How start sampling by timer with PPI?
#define SAADC_CHANNEL_COUNT 4
#define SAADC_BUF_SIZE SAADC_CHANNEL_COUNT * 8
#define SAADC_SAMPLE_INTERVAL_MS 250
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static volatile bool is_ready = true;
static nrf_saadc_value_t samples[SAADC_BUF_SIZE];
static nrfx_saadc_channel_t channels[SAADC_CHANNEL_COUNT] = {NRFX_SAADC_DEFAULT_CHANNEL_SE(NRF_SAADC_INPUT_AIN0, 0),
NRFX_SAADC_DEFAULT_CHANNEL_SE(NRF_SAADC_INPUT_AIN1, 1),
NRFX_SAADC_DEFAULT_CHANNEL_SE(NRF_SAADC_INPUT_AIN2, 2),
NRFX_SAADC_DEFAULT_CHANNEL_SE(NRF_SAADC_INPUT_AIN3, 3)};
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
APP_TIMER_DEF(m_sample_timer_id); /**< Handler for repeated timer used to blink LED 1. */
static void event_handler(nrfx_saadc_evt_t const * p_event)
ret_code_t err_code;
switch (p_event->type)
case NRFX_SAADC_EVT_FINISHED:
for(int i = 0; i < p_event->data.done.size; i++)
NRF_LOG_INFO("CH%d: %d", i, p_event->data.done.p_buffer[i]);
is_ready = true;
nrf_gpio_pin_toggle(LED_ST_B);
case NRFX_SAADC_EVT_BUF_REQ:
err_code = nrfx_saadc_buffer_set(samples, SAADC_BUF_SIZE);
//buf_to_load++;
/* Applying workaround from Errata 212, otherwise current is stuck at 4-500uA during sleep after first sample. */
volatile uint32_t temp1;
volatile uint32_t temp2;
volatile uint32_t temp3;
temp1 = *(volatile uint32_t *)0x40007640ul;
temp2 = *(volatile uint32_t *)0x40007644ul;
temp3 = *(volatile uint32_t *)0x40007648ul;
*(volatile uint32_t *)0x40007FFCul = 0ul;
*(volatile uint32_t *)0x40007FFCul;
*(volatile uint32_t *)0x40007FFCul = 1ul;
*(volatile uint32_t *)0x40007640ul = temp1;
*(volatile uint32_t *)0x40007644ul = temp2;
*(volatile uint32_t *)0x40007648ul = temp3;
/* setup m_timer for compare event every 10ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 100);
//uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer, 10);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = NRF_SAADC_TASK_SAMPLE;
timer_compare_event_addr,
saadc_sample_task_addr);
err_code = NRF_LOG_INIT(NULL);
APP_ERROR_CHECK(err_code); //Configure Logging. LOGGING is used to show the SAADC sampled result. Default is UART, but RTT can be configured in sdk_config.h
NRF_LOG_INFO("nrfx_saadc_api2 simple SAADC Low Power Example.");
err_code = nrfx_saadc_init(NRFX_SAADC_CONFIG_IRQ_PRIORITY);
err_code = nrfx_saadc_channels_config(channels, SAADC_CHANNEL_COUNT);
nrfx_saadc_adv_config_t config = {
.oversampling = NRF_SAADC_OVERSAMPLE_8X, // oversample.
.burst = NRF_SAADC_BURST_ENABLED, // burst.
.internal_timer_cc = 0, // Sample 0.
.start_on_end = true, // Latch next buffer at END event in interrupt.
err_code = nrfx_saadc_advanced_mode_set((1<<0|1<<1|1<<2|1<<3),
NRF_SAADC_RESOLUTION_12BIT,
&config,
event_handler);
//timers_init();
saadc_sampling_event_init();
err_code = nrfx_saadc_mode_trigger();
while (1)
while(NRF_LOG_PROCESS() != NRF_SUCCESS);
__WFE();
