Catch advertising timeout in main
I would like to catch in main.c the nobody connect after advertising event via ADV_SET_TERMINATED.
I can see with breakpoint program jump into  ble_advertising_on_ble_evt inble_advertising.c but once traeted, it doesn't call the same function in main.c.
I have added the case case BLE_GAP_EVT_ADV_SET_TERMINATED in ble_evt_handler in mains.c. But this timeout event doesn' reach the ble_evt_handler function of may main.c.
I saw another topics where Joakim Jakobsen proposed a good solution, that should solve the problem, but it dosn't work for me. My code is based on ble_app_buttonless_dfu_pca10100.
devzone.nordicsemi.com/.../142407
    uint32_t err_code = NRF_SUCCESS;
            case BLE_GAP_EVT_ADV_SET_TERMINATED:
               // AdvertisingTimeout, nobody connect after 1 minutes
               etat = EVENT_TIMEOUT;
Thanks a lot !
  • Hi Vidar,
    I'm in system On to keep ram retention and clock because i should wake up every day. My system start, do all peripherals init, go in low power with idle_state_handle(); called two time because first time it jump over i don't know why.
    Then I wake up with GPIOTE ( accelerometer connected to one input pin). It toggle from low to high. Once wake up, nrf52833 start advertising. If nobody connect, it raise timeout event, and i call idle_state_handle() to enter in low power, but it doesn't work this time. It jump over the the function without going into low power mode.
    How to know why it is impossible to enter into sleep mode ?
    Thanks for the tips to use port event
    Could you call idle_state_handle() from your main loop instead? If not you should consider placing it inside a spinlock loop that doesn't exit until the GPIOTE interrupt is triggered.
    idle_state_handle() may return immediately if you call it after servicing an interrupt because the internal event register is not cleared.
  • I call it in the main already, in my state machine, so i guess timeout advertising as raised an interrupt flag that as not been cleared as you said. How to know which flag has been set ? I think i have the same the issue at the first low power entering, because i need to call two times idle_state_handle();
        bool       erase_bonds;
        ret_code_t err_code;
      //  etat = START;
        for (;;)
            switch (etat){
                case START:
                     log_init();
                    NRF_LOG_INFO("State Machine : START!");
                    // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
                    err_code = ble_dfu_buttonless_async_svci_init();
                    timers_init();
                    power_management_init();
                    ble_stack_init();
                    peer_manager_init();
                    gap_params_init();
                    gatt_init();
                    services_init();
                    advertising_init(); //fle advertising init should be called after services init else error
                    conn_params_init();
                    // ACCEL INIT
                    acceel_init_spi();
                    accel_goto_mode_power(MODE_LOW_POWER);
                    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
                    in_config.pull = NRF_GPIO_PIN_NOPULL;
                    err_code = nrf_drv_gpiote_in_init(30, &in_config, in_pin_handler);
                    nrf_drv_gpiote_in_event_enable(30, true);
                        etat = LOW_POWER;
                case LOW_POWER:
                        NRF_LOG_INFO("State Machine : LOW POWER");
                        accel_goto_mode_power(MODE_LOW_POWER);    // attention si echec recommencer
                        idle_state_handle();    //why two times ? but it works...
                        //ZZZZZZZZZZ... Program sleep here, will continu after this comment on wake up
                         bma400_goto_mode_power(MODE_SLEEP);
                        etat = EVENT_WAKE_UP_MOVE;
                    /**/case EVENT_WAKE_UP_MOVE:
                            NRF_LOG_INFO("State Machine : WAKE UP on move!");
                            etat = ADVERTISING;
                case ADVERTISING:
                    NRF_LOG_INFO("State Machine : ADVERTISING...");
                    // Start execution.
                    advertising_start(erase_bonds);
                    etat = WAIT_USER_CONNECT_OR_TIMEOUT;
                    NRF_LOG_INFO("State Machine : Wait USER CONNECT or TIMEOUT...");
            /**/case WAIT_USER_CONNECT_OR_TIMEOUT:
                          /**/case EVENT_USER_BLE_CONNECT:
                                  NRF_LOG_INFO("State Machine : CONNECTED");
                                  etat = INIT_SENSORS;
                          /**/case EVENT_ADVERTISING_TIMEOUT:
                                  NRF_LOG_INFO("State Machine : ADVERTISING TIMEOUT");
                                  etat = LOW_POWER; //nobody is connected go back to sleep
                case INIT_SENSORS:
                        start_timer();
                        etat = RUN;
                case RUN:
                        //Sensors are measured in their timer interrupt
                case EVENT_USER_BLE_DISCONNECT:
                        NRF_LOG_INFO("State Machine : DISCONNECT");
                        etat = LOW_POWER;
            }//end switch machine d'etat
       }//end for infinite
  • So the problem is that you have to call the "idle" function to enter System ON idle? I think the safest method may be to add a spinlock loop in this case. Something like this maybe:
    static volatile bool m_acc_wakeup_triggered;
    void acc_wakeup_callback()
        m_acc_wakeup_triggered = true;
        bool       erase_bonds;
      //  etat = START;
        for (;;)
            switch (etat){
                case LOW_POWER:
                        while(!m_acc_wakeup_triggered)
                            __WFE();
                        m_acc_wakeup_triggered = false;
                            etat = ADVERTISING;
                case ADVERTISING:
                    // Start execution.
                case INIT_SENSORS:
                        start_timer();
                        etat = RUN;
                case RUN:
                        etat = LOW_POWER;
       }//end for infinite
  • The problem is that i can enter without issue in System ON idle( what i call low power) the first time. But then , after advertsing timeout , i can't. If you go deeper in the idle function you can see that __WFE is called into nrf_pwr_mgmt_run so that's not the issue i think.
    I think the source of the probleme is that somthing is blocking the possibility to enter into System ON idle mode. But what or how can i know which interupt service is not served to clear the flag i don't know where to look in whitch register for example
