OTA over BLE from nrf2840 central to nrf52840 using gatt
Hai ,
           I am using nrf52840 and 15.2 SDK  for ota over BLE. I  have made bootloader for OTA over BLE and tested same with nrf connect application using dfu package zip file. firmware is upgraded successfully and working fine.
          Now I need to upgrade firmware using  NRF52840 to another nrf52840 , as per the protocol i  have to send ping response , create object , init file ,check and so on..
sending ping response to bootloader but not getting any response for the ping response . traced the log from nrf connect application . have to write on 0x0001 characteristic , what is the correct way to write on characteristic , i am using ble_app_blinky_c example .
Kindly let me know how to write on particular characteristic on ble central?
thanks,
sowmiya
  • yes ,i am trying with simple application file , i have increased NRF_DFU_BLE_MAX_CONN_INTERVAL and NRF_DFU_BLE_MIN_CONN_INTERVAL.
    i am  not getting reset error but after writing two set of 244 bytes nrf side bootloader gets hanging after that not getting any errors or any return value. and also traced the log which i have taken from nrf connect application upto the two packets of 244  bytes are same.
    info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x2000A1A8, len=440 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <debug> app: Enter nrf_dfu_app_is_valid
    <debug> app: No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x200057D4)
    <debug> app: timer_activate (0x200057D4)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_ble: Initializing BLE DFU transport
    <debug> nrf_dfu_ble: Setting up vector table: 0x000F1000
    <debug> nrf_dfu_ble: Enabling SoftDevice.
    <debug> nrf_dfu_ble: Configuring BLE stack.
    <debug> nrf_dfu_ble: Enabling the BLE stack.
    <debug> nrf_dfu_ble: No advertising name found
    <debug> nrf_dfu_ble: Using default advertising name
    <debug> nrf_dfu_ble: Advertising...
    <debug> nrf_dfu_ble: BLE DFU transport initialized.
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    <debug> app: Enter main loop
    <debug> nrf_dfu_ble: Connected
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
    <debug> nrf_dfu_ble: max_conn_interval: 120
    <debug> nrf_dfu_ble: min_conn_interval: 120
    <debug> nrf_dfu_ble: slave_latency: 0
    <debug> nrf_dfu_ble: conn_sup_timeout: 3000
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST.
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (251, max_rx_time 2120).
    <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 500, reply: 247).
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> nrf_dfu_ble: Buffer 0x2000910C acquired, len 141 (244)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    <debug> nrf_dfu_ble: Freeing buffer 0x2000910C
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 64
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating init packet hash (init packet len: 64)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <debug> app: Enter nrf_dfu_cache_prepare()
    <debug> app: required_size: 0x5A08.
    <debug> app: single_bank: false.
    <debug> app: keep_app: false.
    <debug> app: keep_softdevice: true.
    <debug> app: SD_PRESENT: true.
    <debug> app: Bank contents:
    <debug> app: Bank 0 code: 0x00: Size: 0x0
    <debug> app: Bank 1 code: 0x00: Size: 0x0
    <debug> app: pass: 0.
    <debug> app: cache_address: 0x26000.
    <debug> app: cache_too_small: false.
    <debug> app: keep_firmware: false.
    <debug> app: delete_more: false.
    <debug> nrf_dfu_validation: Write address set to 0x00026000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x2000A1A8, len=440 bytes), queue usage: 2
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 3
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x2000A360, len=440 bytes), queue usage: 4
    <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 4
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 3
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 1
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
    <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 1
    <debug> nrf_dfu_ble: Buffer 0x2000910C acquired, len 244 (244)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x2000910C, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x2000910C, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000260F4, pending 1
  • Please do a sniffer trace so that we can compare of what exactly sent over BLE.
    Also please try to debug the bootloader, you can't just rely on the log to debug. When it hang you can stop and check where the MCU stuck.
  • i can able to transfer a firmware file ,but i am getting response for one packet of data , i am sending data as 244 bytes (which  is 242 bytes data and encoded with slip library ) total 244 bytes after getting one packet of data on bootloader , getting error 0x03,why it is getting invalid parameter ?i have attached the log.
    <info> app: Inside main
    <debug> nrf_dfu_settings: Settings OK
    <debug> nrf_dfu_ble: max_conn_interval: 50
    <debug> nrf_dfu_ble: min_conn_interval: 50
    <debug> nrf_dfu_ble: conn_sup_timeout: 600
    <debug> app: Bank 1 code: 0x00: Size: 0x5A08
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 0
    <error> nrf_dfu_req_handler: Object size must be page aligned
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x3
    <warning> nrf_dfu_ble: DFU request 1 failed with error: 0x3
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000260F4, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261E8, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000261E8, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262DC, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000262DC, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263D0, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000263D0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264C4, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000264C4, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265B8, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000265B8, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000266AC, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000266AC, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000267A0, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x000267A0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026894, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026894, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026988, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026988, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A7C, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026A7C, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B70, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026B70, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C64, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026C64, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D58, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026D58, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E4C, src=0x2000910C, len=244 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026E4C, pending 0
    <debug> nrf_dfu_ble: Buffer 0x2000910C acquired, len 192 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026F40, src=0x2000910C, len=192 bytes), queue usage: 0
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026F40, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:4096, CRC:0xAB950B70
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <error> nrf_dfu_req_handler: Write request too long
    <debug> nrf_dfu_ble: Buffer 0x20009200 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200092F4 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200093E8 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200094DC acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200095D0 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200096C4 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200097B8 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200098AC acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x200099A0 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x20009A94 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x20009B88 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x20009C7C acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x20009D70 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x20009E64 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x20009F58 acquired, len 244 (244)
    <debug> nrf_dfu_ble: Buffer 0x2000A04C acquired, len 192 (244)
    <warning> nrf_dfu_ble: cannot allocate memory buffer!
  • When you hit an error, and when you have the log, you need to read the log.
    Here is what the log said : <error> nrf_dfu_req_handler: Object size must be page aligned
    The object size must be page aligned. Usually object size is 4kB. It's mentioned here in the error code.
    It's really hard to help you if you don't study the example and the protocol properly.
  • I am sending each packets as 4096 bytes in uart , in 4096 bytes splitting as 64 bytes and after encoding using slip library send through uart to secure_uart_bootloader example on nrf  and  working fine over serial.
    as per the protocol ,same way like over serial  I am doing for ble bootloader each packets as 4KB and splitting as 242 bytes and after encoding the bytes sending over BLE.is this way correct to send over BLE?
