my,node {
compatible = " ";
io-channels = <&adc 0>, <&adc 1>;
io-channel-names = "CHANNEL_0_LABEL", "CHANNEL_1_LABEL";
where the &adc node is now connected with the analog input channels 0 and 1. Please note that you still need to configure the actual analog inputs (AIN0 to AIN7) in the main file. You can configure any analog input to any analog input channel.
All nodes need a "compatible" property. Even though it may seem like a logical choice for this node, you cannot use "nordic,nrf-saadc" as the compatible. This is a binding written specifically to instantiate the ADC peripheral and cannot be used with a node.
The only one available in NCS as of now is the "voltage-divider" binding in zephyr/dts/bindings/iio/adc/voltage-divider.yaml.
Users can create their own bindings and then use this as the compatible property. See the Zephyr Bindings documentation before you start writing it, for the file syntax and conventions, etc. Make sure to use a `[compatible]` that's namespaced to avoid conflict with other devicetree node identifiers; use something like `[companyname,rc-divider]`.
The &adc node does not need to be defined or set to status = "okay", because both of these things are taken care of in the board folder.
One of our developers wrote a simple sample for your use case (RC-divider and OP-AMP) that can be found here.
Also, please note that the documentation for the pin mapping on the nRF5340 PDK has some errors (both in the Getting Started guide and on the actual board).
This is the correct mapping, and on the nRF5340 PDK, the front of the board has the correct labels for the GPIO pins.
| AIN0 | P0.04 |
| AIN1 | P0.05 |
| AIN2 | P0.06 |
| AIN3 | P0.07 |
| AIN4 | P0.25 |
| AIN5 | P0.26 |
| AIN6 | P0.27 |
| AIN7 |
P0.28 |
As for the unit-address with regard to the SPI peripheral, it is defined as:
"An index representing the peripheral’s chip select line number. (If there is no chip select line, 0 is used.)"
Using this example as the explanation: The spi1 node has a chip select (cs-gpios) property, which means that the unit addresses for node a and b (0 and 1 respectively) are indexes into the cs-gpios array (an index representing the peripheral's chip select line number). The spi1 node has no cs-gpios, so node c has no chip select configured in the device tree, and therefore its unit address is left at 0 (if there is no chip select line, 0 is used).
This might seem a bit confusing, but you cannot look at the unit-addresses of nodes alone, you always have to look at the unit-address in context to the parent node. And when you look at the parent node of sub-node a versus sub-node c it becomes clear that sub-node a's "0" means an index into the cs-gpios array and sub-node c's "0" is just "NULL".
Let me know if there's anything missing and I'll add it in!
Also thank you for all your questions!
Heidi
Hi Heidi,
Your developer has actually provided a binding specific to our needs. So, I do not have to create my own bindings :). Happy days!
How do I download the code for the sample?
Thank you.
Kind regards
Mohamed
Here there is a green button called "Code". You can hit "Download" zip to get the zip-file or run git clone https://github.com/pabigot/fw-nrfconnect-nrf.git to clone the git repository.
Make sure to use the ncs environment the sample was made in (so don't extract the sample folder and place it in another ncs tag) and make sure to run west update, to update the other repositories as well.
Thank you Heidi,
I was going to extract only the sample I was interested in (https://github.com/pabigot/fw-nrfconnect-nrf/blob/sample/20201020a/samples/myapp/) and run it in my current environment. Why can't I do that?
I have my current zephyr installation here C:\Zypher\v1.3.0\...
06/08/2020 14:04 <DIR> .
06/08/2020 14:04 <DIR> ..
29/07/2020 17:21 <DIR> .west
29/07/2020 17:25 <DIR> bootloader
05/08/2020 11:38 1,664 Go_west.bat
29/07/2020 17:26 <DIR> mbedtls
29/07/2020 17:29 <DIR> modules
29/07/2020 17:21 <DIR> nrf
29/07/2020 17:25 <DIR> nrfxlib
29/07/2020 17:25 <DIR> test
29/07/2020 17:21 <DIR> toolchain
29/07/2020 17:29 <DIR> tools
29/07/2020 17:39 <DIR> zephyr
Which folder should I run the command 'west update' from?
Which other repositories will it update?
Kind regards
Mohamed
